Old 4th March 2016, 21:56   #16
im_srini's Avatar
Thanked: 397 Times
Post Re: Front Brake Caliper Pin for Hyundai i10?
Originally Posted by techiecal View Post
Has anybody sourced Lithium grease here in India.
If anyone has procured please let us know the source.
Hello
I got a tube of lithium grease several years ago at a tire store (TyreStore (Chennai)) in Chennai, I'm guessing any high-end accessory store at your location that deals with imported products should be able to provide some.
Or, you could try online, industrybuying, for example, I've ordered from them before & had a pleasant experience (Tools for a DIYer).
Incidentally, the last time I took my K10 for a service, several months ago, I was informed that an annoying rattle I'd complained about was due to the caliper pin. I was also told that the pin wasn't available separately & that I would have to change the entire caliper. I thought it ridiculous at first but on checking the Parts-Catalog saw that it was indeed true, the front caliper was available as as assembly, however so was the pin & the little rubber boot over it - available as a set for ~ Rs.118 ! So it should be possible to just order the caliper pin set from MGP. One question though was why the pin gets "eroded" even though the caliper is just moving laterally on the pin. Nevertheless, given the simplicity of the pin, I guess it should be possible to get it turned out of higher grade steel on a lathe for longer life. Also, funny thing is that my 15-year old Alto ( ~100K Kms ) has never had this issue
im_srini is offline   (1) Thanks Reply With Quote
Old 4th March 2016, 22:20   #17
Awaiting Email Confirmation
Thanked: 319 Times
Default Re: Front Brake Caliper Pin for Hyundai i10?
If you are okay with spongy brakes then Teflon or brass sleeving is acceptable. If you want the tight feeling then you have to get the slightly oversized pin by about 0.1mm and then take it to the lathe along with your caliper assembly. They will sort it out in about 5 minutes.
The present day pins wear out faster because they are made of aluminum alloy to save weight, better heat transfer and non corrosive. I have in my car the Cruze, replaced the caliper pins with the pins from the TATA manza which are a straight fit except for the rubber boots.
Please note that it should be a tight fit when received from the lathe, something like twice as tight as the hinges of Olympus binoculars or the focus wheel of the Olympus microscope.
drpullockaran is offline   (1) Thanks Reply With Quote
DIY: Installing Brake Caliper Covers 197Horses DIY - Do it yourself 33 4th September 2017 23:34
Strange sound from my SX4's brake caliper Kaumad Technical Stuff 9 24th July 2014 17:14
Brake Caliper Failure supertinu Technical Stuff 17 9th July 2014 16:45
Hyundai Accent - Front Brake Pads need replacement every 10,000 kms! hbaruas Technical Stuff 25 23rd October 2012 20:43
Loose Caliper problem in Hyundai i10 maxmachine Technical Stuff 13 17th November 2009 22:34
