Old 31st March 2004, 03:15   #16
Rehaan's Avatar
Thanked: 25,043 Times
Hey Sam,
In an auto the Neutral > Drive is REALLY bad for your autobox...... but i guess the choice of whether or not to risk doing it this way depends on the driver.....
Old 31st March 2004, 15:53   #17
Sam
Yes it is, I do agree, and it is upto the driver. Thats why i do it with the reverse 1st, coz then the revs are not so high. It is similar to trying to accelerate up hill. The cars momentum is going in reverse and the wheels are powered to go forward, so there is loss of traction.. ie a spin
Sam is offline   Reply With Quote
Old 17th July 2005, 19:31   #18
karthik247's Avatar
Thanked: 16 Times
guys then how do u do wheelspins, from a stand still. I mean the car dosen't come, but the wheels keep spinning??
karthik247 is offline   Reply With Quote
Old 17th July 2005, 20:12   #19
turbo_lover's Avatar
Originally Posted by Dippy
Hey guys
Is wheelspin possible in an A/T car? had seen the SL do it in the Speed Run 2003. If its possible how can it be done any ideas guys?
dude ...i have done tons of wheelspins ....
including 120k's burnout in a Rented grand am ...
to get a wheelspins jut tap hard on the gas pedal and your sure to get a wheelspin ...
to get a burnout ...select (R) ..go backwards for around 10 feet and then shift to 1 /2 or Drive ...and you get a burnout ...remember to switch the traction control systemm...
turbo_lover is offline   Reply With Quote
Old 17th July 2005, 20:23   #20
balenopower's Avatar
Thanked: 228 Times
well as far as wheelspin is concerned the big sl's and our v6 sonatas will burn rubber without any probs but on zens and wagonr's and other smaller auto's ....forget it unless u wanna screw the tranny....
balenopower is offline   Reply With Quote
Old 17th July 2005, 20:38   #21
are we talking about burnouts or wheelspins ?
wheelspins are harmless you are just flooring the gas in D select ...it's like spinning the wheels at 1st gear ...burnouts are rather hard on the tranny ...
Old 17th July 2005, 21:19   #22
karthik247's Avatar
Thanked: 16 Times
oops.. i meant the burnouts
Old 17th July 2005, 21:34   #23
dadudeonfire's Avatar
keep the gear on neutral accelerate till u reach high rpm and then just put it on d...this is the best way of doing it
dadudeonfire is offline   Reply With Quote
Old 17th July 2005, 21:56   #24
nope its only good for wheel spins ..not a burnout ..
i havent driven an auto here but you cant give a car full rev at N ..the rev limiter cuts it off..
Old 6th December 2010, 22:19   #25
siddheshb's Avatar
Thanked: 251 Times
This is what I do in my Endy... press brake (with left leg), revv the throttle in D, and leave the brakes, the surge of power gives an excellent burn of rubber
With a manual Fiesta and Ikon though, this used to be a piece of cake
siddheshb is offline   Reply With Quote
Automatic Transmission wolfgangsiva Technical Stuff 7 2nd April 2018 13:02
Automatic Transmission v/s Manual venkatrx Technical Stuff 331 19th February 2017 18:07
Automatic Transmission - Gearbox oil change vinodbijlani Technical Stuff 14 25th May 2016 15:20
Mercedes Benz 300D (W123 series): Manual Transmission to Automatic Transmission. wartikars Post-War 5 3rd January 2014 12:39
Maruti Alto Automatic Transmission? genopv Modifications & Accessories 7 5th July 2006 19:05
