Thread Tools
Old 31st August 2006, 04:44   #1 (permalink)
pramodkumar's Avatar
Unhappy Please suggest - power windows, power steering from one Esteem to another
Hi Guys,
I have a 98 model esteem lx carb, I have a friend who has a carb model esteem which is now completely totaled (he had a major colision from the passenger side) Now since he has written off that car he suggested me if i want i can take the power windows and power steering assembly from him. please tell me is it possiable that i can simply bolt these things to my car or do i need any serious mods. please suggest is it adviceble to do this as i love my car and it took me 7 years to buy this car but i was in a hurry so i brought a lx model. Please help
Old 31st August 2006, 15:29   #2 (permalink)
esteem_lover's Avatar
i am pretty sure that you can transfer the power steering kit to your car. but the windows, i am not so sure, because if you have to change the door pads, which could be damaged due to the collision, then it might work out very expensive & not worth it, really. consult your mechanic & ascertain what would be the actual costs.
cheers
__________________
can't you hear me? What, do you have bubble gum in your ears ? like Mr.Bean ?
The Bean effect on my 4 year old
Old 1st September 2006, 01:04   #3 (permalink)
Thanks for the reply. i know a mechanic who has converted a power window to a manual window in an esteem he has those door pads and motors only 2 sides and the pillar is badly damaged in my fren's car i can use the rest. i was only doubtful about the power steering wether it is a direct bolt on or not.
pramod
Old 1st September 2006, 06:53   #4 (permalink)
SLK
SLK's Avatar
Even for the power steering.... there are going to be many bolts...
might not be a very simple job.... but then the mechanic would know better..
__________________
Č╠╣€€Я$
$£Қ
SLK is offline   Reply With Quote
Old 1st September 2006, 09:19   #5 (permalink)
Take it. The Power steering units will bolt on. Don't forget to remove all the brackets and clamps along with the pump from the engine block.
The power window units will also fit, but make sure you get all the clamps and brackets. What you should ideally do is get both cars in the same place and start the work.
__________________
Live Life King Size!
jyobeb is offline   Reply With Quote
Thread Tools
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 19:56
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 9 1st October 2007 16:27
Power Windows for Indica sunil_khanduja Modifications & Accessories 8 12th September 2006 15:16
update my esteem with power windows viper dude Modifications & Accessories 8 25th October 2005 18:33
Power windows NHC SCH Technical Stuff 2 6th August 2005 16:32
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
