Old 4th December 2009, 23:27   #31
Thanked: 54 Times
check this link the part numbers are in the pdf - quote them when you go to the shop
http://www.neibearing.com/nbcpdf/new_CarJeep.pdf
techn0l0gist is offline   Reply With Quote
Old 5th December 2009, 00:11   #32
Raccoon's Avatar
Thanked: 105 Times
^^^ But these are for NBC bearings. Wont the part/bearing numbers differ with different companies?
Old 5th December 2009, 00:32   #33
Thanked: 48 Times
Was it NRB bearings? Don't know if that is what your require but NRB bearings is one of the leading manufecturers of bearings and a competitor of SKF and FAG.
NRB Homepage
rock75 is offline   Reply With Quote
Old 5th December 2009, 01:33   #34
Raccoon's Avatar
Thanked: 105 Times
^^^ No. It is correct as mentioned. He said its NMB. I googled it... but could not find any India specific website...
Still dunno what to do. :(
Old 5th December 2009, 23:56   #35
Thanked: 54 Times
the part number in the PDF is also the maruti part number for the wheel hub+bearing
Old 6th December 2009, 00:55   #36
Raccoon's Avatar
Thanked: 105 Times
^^^ Oh, is it? Well check it out once again...
Finally got fed up of inuring everywhere and I need to get the car running asap, so bought the NMB stuff from Nana Peth, from National Tempo House. Cost is Rs. 750 each. They also had another brand called Mi. Never heard of it. Price was the same.
Nobody seemed to have any other bearings. Inquired at all the SKF and FAG stockists I could find on the net. The distributor I mentioned earlier said SKF does not sell this assy. in the after market. They are only sold to OEMs. So I wonder how others here are claiming to have sourced SKFs. Are you sure they are genuine? Did you buy them from an authorized dealer?
Now the funny thing is, though both are NMB, they have small difference. Some can be seen in the pics. First, the label on the round plastic box is different. The print on the bearing edge is also not quite identical, etc.
Also, they didn't even come in a sealed box/wrapper. Just a poor quality round plastic box, which is cracked a bit. The bearing+hub assy. itself is just inside a open plastic bag with NMB print(can be seen in the pic). Otherwise, the actual assemblies seem almost the same.
I have no idea if these are genuine or even if they are quality stuff. The exterior finish is not exactly top notch nor is it what I can call bad.
Any comments, dudes?
Labels on the two boxes are different:
The print on the edge seen below is not exactly identical on both the assembiles as can be seen in this and the next pic:
Old 7th December 2009, 19:53   #37
Raccoon's Avatar
Thanked: 105 Times
No comments on these NMB bearings? :(
Just got them fixed. Mass charged Rs. 480 just for labor. Job takes about 30 - 45 mins.
Car is running smooth and quiet as before now. No apparent issues. The supervisor tried his best to assure me that wheel alignment is not necessary. However, I insisted and the rear wheels were indeed out of alignment (they were aligned at the same place during service, about 75 km earlier)! So don't forget to check the alignment after the job dudes.
I hope they last...
The original bearings are NTN. It has "Japan" printed on the rim... but not "Made in Japan".
Old 7th December 2009, 23:40   #38
Thanked: 660 Times
i don't have the latest price of original esteem bearing. but its 2006 price was rs.580/-
Old 7th December 2009, 23:46   #39
Raccoon's Avatar
Thanked: 105 Times
^^^ Can't be dude! Current price is somewhere around 5,500 each (rear). I don't think it can jump from 580 to 5.5 k in 3 years.
Old 7th December 2009, 23:58   #40
Thanked: 660 Times
Believe me i have the electronic part catalogue plus the parts list of every maruti car. courtesy a friend who is a MASS owner.
only esteem zen i have very old ones.
this is the best image i can show you. even the swifts one cost 1250/- it can't be more than that.
Name:  mruti parts.jpg
Old 8th December 2009, 00:17   #41
Raccoon's Avatar
Thanked: 105 Times
Well, I inquired at 2 MASSs and one authorised Maruti parts dealer or something. All of them quoted exactly the same price! Maybe the prices have been jacked up in the last 3 years? If yes, the leap is phenomenal!! :(
Old 8th December 2009, 01:02   #42
rr_zen's Avatar
Thanked: 268 Times
Are you saying you managed to buy one set at Rs 750 while MASS charges Rs 5500 for the same ? Am I missing something here otherwise ?
rr_zen is offline   Reply With Quote
Old 8th December 2009, 08:14   #43
gigy's Avatar
Thanked: 41 Times
Why is the print different on the same company's product, even if they are from different lot? the right one look more original NMB to me?
gigy is online now   Reply With Quote
Old 8th December 2009, 10:30   #44
Raccoon's Avatar
Thanked: 105 Times
Not one set... the NMBs are at Rs. 750 a piece. And the MGP price is above Rs. 5,500/- a piece, as mentioned.
Very good question! Thats why I posted the pics. Both the shops I visited had only 1 in stock, and I needed two. The second shop owner said he can order one more if I was ready to wait for half an hour. He had 2 Mi pieces though... which I somehow did not feel like buying, though I could not tell any difference by just looking at all of them. I asked him to get one more, and immediately noticed the difference in the label. He assured me that its the same thing and I should not worry. I could not find any difference between the two bearings at all... not visually at least; except that the small print on the bearings itself (on the circular part) was bit different too... Seeing no alternative, I went ahead and bought both. :(
NMB does not even seem to have a India specific website. Maybe they are imports? I just hope they are genuine...
Old 8th December 2009, 11:32   #45
rr_zen's Avatar
Thanked: 268 Times
Now that you have got them onto the car and you say the car is running fine, it means it is doing its job. Leave all your worries behind as you have not spent a bomb on this which would have been the case had you opted for the one from MASS.
This price difference is nothing but pure daylight robbery.
Rear bearing replacement at 43,000 kms? DukeSan27 Technical Stuff 57 28th December 2017 09:37
Wagon R - Rear wheel bearing broken Swift Technical Stuff 18 5th November 2013 18:29
Gypsy rear wheel axle bearing breaking repeatedly. Reasons? Solutions? abheekg 4x4 Technical 19 11th October 2010 13:10
Ohc - Rear Bearing Issue narayan Technical Stuff 13 22nd December 2008 16:24
the bearing used in handle bar of bikes vivekiny2k Technical Stuff 4 14th December 2005 10:48
