Old 4th February 2006, 04:13   #31
Rehaan's Avatar
Thanked: 25,038 Times
Originally Posted by cbr1000f
you cant run something like this on petrol right because there would be no way to ignite it.
another query... with a piston stroke that long, at 103rpm arent you exceeding 20m/s piston speed making the engine unstable?
98" Stroke
Piston travels 98"x2=196" per 1rpm
196"= 4.98m
103rpm x 4.98m = 512.94m / minute
512.94 / 60 = 8.54 m/s
Correct?
cya
R
Old 4th February 2006, 22:21   #32
jat
R, you are right.
You can run it on petrol (and you don't have to fit a welding machine for ignition) but it is not used because economics does not allow it.
RK
jat is offline   Reply With Quote
Old 5th February 2006, 11:08   #33
cbr1000f's Avatar
silly question! just read the artice and saw stroke only 98''... looks much more doesnt it
thanks Rehaan.
cbr1000f is offline   Reply With Quote
Old 8th May 2006, 22:10   #34
Cool Belive it or not itz an engine
hay dudes check this out don be stun its not a building its an engine //http://www.bath.ac.uk/%7Eccsshb/12cyl/
samybravo is offline   Reply With Quote
Old 8th May 2006, 22:43   #35
karthik247's Avatar
Thanked: 16 Times
Umm..isn't this already posted on the site?
karthik247 is offline   Reply With Quote
Old 8th May 2006, 22:47   #36
Deeps's Avatar
Thanked: 68 Times
Like Karthik said, we've already seen it. But if by posting it in this section you are implying that a motorbike could perhaps be powered by this then...
Deeps is offline   Reply With Quote
Old 8th May 2006, 22:56   #37
jango's Avatar
Thanked: 19 Times
nice one dude am seeing it for the first time and yes they are used in ships !!
jango is offline   Reply With Quote
Old 8th May 2006, 23:26   #38
kb100's Avatar
HOLY MACKAREL!!.... Thats huge!!... yeah seeing it for the first time!!
I have been in a few ships engine rooms - but this puts a perspective to that! (can imagine now what it might look like stripped)
kb100 is offline   Reply With Quote
Old 9th May 2006, 00:05   #39
elf
elf's Avatar
Thanked: 9 Times
Wink Thanks GTO!
See! This is what I like about T-BHP.
I've been moaning & griping all over the forum about the lack of bottom end in my Lancer, & GTO, darling that he is, goes & starts a topic on it offering a solution!
Thanks man!
I may have to enlist Viper's services, though, as I'm not too sure it would clear the bonnet. Any idea if my K&N would work with it?
Later...
elf is offline   Reply With Quote
Old 9th May 2006, 17:46   #40
sumitkalindi's Avatar
Thanked: 13 Times
This IS BIG.
Originally Posted by jat
May be 3 mts per litre
RK
Do you know the FE of Our homegrown Arjun Tank?? By tank standards It is Very frugal.
sumitkalindi is offline   Reply With Quote
Old 10th May 2006, 17:44   #41
Thanked: 54 Times
most of these engines run on oil ,not on diesel .The Rpm mayt exceed 500 and the wartsila engine might be doing a max of 200-300 i guess .
Old 10th May 2006, 20:24   #42
jat
For rpm and power range, one can refer to this site.
http://www.wartsila.com/Wartsila/doc...rta_series.pdf
These engine can operate from as low as little above 60 rpm. Interesting - like a second hand of clock ticking!!!
Another high power - slow speed engine maker
http://www.manbw.com/engines/TwoStro...nesProgram.asp
Old 12th May 2006, 16:34   #43
jat
This engine consumes around 14000 lts of fuel in one hour at full power. If we assume that average people consume around 100 lts of diesel in a month, it amounts to 140 months or nearly 12 years of fuel!!!
The fuel used can have a density of 1010 kg/m3 that is heavier than water.
The fuel specs says that the pour point should be less than 30 deg Celsius. In most of the Indian cities the oil would not flow at night. Something like tar!!!
The cooling water in the system may be 10,000 lts and if lube has to be changed, then it would amount to around 40,000 lts in one go!!! Well here it is never changed
Old 12th May 2006, 17:24   #44
cool... I would like this engine with a free flow exhaust system heehee :-)
RoaringEngine is offline   Reply With Quote
Old 12th May 2006, 20:13   #45
OT but wouldn't that be 1 rpm?
hrag is offline   Reply With Quote
2010 Vyrus 987 C3 4V: Fastest, most powerful production bike in the world Sarvodaya Superbikes & Imports 19 29th October 2009 13:11
The World's Most Powerful Street Legal Car turbo_v12 The International Automotive Scene 38 20th June 2008 21:04
World's most powerful diesel engine Ram Shifting gears 6 31st January 2006 22:19
The world's most powerful production car tabrez02 The International Automotive Scene 32 17th July 2005 21:53
The Most Powerful Automotive People in the world GTO The International Automotive Scene 5 27th January 2005 01:12
