Old 24th April 2004, 16:16   #16
Awaiting Email Confirmation
well,,one simple solution that would apply to all cars is to remove the stooopid plastic wheel covers that come as standard on most cars,,or fit alloy wheels ,,since the key to preventing brake fade is ADEQUATE VENTILATION,,also there is a chemical spray that is available at good accessory shops which you just spray on discs/drums,,to remove dust
snoopy41 is offline   Reply With Quote
Old 24th April 2004, 22:14   #17
hehe just get some brembo's off bhushans car man
Kinetik is offline   Reply With Quote
Old 8th June 2006, 23:59   #18
humyum's Avatar
Thanked: 2,502 Times
u guys feel ikons brakes are pathetic.Try out my 800 or any other 800 for that matter u will know what brakes are.Rather than depend on the brake pedal u have to trust more in god while applying the brakes.Guys trust me i have been hating my 800 more since some days so much that i would not raise my eyebrow if someone were to break it into two
Old 10th May 2007, 13:43   #19
Can disc braked be fitted at the rear in Ikon 1.6? anyone tried it yet?
compenn is offline   Reply With Quote
Old 11th May 2007, 11:16   #20
^ Yes disc brakes can be fitted at the rear in the 1.6, but its complicated and a bit costly too.
-Absar
Absar is offline   Reply With Quote
Old 11th May 2007, 11:19   #21
@Absar
Did u get it fitted in your Ikon or some friend of yours? Any idea about the approximate cost?
Old 11th May 2007, 11:36   #22
shazikon's Avatar
Thanked: 19 Times
Rather than going for Disc breaks at the back, its better to go for slotted rotors with better brake pads. Changing the back drum breaks to discs will change the break force geometry in the car and may be dangerous..Ikon brakes are electronically distributed. Brake force is distributed to all four wheels at a particular ratio. changing the rear breaks may result in loss of braking rather than improving bracking.
shazikon is offline   Reply With Quote
Old 11th May 2007, 13:26   #23
@Shaz
The slotted rotors u mentioning, are they for the front or the back... cost of slotted rotors + brake pads?
Old 11th May 2007, 19:09   #24
Originally Posted by compenn View Post
@Absar
No, I haven't done it on my Ikon. Brakes are stock. The cost was around 40-45k for better front rotors & calipers + rear disc brake conversion. The person who told me this had said that he hadn't done it on any Ikon, and he wouldnt recommend doing it either, because of the fact that the Ikon's brakes are electronically distributed, also mentioned by shazikon.
-Absar
Old 14th May 2007, 23:38   #25
1100D's Avatar
Thanked: 2,503 Times
GTO's view about Brake fade being the main cause is pretty much it. Because I had noticed on my first set of Rotors and pads the car would have varying brake feel from a cold car to a warmer car (after a few kms). However the second set of rotors were far far better and I always have not gotten this answered that why were the original set so bad.
Ventilated Rotors, great suggestion. Where can we get them (for other cars as well )? Not looking at drilling holes in stock rotors, that will never give the desired results. Does Brembo Ferrodo etc have any presence in performance brakes area in India?
1100D is offline   Reply With Quote
Old 14th May 2007, 23:50   #26
kpzen's Avatar
Thanked: 1,655 Times
I feel there's lots of nose dip in Ikon while braking which also adds to the scary feel for the driver.
Yeah overall also the braking is also no good....But it has awwssum handling with min body roll..
Old 15th May 2007, 10:52   #27
Jaggu's Avatar
Thanked: 8,685 Times
ikon brake electronically adjusted?? i dont think so, its just hydrolic with booster and no electronics apart for brake pad wear indicator and fluid level indicator.
i had issues with first set of pads, but things improved tremendously after i changed the pads to new OE and yes i used to run around without hub caps so might have helped in cooling
Old 16th May 2007, 02:28   #28
1100D's Avatar
Me too!!
But I had alloys from day 1 so it wasn't wheelcaps or something. The first set was bad. (not eh second set is awesome, but do-able)
Old 5th September 2007, 12:26   #29
I understand, the front dics bites harder than the rear drums due to front-rear bias. Does any ikon owner feels the brakes are too bias on the front? I feel mine is. I tried braking hard and examined the skid marks. I don't see skid marks for the rear tyres. Note, this is done on my backyard at slow speed. Well, I tried this because I feel the ikon brakes quiet poor and only the front seems to be working.
kaynmantis is offline   Reply With Quote
Old 4th March 2009, 12:17   #30
Default Bad Braking - Ikon 1.6 Zxi
Hey Guys,
I have started using my dad's 2002 1.6 ikon. Having a lot of trouble getting used to the engine. Which in turn is affecting engine braking capabilities.
The car seems to want to over rev by itself. Whether on the highway or city, if I push the car a little and try to shift gears the the RPM just keeps increasing when I press the clutch. Not sure if this is normal.
We had some issues with speed sensor (or so they said). The RPM would just drop when you pressed the clutch and engine switch off at any speed!! That was a crazy time. They have replaced the sensor. But this problem persists.
Not sure if this is normal in the Ikon. I am more used to the old city. Trying to get the car to stop at higher speeds is a scary affair since i'm completely depended on brakes (and they arent too great either). Had the wheel lock up a couple of times.
Help!!!
BlackWagon is offline   Reply With Quote
5009 KMS-A'bad-Calicut-Bangy-Hyd-Aur'Bad-A'Bad-Report ramkya1 Travelogues 48 4th August 2010 00:04
A bad bad bad night for me.... Ranjan Sharma Street Experiences 38 8th April 2010 12:02
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
My accident - Bad brakes, bad rain, bad luck... vezj420 Street Experiences 41 22nd May 2007 10:49
Safari 2.0 TD - Bad Brakes & Steering Play abhishek2 Technical Stuff 4 19th February 2006 10:49
