Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 30th August 2006, 15:49   #1 (permalink)
superavi's Avatar
Question Baleno - Pinging noise after the car's started
Guys,
We have a baleno which of late (5 months approx) has begun to emit a pinging noise (like a tappet) when the car's just started in the morning. It persists for a few seconds, and when the car's warmed up, it disappears.
We brought it to the notice of Bimal (service center) and they said that it requires some adjustment and/or lubrication.
We noticed that the sound's become louder now and these guys havent been able to rectify it.
Baleno owners/gurus - let me know if you've faced a similar problem and how you rectified it.
TIA
Superavi
superavi is offline   Reply With Quote
Old 30th August 2006, 15:58   #2 (permalink)
Samurai's Avatar
Your first mistake was to buy from Bimal. The second mistake was to take your car to Bimal service station. Those folks generally don't know much about cars.
Don't worry, I have done the same mistakes with my Baleno. My car FE dropped by 2 Kmph after second service at Bimal, and they had no idea what to do and how they did it. I switched to Mandovi and had much much better experience. I suggest you do the same.
__________________
Samurai
The only Super Car in my book -Bowler Wild Cat
Old 30th August 2006, 16:58   #3 (permalink)
superavi's Avatar
Thanks Samurai, this is something I've mentioned to my unc (it's his car) for a couple of months now. Which is why I specifically mentioned Bimal here.
Coming back to the problem, has anyone else experienced this? Any ideas on what it is and what the solution could be?
Superavi
Old 30th August 2006, 17:49   #4 (permalink)
Superavi
I think, its gotto to do with not enough lubrication or oil somewhere (could be tappets) and after the engine warms up and oil being circulated properly the sound dies off.
Try this...
Take the car for a spin for few KMs. Check for the same sound when the car is cranked after being parked for an hour or so.
Is it that the sound comes only in the morning?
Ciao
Samy
urdudesamy is offline   Reply With Quote
Old 30th August 2006, 18:23   #5 (permalink)
Shan2nu's Avatar
Most cars sound harsh when they're started after a long interval. I guess the engine needs a lil warming up.
Shan2nu
Old 30th August 2006, 19:09   #6 (permalink)
superavi's Avatar
Would a car that's driven everyday sound harsh at the start of a new day? She's covered 36000 kms and is in very good condition otherwise.
Is there anything we need to be concerned about? Is this a common occurence?
Superavi
Old 30th August 2006, 19:52   #7 (permalink)
humyum's Avatar
It could have been that the tappet setting was set when the engine was hot leading to them having no clearance when the engine is cold as metals expand on heating and contract on cooling.Hence the sound when the car is cool and the sound goes off when it warms up.This will lead to premature wear of the tappets.
__________________
Life is Simple - Eat,Drink,Swift!
Old 30th August 2006, 20:20   #8 (permalink)
Samurai's Avatar
If I remember correctly, tappet setting should be done when the engine is completely cool. The mandovi guy let the car cool for a day in the shop before he adjusted my Baleno's tappet.
__________________
Samurai
Old 30th August 2006, 20:41   #9 (permalink)
superavi's Avatar
Default Will try out this solution
Thanks Humyum and Samurai,
Will check out the tappet setting at Mandovi.
Thanks folks, will keep you updated.
Superavi
Old 31st August 2006, 18:42   #10 (permalink)
@superavi
Are you sure it is the tappet noise. At times this is due to generator belt. When the car is started a shreeking sound is heard and when it is revved up, the sound is gone. It is due to the battery weakness which is unable to move the generator belt alongwith the starter of engine at full speed. I am not 100% sure but also get your car battery checked for gravity, etc.
bkahive is offline   Reply With Quote
Old 31st August 2006, 19:01   #11 (permalink)
Originally Posted by bkahive
@superavi
I agree with you on the alternator belt, but that has nothing to do with battery, the noise occurs from the belt , when it is bone dry, a few drops of brake fluid will make the problem go away
s.prashanth is offline   Reply With Quote
Old 31st August 2006, 19:24   #12 (permalink)
Jaggu's Avatar
pinging as in metalic sound, just make sure its just not the silencer pipes expanding under heat, this you will hear when u park the car after a run also.. usually happens in new cars, just make sure before u go on tappet, pulley and all..
alluminium blocks and pipe parts give out tic tic sound while heating and coolin
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 8th September 2006, 15:03   #13 (permalink)
superavi's Avatar
@jaggu, prashant, bkHive,
There's no noise after the engine's gone cold. And it's certainly a cold start problem.
This will probably be addressed this weekend, or in the next few days. Will keep you posted.
Superavi
P.S. Thanks for your suggestions.
Old 8th September 2006, 15:25   #14 (permalink)
Stryker's Avatar
Hi, my first post here after a long time, almost a year now. Nice to be back and hopefully I will remain here now. Sometimes things take all your time for quite a long time and just dont let up. You know how it is.
I have the reverse problem of superavi. After I park my Baleno, once I am back after a drive of around 10kms or so (the distance between my office and home), I can hear a pinging sound from somewhere under the car. It is more a "tak tak" sound rather than a ping. The service guy over at Sagar told me it is the sound of the engine cooling off and it will usually disappear after the first few weeks, but it is more than a year now and it is still making that noise when I park it.
The car has done about 10000 kms in the last year and there is no other problem with it. Just this noise after I park. Any ideas? Is this normal?
Stryker is offline   Reply With Quote
Old 11th September 2006, 16:34   #15 (permalink)
Jaggu's Avatar
@stryker same sound as i mentioned and absolutely normal
__________________
Thread Tools
Baleno Suspension Noise s.prashanth Technical Stuff 4 6th February 2009 16:04
Baleno Cabin noise problem!! iceman1 Technical Stuff 8 25th June 2008 11:55
Noise and vibration in Baleno engine sans33 Technical Stuff 14 20th June 2008 19:42
baleno making kr..kr..kr..kr noise gigy Technical Stuff 19 6th July 2007 20:33
Baleno: Rolling noise what is the truth? javedbhaimumbai The Indian Car Scene 25 21st October 2005 04:44
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
