Old 30th July 2015, 00:35   #1
Thanked: 48 Times
Default Odometer suddenly started showing a lower reading!
Hi all,
My first car - a Chevy Spark - was unused for a while and the battery died down. When I started it today, I found 10k kms missing from the odometer. It came down from 17000 odd to 7000!!
How do I fix this? I was actually hoping to sell it off this month, so how do I explain it to the buyer / dealer where I hope to sell it off ?
Please help.
Note from Mod : Please use proper capitalization + punctuation. Make sure you see THIS THREAD (Expected Posting Etiquette) before continuing. Thanks.
Last edited by GTO : 2nd August 2015 at 11:11. Reason: Please take a look at the mod note that has been added to the end of your post.
kippu is offline   Reply With Quote Received Infraction
Old 30th July 2015, 09:00   #2
Thanked: 8,933 Times
Default re: Odometer suddenly started showing a lower reading!
I assume you have some sort of digital display? In most cases the km get stored on the ECU. In any case you can read the real mileage with most OBD readers. To change them you typically need some special SW, because for obvious reasons, the manufacturers have made it a bit difficult to change the mileage to easily.
If nobody had messed around with some reader, changes are that it is indeed one digit that is playing up or some other weird electronic problem. First thing is to check with a reader. If you find your original mileage embedded somewhere in the electronics the next steps would be to start checking the display/wiring etc.
Good luck
Jeroen
Jeroen is offline   (2) Thanks Reply With Quote
Old 30th July 2015, 09:28   #3
condor's Avatar
Thanked: 4,894 Times
Is it that the specific two segments are not lighting up ? ( Like if the LCD display is faulty).
condor is online now   (3) Thanks Reply With Quote
Old 30th July 2015, 11:46   #4
PapaBravo's Avatar
Thanked: 1,604 Times
+1. I think the 5 digit LCD display would have gone Kaput if the meter is digital.
PapaBravo is offline   (2) Thanks Reply With Quote
Old 30th July 2015, 12:08   #5
Thanked: 1,719 Times
Congrats on a sudden increase in resale value
I too think it could be a matter of faulty display than with kms reading.
ani_meher is offline   (1) Thanks Reply With Quote
Old 2nd August 2015, 11:57   #6
MunnabhaiMBBS's Avatar
Thanked: 587 Times
Default Re: Odometer suddenly started showing a lower reading!
Kippu,
Since it is not your fault, you do not owe an explanation to buyer / dealer. A clarification would suffice. However, get it diagnosed, repaired & restored before the sale. Also request you to share the post analysis observations for the benefit of other BHPians.
MunnabhaiMBBS is offline   Reply With Quote
Old 28th July 2017, 09:01   #7
Default Odometer (Weird Behavior) Chevrolet Beat Petrol
Hi Everyone,
I have this weird issue on my Chevrolet Beat odometer (2010 Model). Yesterday evening after a few kms drive, when I parked my car the odometer was showing 34617. But today when I started my car in the morning, the odometer was showing reading as 34615. Which is 2kms less than the previous one.
Can anyone suggest what has gone wrong with the car ?
Lately I have seen drop in the mileage, hence I was keeping an eye on the odometer reading for last few weeks. The car was filled with 15 litres petrol on 14-Jun-2017 @ odometer reading 34539, and it showed low fuel indication today.
Please advise.
hitman1980 is offline   Reply With Quote
Old 28th July 2017, 10:14   #8
hemanth.anand's Avatar
Thanked: 6,996 Times
Default Re: Odometer (Weird Behavior) Chevrolet Beat Petrol
Originally Posted by hitman1980 View Post
Hi Everyone,
Please advise.
Beat has a digital Odometer.
The low mileage, the low fuel warning are all connected to this faulty ODO-meter reading
Car electronics act weird and are always difficult to diagnose. In your case it can be anything from a Faulty odo memory chip or a bug in the ECU program. the Service centre guys with their OBD readers may be able to read if any error is registered
hemanth.anand is offline   (2) Thanks Reply With Quote
Highest reading in the odometer! Surprise The Indian Car Scene 602 18th April 2018 19:39
Odometer Reading: How to tell if it has been tampered with? nd81 Technical Stuff 58 8th September 2011 21:18
Mahindra Xylo : Odometer showing distance traveled with air-conditioner mmxylorider Technical Stuff 12 26th June 2011 19:14
SuperBike Trip Reading shows 866 while ODO Reading is 865 freakrz Superbikes & Imports 3 23rd June 2009 11:57
Logan Odometer reading correctness Sush Technical Stuff 13 24th May 2009 08:15
