Old 16th August 2015, 09:26   #1
kunaldhami's Avatar
Thanked: 62 Times
Default Door Lock not working - Repair or replace?
I have a Skoda Fabia Diesels Classic which has only key operable door lock, no remote lock.
Now, its not working. When I insert the key & turn it completes the whole circle but it does not open the door.
Went to my mechanic and he said you need to change all locks at dealership.
Now while searching I found couple of videos and this
http://www.aliexpress.com/item/OEM-6...063905713.html
Now please help me.
Will this kit solve my problem?
if yes, has anyone tried this?
or I will have to go to Skoda A.S.S and burn approx 10K for changing all locks..
kunaldhami is offline   (1) Thanks Reply With Quote
Old 16th August 2015, 10:54   #2
phamilyman's Avatar
Thanked: 3,526 Times
Default re: Door Lock not working - Repair or replace?
Originally Posted by kunaldhami View Post
Now please help me.
Bhai,
You can try and check whether its the lock? In my swift i just replaced the linkage which was the problem (and not the lock). Costed me half an hour and just 2k. Changing all locks does not compute. Can you expand on his diagnosis?
phamilyman is offline   (1) Thanks Reply With Quote
Old 16th August 2015, 11:09   #3
Thanked: 1,440 Times
Changing all the locks for one malfunctioning lock doesn't make sense, unless you have to change the cylinder. As phamilyman said, please diagnose it to find out if you have to replace the cylinder - in which case you may want to change all the locks (including the boot and the ignition), or keep a separate key for the new lock (not exactly bad, since it provides a tad more security!).
honeybee is offline   (1) Thanks Reply With Quote
Old 2nd October 2015, 15:37   #4
kunaldhami's Avatar
Thanked: 62 Times
Default Re: Door Lock not working - Repair or replace?
UPDATE :
Been to Skoda dealership and they said you need to change all locks..
Found one lock repair guy and will be taking my car to him next week to get it checked..
kunaldhami is offline   Reply With Quote
Old 28th October 2015, 16:42   #5
kunaldhami's Avatar
Thanked: 62 Times
Finally been to that lock repair guy and he repaired the lock for just 700rs.
This is his contact Details
Imityaz - 9327929234
Location
In the lane after Rushabh Petrolpump & 24 carat sweetshop, Ring Road, Surat
Which Steering lock and Gear lock to buy? willy Modifications & Accessories 73 3rd September 2015 12:17
Volvo S60 instrument console failed. Repair or replace? Volvo to replace under Goodwill! jfxavier Technical Stuff 26 13th January 2015 10:49
Security : Gear lock, steering lock venkatrx Modifications & Accessories 11 25th January 2011 18:04
Superbike Security Systems - Disc Lock / Chain Lock / Alarm Systems gsferrari Superbikes & Imports 3 3rd July 2009 01:45
Door Lock Malfunction in Swift VXI lambuhere1 Technical Stuff 14 6th June 2008 17:33
