Old 1st October 2006, 14:03   #16
Pankaj401's Avatar
Originally Posted by Domnic
Indian:
37820-PJT-E01
7M 1346-201049
Thai:
37820-PJT-T01
43 1340-101245
37820 is a code for honda
PJT - is type of car here its the Honda B15C2
E01 or T01 - Country code E is india, T is thailand
cheers
The bold & underlined seems to be the serial. I have it as 100923.
Pankaj401 is offline   Reply With Quote
Old 1st October 2006, 15:59   #17
Ford Rocam's Avatar
Thanked: 16 Times
Honda ECU Part number concisit of three main components
*37820 which denotes as Honda part number & will be same
* The 3 centre characters are loosely related to model of car/engine in this case (PJT)
* The third number is not the country code but the revision of the ecu,
We should look for Middle 3 characters to identify what ECU is running, in indian Vtec case the number is same as malaysian part the only difference is the revision number when honda launched Vtec in India they detuned it,they used the same ECU but mapped according to indian fuel condition that time which was at 87octane hence the code is E01.
Ford Rocam is offline   Reply With Quote
Old 1st October 2006, 17:49   #18
Pankaj401's Avatar
Per Honda rep (Mr. Somaraju from Chennai office) the ECM is not re-programmable. Though he said certain parameters could be changed. I wonder what that means. I'll find that on next Saturday from Whitefield.
Old 1st October 2006, 20:41   #19
Domnic's Avatar
true, the indian ecm's cannot be reprogrammed, just a few basic adjustments can be done.. thats about it..
yep third series of alphabets indicate revision as rocam pointed out....
heres a link from hondata which explains
http://www.hondata.com/techecuid.html
cheers
Domnic is offline   Reply With Quote
Old 1st October 2006, 21:11   #20
Domnic's Avatar
also would like to add in third series the first alphabet denotes the market, t01 is usually jdm.
A, L usually USDM
J, 9, X*(T) usually JDM some UK (EDM) ecu's also listed as T
Q Australia...
you get the idea...
Old 3rd October 2006, 23:53   #21
Pankaj401's Avatar
In the meantime does anyone has the OHC workshop/service manual or an idea how one could be procured?
Old 7th October 2006, 19:49   #22
Pankaj401's Avatar
Just came back from trip to WhiteField Honda. The Asst. Service Manager there confirmed that they can't make any changes to the ECM and I should learn to live with these jerks.
I do feel that the fuel quality makes a lot of difference though.
Old 16th October 2006, 22:53   #23
Pankaj401's Avatar
[SIZE=2]Wanted to know if re-mapped ECU (as GTO mentioned) is off the shelf replacement for pre-2001 OHC VTEC?[/SIZE]
Problem with Vtec idling...varying RPM. EDIT : Solved! GTO Technical Stuff 99 22nd January 2017 16:48
NHC - BullKit Problem :EDIT: now detected to strut problem ibcool Technical Stuff 13 9th September 2007 12:02
OHC VTEC Problem iraghava Technical Stuff 9 9th September 2006 21:13
NHC-Vtec or OHC Vtec..which is a better buy? sunith Sedans 4 2nd May 2006 21:25
Indian vtec 106 bhp  Thai Vtec 120 bhp ajmat The Indian Car Scene 7 7th March 2006 18:21
