Old 18th September 2006, 01:06   #16
rjstyles69's Avatar
Thanked: 795 Times
Have had the squeaky noise in my baleno also.Dunt know if its the same same noise you have mentioned. I use the car only during the weekends and have this noise once i start my car. Eventually dies down in less than a minute.Superravi have you been able to find the root cause???? I was due to go down to RNS this weekend and couldnt do so..
Old 18th September 2006, 12:06   #17
Stryker's Avatar
Thanked: 827 Times
Hey Jaggu, thanks man. That sound was really making me uncomfortable. I checked under the car after I parked and identified the location as somewhere near the silencer, so it could be the silencer pipes expanding/contracting due to heat.
Stryker is offline   Reply With Quote
Old 10th October 2006, 18:01   #18
superavi's Avatar
Thanked: 13 Times
It took two visits to Mandovi, but the sound is now pretty less. At times there is no pinging, but a couple of occasions there is this muted pinging noise, which is not as scary as before.
Thanks Samurai. I hope my uncle (and now my friend who's bought the car from my unc) have seen the end of that sound.
I now have a new problem in my siena, but that's in a new thread.
Superavi
superavi is offline   Reply With Quote
Stebel Nautilus Horns - gargling noise? no noise? gd1418 Technical Stuff 31 23rd May 2011 21:59
Elantra rare noise (hissing noise) Please help!! manne Technical Stuff 9 28th June 2010 09:24
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
