Thread Tools
Old 31st August 2006, 13:29   #1 (permalink)
Jaggu's Avatar
Default Cough cough!
Finally it has started, wasnt been using the iKON regualrly and today morning when i started the car started idling with tons of vibration. Ran the car for approx 7 kms to office and power and response all the same, still engine has considerably more vibration when idle, even after engine is warm. No smoking at pipe yet.
Symptom of:
Conked plug/Plug wire?
Injector clogged?
Or is it anything else?
Anybody who has done injector cleaning in Bangalore? Especially do the dealer handle this job.
Anyways have booked an appointment with Metro Ford for the weekend.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 31st August 2006, 13:41   #2 (permalink)
Accumulated moisture and clogged up pipes
Try an italian tune up
Warm the engine, then drive in high revs and beat the hell out of it
__________________
I love the whoosh, but i miss the bellowing
Old 31st August 2006, 15:50   #3 (permalink)
esteem_lover's Avatar
ajmat,
i have faced the same problems & done the same thing & it has worked. but is that the right thing to do ? wouldn't there be any long term issues here ?
__________________
R.I.P Islero
esteem_lover is online now   Reply With Quote
Old 31st August 2006, 16:05   #4 (permalink)
Originally Posted by esteem_lover
ajmat,
Not after the engine has warmed up
I took my car to the race track last week. It drove even better coming back!!
__________________
Old 31st August 2006, 17:11   #5 (permalink)
Jaggu's Avatar
yup will do on the way back when traffic clears, i have a wierd feeling its something to do with plugs firing in my case, anyways its italian tuneup for today
__________________
Old 1st September 2006, 10:22   #6 (permalink)
Jaggu's Avatar
Italian tune up turned negative results, cough persists..
soot at exhaust, injector or plug?? seems like injector only, hope they have cleaning machine in place at the dealer for tomorrows appointment :(
__________________
Old 1st September 2006, 10:29   #7 (permalink)
Rtech's Avatar
Why don't you try putting some injector cleaner first and see if that helps. Far cheaper than taking it to a dealer and paying those prices.
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 1st September 2006, 10:44   #8 (permalink)
Or just do a search on the forum.. you will find a lot of threads on adding this and that into petrol that helps in the supposedly smoother running of your car... or wait a bit and soon you will find a thread that says what happens when you mix PETROL to boric powder/thinner/whiskey/rum/vodka and then run a car on the cocktail
2L8uLoose is offline   Reply With Quote
Old 1st September 2006, 12:34   #9 (permalink)
elf
elf's Avatar
Default Free flow...?
Originally Posted by 2L8uLoose
... you will find a lot of threads on adding this and that into petrol ...
... you mix PETROL to boric powder/thinner/whiskey/rum/vodka and then run a car on the cocktail ...
On gas tanks, I've seen stickers of little boys relieving themselves... what does that imply?
elf is offline   Reply With Quote
Old 1st September 2006, 12:43   #10 (permalink)
MORAJI DESAI SPECIAL!!!
Old 1st September 2006, 13:00   #11 (permalink)
Jaggu's Avatar
Guys i have been using Iftex.
History of the car, it was idle for a year when it was in kerala and had a severe case of the same symptom and one injector had to be changed.
Afterwards it was running fine for 3 years and lately i become sucker for my puny lil CT 100 thanks to ease of commute in banglaore traffic :(
since bangalore guys dont have any info on external help with injector cleaning i shall keep my appointment for tomorrow.
__________________
Old 1st September 2006, 15:40   #12 (permalink)
iraghava's Avatar
Have you checked the fuel filter?? Same problem occurred in my car on tuesday & it was the result of a clogged fuel filter, changed it & everything is back to normal now.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 1st September 2006, 16:24   #13 (permalink)
Jaggu's Avatar
nope i havent but will take fuel filter>plugs>plug wire>injector route
what car is urs, was this a mpfi or carbed car?
__________________
Old 1st September 2006, 16:43   #14 (permalink)
iraghava's Avatar
OHC VTEC, MPFI & firstly I had had the plugs checked & they were fine so the mechanic opened up the filter & it was full of dirt so we changed that & now she's running fine.
__________________
Old 1st September 2006, 17:14   #15 (permalink)
Jaggu's Avatar
thanks mate, anyway tomorrow will come to know
__________________
Thread Tools
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458
