Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 25th March 2004, 14:09   #1 (permalink)
Shan2nu's Avatar
I'd like to know the difference between normal disc brakes, carbon fibre disc brakes and ceramic disc brakes.
What r their charetaristics?
Which is the most effective in terms of sheer braking power?
Do ceramic brakes need to be warmed up before use?
When we say Ceramic or Carbon Fibre, which part of the braking system exactly are these materials made of? Is it the Disc or the brake pads or both?
Regards...
Shan2nu
Old 25th March 2004, 14:31   #2 (permalink)
v12
v12's Avatar
i guess the discs are made of the material. Ceramic disc brakes can withstand very high temperatures. Thats why they are more efficient and effective.
__________________
Enfield Cafe Racer completed. Yamaha Cafe Racer started.
v12 is offline   Reply With Quote
Old 25th March 2004, 17:38   #3 (permalink)
1) Ceramics can take more heat ( Heat Resistant )
2) The more it can take heat , the more it is efficient
3) It is also eco- friendly and brake disc and pads are regulation parts.
4) It can also take Hard Braking and Continuous braking compared to normal Disc
toyota is offline   Reply With Quote
Old 28th March 2004, 16:26   #4 (permalink)
Sam
The effectiveness of Disc brakes is better than the old Drums which we find on most rear wheels of on the indian road cars. the princilpe of Disc brakes is that a Caliper presses on a Disc which is attached to a wheel.
The use of carbon fibre and ceramic brakes have 2 major disadvantages and one major advantage.
Advantage: When they work, they work really well.
BUT
Disadvantage: 1) you have to be in near racing conditions to get them to work coz their working temperature is not like that of normal Discs. They have to be heated up and have to stay hot. That means you will have to be braking from High speeds conatantly to keep them up to temperature.
2) the other disadvantage is they are Really expensive compared to normal discs.
What i suggest is if you looking for better braking try the vented and cross drilled type of brakes. These are ones with grooves in them or holes allowing for the brake dust from the brake pad to be be cleared off allowing better grip on clean discs. Increasing the size of the disc is not suggested unless you are increasing the horsepower and the wheels diameter, well its a whole science.
__________________
Winning isnt everything... its the only thing!!!
Sam is offline   Reply With Quote
Old 28th March 2004, 20:13   #5 (permalink)
Shan2nu's Avatar
I'm not planning to change the discs. I';m very happy with the braking of my Vtec. It's the tyres that spoil the party, but even then the car is pretty stable.
Regards...
Shan2nu
Old 6th March 2006, 23:22   #6 (permalink)
Edmund's Avatar
Question Disc brakes on the rear wheels?
How difficult is it to retrofit disc brakes on the rear wheels?
__________________
|zeropointeight for me to keep and miles to go before I sleep|
Edmund is offline   Reply With Quote
Old 7th March 2006, 00:30   #7 (permalink)
karthik247's Avatar
Carbon fibre and ceramic brakes are very reliable and last longer. They don't wear out like the normal brakes...
__________________
Mitsubishi Cedia - Pearl White
Skoda Octavia vRS - Magic Black
karthik247 is online now   Reply With Quote
Old 7th March 2006, 01:24   #8 (permalink)
nitrous's Avatar
Very much. Unless they're bolt-on, quite complicated.
__________________
Han:The Red Evo's yours
Sean:What do u mean?
H:U're representing me now...What did U think, I'm gonna let you roll in a hyundai?
Old 7th March 2006, 14:49   #9 (permalink)
sbasak's Avatar
That's the reason why most cars are fitted with drum brakes in rear wheels. Handbrake operates on rear wheels and it is really complex to link rear disk brakes with handbrake.
__________________
Gearbox acts as torque multiplier.
sbasak is offline   Reply With Quote
Old 7th March 2006, 14:53   #10 (permalink)
binz's Avatar
Sorry karthik;the carbonfibre brakes are very reliable but are more expensive(duh!) and wear out sooner than the normal discs.Dead sure about this but not about the ceramic ones.
binz
__________________
Advan Neova AD-07
Enkei RP-01
Suzuki Power!
binz is online now   Reply With Quote
Old 7th March 2006, 16:17   #11 (permalink)
nitrous's Avatar
Yeah, at US$1000 for a set of pads.
__________________
Old 7th March 2006, 17:16   #12 (permalink)
kb100's Avatar
What would the best way to upgrade the braking? Isnt the entire suspension a part of braking efficiency??
__________________
A closed mouth gathers no Feet.
kb100 is offline   Reply With Quote
Old 8th March 2006, 01:36   #13 (permalink)
nitrous's Avatar
Softer,wider tyres.
__________________
Old 8th March 2006, 11:17   #14 (permalink)
Rehaan's Avatar
Not really true.
A regular drum type handrake / emergency brake can be housed inside the disc, so to speak.
Check out this pic, it will give you a clearer idea...
cya
R
ps - kb100, i would say upgrading your tyres from stock ones takes you 70% of the way in terms of what you can do to make your brakes better...
Old 8th March 2006, 15:19   #15 (permalink)
karthik247's Avatar
They might be expensive, but u will obviously have to pay a lot more if ur looking for way better breaking power than the normal ones. It would be useless in India ofcourse, but if ur a guy who takes the car to the track u'll be more than happy to have them. No fading or less breaking what-so-ever.
__________________
Thread Tools
Drum brakes to Disc gdhiraj Modifications & Accessories 43 17th July 2009 16:16
Disc Brakes - Are they very expensive raneeshvijayan Technical Stuff 63 20th May 2009 14:49
Which Hatch back has all four disc brakes? VMG The Indian Car Scene 12 12th January 2009 09:56
Squeaky disc brakes on 1.8TPI? nanu28 Technical Stuff 8 3rd February 2007 00:14
Disc Brakes for Rear Wheel ~ H O N D A ~ Modifications & Accessories 39 24th June 2006 10:50
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
