Thread Tools
Old 17th March 2004, 23:30   #1 (permalink)
What if ur driving and suddenly u see flames coming out of ur engine area. u dont have a fire extinguisher or anything in ur car. how can we deal with fire in such a situation?
__________________
Some people drive cars. I drive the Palio.
amit is offline   Reply With Quote
Old 18th March 2004, 04:33   #2 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Switch off
Park
Pop open hood (for hassle free opening for the fire dept etc)
Run!!
Ofcourse if it was WRC the answer would be - drive faster!!
I guess the answer would also alter depending on what i felt the source of the fire was.... i guess it depends on the situation.
Cheers.
__________________
The memory of you will ride by our side forever.
Rehaan is online now   Reply With Quote
Old 18th March 2004, 07:20   #3 (permalink)
As you say that you do not have F extingusiher , there is nothing much you can do other than park , swithc off , and open the hood and then watch . If you have a cloth and water , jut make it wet and you can try to put in in the fire. ie trying to cut off the oxygen. But you cant then stand little away from the car , as there are chances that the fuel might explode
SO it is better to have a Fire Extinguisher !
toyota is offline   Reply With Quote
Old 18th March 2004, 12:58   #4 (permalink)
Shan2nu's Avatar
So far, i've seen only two cars with a completely smoking bonnet. The first one was an opel Astra just outside the H-D Bypass, the dude must have really given it the go!!
The other was a Hyundai Accent in Blore.
In both cases, the owners we're standing next to the car surrounded by a mob who had no idea what was going on.
"Ofcourse if it was WRC the answer would be - drive faster!!" - Rehaan, that was neat.
Regards...
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Shan2nu is online now   Reply With Quote
Old 18th March 2004, 14:40   #5 (permalink)
RJK
RJK's Avatar
switch off the car & run for life
__________________
'94 Mazda MX-6
My first car with my own money.
RJK is offline   Reply With Quote
Old 18th March 2004, 18:08   #6 (permalink)
v12
v12's Avatar
"Fire in the car. Run Run Run. "
I guess best option wud be to switch it off and pour water over the fire.
__________________
Enfield Cafe Racer completed. Yamaha Cafe Racer started.
v12 is offline   Reply With Quote
Old 19th March 2004, 01:01   #7 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Guys,
I didnt suggest water as sometimes it may be an electrical short circuit that has caused the fire. Dont forget about the immense ampereage of the battery!!
cheers
Rehaan
__________________
Old 19th March 2004, 07:25   #8 (permalink)
As rehaan said water may not be the right option
Just step away and if the fire is little less then you can try to put it off with sand !
Old 19th March 2004, 11:18   #9 (permalink)
Super-Admin
I never ever drive my Jeep without a Fire extinguisher. It is located right below the drivers seat, and I made sure I bought one which is certified by all the authorities concerned.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 19th March 2004, 11:24   #10 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Once my friends 1966 350cc enfield had some sort of short circuit in the rain and all the wiring just glowed red hot and burst into flames!! luckily he had just got off the bike!
Another time i was woken up at 6am by the watchman coz there was smoke comming out from our sumo's bonet. Another short circuit, and it wasnt even raining or anything. The wire responsible was totally melted, and the bonnet had got so hot it was not possible to touch it to open it.
These are examples of how much punch an automobile battery carries, just so that u guys know!
cheers
__________________
Old 19th March 2004, 13:11   #11 (permalink)
Super-Admin
Originally Posted by [b
Quote[/b] ] Another short circuit, and it wasnt even raining or anything. The wire responsible was totally melted,
Rehaan, I suspect rodents eating into your sumo's wiring system
__________________
Old 19th March 2004, 14:22   #12 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Highly likely GTO....
or it also could have been a wire that had got loose from the harness and either got chopped up in the fan or burnt on the hot engine or just grinded around so much that the insulator got worn off!
cheers.
Rehaan
__________________
Old 26th April 2004, 01:58   #13 (permalink)
aadix's Avatar
hey rehaan
if the engine is off, how can the wiring burn???
and gto which fire extingusher did you buy?
__________________
"live to ride,ride to eliminate"
aadix is offline   Reply With Quote
Old 26th April 2004, 02:12   #14 (permalink)
Quote[/b] (Shan2nu @ Mar. 18 2004,11:28)]So far, i've seen only two cars with a completely smoking bonnet. The first one was an opel Astra just outside the H-D
hey i've seen an opel astra burn into flames at the lokhandwala backroad ..it was a ghastly site.// so u think there maybe a manufactoring/design defect in the car itself ?
__________________
Shalom
Kinetik is offline   Reply With Quote
Old 26th April 2004, 03:56   #15 (permalink)
Team-BHP Moderator
Rehaan's Avatar
Quote[/b] (aadix @ April 26 2004,00:28)]hey rehaan
Hey Aadix,
Simply put -
The way wiring in a car is connected is that the negative (black) terminal of the battery is connected directly to the cars entire bodyshell (and hence all metal parts in contact).
The positive terminal is connected by wires to the individual electric devices, ie alternator, stereo, ecu, headlights, etc.
Now if one of those insulated (+ve) wires happens to make electrical contact with any part of the cars body (-ve) a short circuit will result.
For example as GTO said, a rat might have eaten the insulation off a positive wire and it might have then touched a metal bodypart, creating a short circuit.
cheers
Rehaan
__________________
Thread Tools
Hyundai Plant on fire ronnyquest The Indian Car Scene!! 6 3rd September 2008 23:54
Scorpio catches fire bigman Shifting gears 36 9th July 2008 14:18
Car on Fire bill1182 Technical Stuff 2 18th September 2007 20:45
fire extingushers in car gigy Technical Stuff 3 13th November 2006 17:38
L- Board Surprise Shifting gears 10 5th July 2005 16:54
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
