Old 2nd September 2006, 17:55   #1
vRS
vRS's Avatar
While driving the other day my brake pedal became hard (was unable to press the brake pedal). Showed it to the dealer who scanned and said that there is a problem with the ABS and that he will try an 'clean' / change it if required. Need some help here :
1. At the time of ignition, I do not see the ABS indicator on the dash come on. Should this not light up for a couple of seconds ?
2. Is not the ABS unit sealed ? Can it be cleaned ?
3. Any ideas why this problem could have occured in just 15000 km or driving ?
Thanks.
Viky
vRS is offline   Reply With Quote
Old 2nd September 2006, 19:22   #2
Thanked: 11,081 Times
sounds more like a servo problem
Old 3rd September 2006, 06:28   #3
subbarp's Avatar
Thanked: 80 Times
Default Light should come on
Thanks.
Viky
(1) I am not sure of the way it works on RS, but on my corolla, the lights for ABS comes on for about 2 seconds and then go off when I start. So assuming it should work the same for you if all is well.
(2) & (3). No clues.
NOTE FROM SUPPORT TEAM: Kindly avoid quoting full post
subbarp is offline   Reply With Quote
Old 3rd September 2006, 12:51   #4
hey u sure ur garage guys just dint take a short cut method and somehow managed to disconenct the ABS warning lamp .. if they have lol u can sue them haha and get away with a Laura or somethin
Kinetik is offline   Reply With Quote
Old 3rd September 2006, 13:08   #5
PJSPEED's Avatar
Check the vacuum line for any damage.......Hope this helps
PJ
PJSPEED is offline   Reply With Quote
Old 3rd September 2006, 19:32   #6
dude .,,i dunno if this makes sense but if one or more of the solenoids in the ABS modulator is faulty , it would create a backpressure via the master cylinder to the brake booster and back to the pedal ..
maybe thats why ur brake pedal is becoming hard and ur ABS light is popping up..
do this drive test
1) Brake lightly while ur driving keep a light hand ont the steering and notice if the car pulls to a particular side and if u have notices reduced braking effect
2) Jam ur brakes hard @ managable speeds over some surface where u could loose traction like sand or mud and see if ur ABS is working,
does it have ESP / traction control ?
Old 11th September 2006, 15:13   #7
vRS
vRS's Avatar
Thanks for the inputs. The car is with the *** (pun intended) !!
I told them that that the brake pedal suddenly becomes hard and cannot be pressed. The *** said its an ABS problem...but when I asked why the ABS warning light did not show up on the dash.. they had no answers.
Old 14th September 2006, 22:53   #8
KS Motorsport's Avatar
Hello VRS,
Yes,the ABS unit cannot be cleaned...but ucan check the servo,just like Amjat said,but the ABS HAS to come on then then go off.Its a sensor continuty test that the ECM will do.Ask the****to show u the scann test to u.Or ask them to do the scann in front of u.I have had a few issue with the Skoda guys.Soon u will have a pulsating brake pedal,at about 120kmph..A big skoda problem.I dont want to scare u,just getting u prepared.
Let me know if i can be of any more help.
Karan
KS Motorsport is offline   Reply With Quote
Old 15th September 2006, 12:06   #9
vRS
vRS's Avatar
Thanks for the inputs Karan. I have got Skoda Auto involved and they intitally thought its the ECM since the EPC and Check Engine Electronics warning lights were also showing up. But now they are planning to change the ABS. It has taken them a week and they are still trying to figure.
Viky
Old 5th November 2006, 00:32   #10
PJSPEED's Avatar
Any update on this???????
PJ
Old 5th November 2006, 08:04   #11
nikkibike's Avatar
Thanks.
Viky
hard pedal is due to the mal function of booster assy I guess!! See whether the booster gets enough vaccum or it is defective!! Also, guess this ABS starts functioning only when the sensors give commands to the brake system..... when the sensors come across too many different parameters to process!!
Am not sure whether am right or wrong! Juz abit from my knowledge!!
nikkibike is offline   Reply With Quote
Old 5th November 2006, 19:47   #12
Octavia2's Avatar
Arrow
vRS,
Please ask them for the VAS error code and description it should be very clear and straight forward to get it from the logs of VAS when they do a ABS scan. I am still wondering why you got a CEL though.
Thanks,
-P.
Octavia2 is offline   Reply With Quote
Old 6th November 2006, 12:06   #13
vRS
vRS's Avatar
Octavia2,
Just to update, the issue has been resolved by changing the ABS Control Module ( cost Rs. 25,000+taxes). Seems that some water had gone into it.
Interestingly the problem had started a day after it came back from regular service. Wonder if it was due to water being sprayed while washing up after service. Anyone had such problems ?
Viky
Old 6th November 2006, 15:38   #14
Octavia2's Avatar
Viky,
ABS control module with water in it? Did you take your car in seriously heavy rains or something? If you have a doubt, and if they did replace the ABS control unit, please do check the VAS logs that reported the error that ABS was faulty. Most of these error codes can be reset using VAS and consecutive errors could be even because of some garbage stuck in your brakes or the like.
BTW, did you pay for the ABS control module? If yes, and you paid for the service you can ask them if they had used VAS to check if the car was okay prior to delivery - I am assuming that you did the paid service which was probably the 15k service. If yes, then I am sure they ran the diagnostic on your car prior to delivery; more so if you had given a specific complaint related to engine electronics and this would have created a log in VAS. You might want to tell them that this problem was not there before the service. If the log comes out okay, then it could be something that was a random occurance or something naughty that you did.
Thanks,
-P.
Old 7th November 2006, 12:36   #15
vRS
vRS's Avatar
Hi o2,
Your advise is valuable - in that i think that before the next service I should get the car scanned. As you know the Skoda service system is a mess and I had changed dealers for the service. Actually the car ran ok for 2 days after the service and so i dunno what happened.
Viky
Tata Indica Vista Aura ABS (EDIT: Now it is Aura Plus with ABS and Airbags) akhilesh51 The Indian Car Scene 141 28th September 2010 20:11
Can the functionality of ABS be simulated on Non-ABS cars? abhinav.s Technical Stuff 54 24th February 2010 14:51
swiftDz ZDi Vs verna SX Abs Vs fiesta sxi tdci abs Vs logan dlsx Vs indigo XL G-dicor dayaraamm Sedans 1 27th August 2008 14:22
Fusion + ABS or Baleno VXI or Accent Viva ABS? What to buy? Confused like anything.. sendu79 Sedans 47 3rd June 2006 20:21
