Old 27th June 2010, 17:34   #61
pramodkumar's Avatar
Thanked: 857 Times
Infractions: 0/1 (5)
Originally Posted by akas_chauhan View Post
I did mention car met with an high speed accident with 3 , 360 degree turn.
Yes my friend i remember, i have been following your other thread, i dont think you are experiencing wobble, its more like a noise am i right?
Pramod
Old 27th June 2010, 22:36   #62
akas_chauhan's Avatar
Thanked: 22 Times
Pramod
Yes Pramod, you are right. It's noise and lack of stability on high speed.
akas_chauhan is offline   Reply With Quote
Old 28th June 2010, 09:54   #63
Thanked: 857 Times
if it wobbles at high speed then first step is try balancing the wheel, if it still does it then interchange the wheel with the spare(you have to balance this one as well along with others). if the problem still exists you now know the culprit.
Pramod
Old 20th July 2012, 17:17   #64
Thanked: 19 Times
Default Re: Esteem rear bearing???
Am bumping up an old thread and hope to get a response.
I need to change the rear wheel bearing in my esteem and this costs close to 8K at M.A.S.S. However, when I checked with J.K. Automobiles J.C. Road (Blr) they quoted Rs 1900 for the same NTN make.
My question, can I source the part from J.K. Automobiles believing it, to be genuine/safe?
Has anybody else had any experience with NTN bearings as an aftermarket purchase?
rakirank is offline   Reply With Quote
Rear bearing replacement at 43,000 kms? DukeSan27 Technical Stuff 56 2nd January 2017 15:34
Wagon R - Rear wheel bearing broken Swift Technical Stuff 18 5th November 2013 18:29
Gypsy rear wheel axle bearing breaking repeatedly. Reasons? Solutions? abheekg 4x4 Technical 19 11th October 2010 13:10
Ohc - Rear Bearing Issue narayan Technical Stuff 13 22nd December 2008 16:24
the bearing used in handle bar of bikes vivekiny2k Technical Stuff 4 14th December 2005 10:48
