Old 4th July 2012, 10:51   #46
Thanked: 1,439 Times
Default Re: the Ikon.. bad brakes
I too was worried about the braking of our Ikon (it's a ten year old car which had hardly touched 40k), but after replacing the brake fluid and replacing the brake pads, the performance has improved noticeably. Next time I get the chance (most likely after the rains), I shall try and get the lines fixed too.
Old 4th July 2012, 10:55   #47
Automaton's Avatar
Thanked: 181 Times
Originally Posted by Catalyst_delhi View Post
I tightened the vacuum lines from the block to the booster and i found by brakes much much sharper. Also check the fluid , rotor ,brake pads. The biggest driver was the vacuum lines.
Thanks, as a first step, he could try tightening the vacuum lines, he has gone through the fluids/pads/rotors routine with the service center.
Still looking for a solution in the aftermarket space.
Automaton is offline   (1) Thanks Reply With Quote
Old 4th July 2012, 11:07   #48
johnjojo08's Avatar
Thanked: 28 Times
Changing the break pads to after market ones helped my 1.6 ikon.
johnjojo08 is offline   Reply With Quote
Old 4th July 2012, 11:16   #49
Automaton's Avatar
Thanked: 181 Times
Thanks. Any particular brand?
Automaton is offline   Reply With Quote
Old 4th July 2012, 11:25   #50
quakerme's Avatar
Thanked: 56 Times
Thank God i found this thread alive...I was also in a look out for a solution of the same in my ikon tdci (i feel the breaking is a bit shallow) is there a way to fit ABS on ikon tdci? have someone tried it?
quakerme is offline   Reply With Quote
Old 4th July 2012, 18:20   #51
johnjojo08's Avatar
Thanked: 28 Times
Don't remember the exact brand. One workshop near my hometown suggested it, as they know the breaks in ikon is very bad. They told me they have used it in many ikons. Also they had the stock of it. Now I sold my ikon 6 months back and using fiesta now. A reputed workshop which services ford cars can help you in this regard.
Old 4th July 2012, 20:20   #52
Thanked: 716 Times
I am being told by a mechanic that nothing works like the ford original booster.
ramzsys is offline   (1) Thanks Reply With Quote
Old 4th July 2012, 22:40   #53
arunkumars's Avatar
Experts please comment.
Can we replace the disks, calipers and pads in an Ikon with the ones in a Fiesta for better breaking.
arunkumars is offline   Reply With Quote
Old 4th July 2012, 23:38   #54
Catalyst_delhi's Avatar
Thanked: 149 Times
You can but it is not recommended as you will not have a person who can do a complete job. Brakes are too crucial to be left to an FNG. I can send you the fiesta manual and ikon manual , you should be able to figure it out.
Catalyst_delhi is offline   (1) Thanks Reply With Quote
5009 KMS-A'bad-Calicut-Bangy-Hyd-Aur'Bad-A'Bad-Report ramkya1 Travelogues 48 4th August 2010 00:04
A bad bad bad night for me.... Ranjan Sharma Street Experiences 38 8th April 2010 12:02
Retarder in Volvo B7R buses (air-brakes / jake brakes) sfilinto Commercial Vehicles 12 30th March 2010 00:55
My accident - Bad brakes, bad rain, bad luck... vezj420 Street Experiences 41 22nd May 2007 10:49
Safari 2.0 TD - Bad Brakes & Steering Play abhishek2 Technical Stuff 4 19th February 2006 10:49
