| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) | |
| BHPian | Quote:
One mistake many inexperienced drivers do is put the car in 5th gear asap. And when the speed goes down, they stand on the accelerator, instead of downshifting. This is the easiest way to reduce your mileage and engine life ![]()
__________________ "When the going gets TOUGH.....Great ones PARTY" | |
| | #17 (permalink) | |
| BHPian Join Date: Feb 2004 Location: New Delhi
| Quote:
To me FE is a function of accelerator and speed... rather that the gear (gear is the reason for speed) Take a situation... you are doing 40km/h and you have space on the road to drive at 80km/h. Now you have 2 ways to do it. 1) First approach 40-50 in 3rd 50-65 in 4th 65-80 in 5th 2) Second approach 40-80 in 5th (as you put 5th asap) The problems in the second approach when compared to the first:- 1) you take more time (you are left with less time to cruise on the more efficient rpm) 2) you press more on the accelerator i.e pumping in more fuel 3) you strain your engine because you pump in more fuel than it wants at that rpm. 4) you even increase emissions *these are no scientific study results...
__________________ Č╠╣€€Я$ $£Қ Last edited by SLK : 7th September 2006 at 14:50. | |
| | #18 (permalink) |
| Team-BHP Support ![]() | Ever wondered how to get the most out of your engine's performance? Or, ever admired that guy who shot past in his car like a bat out of bellfry - and then you tried the same "performance" shifting in your car only to end up a major embarrassment with your engine shutting down?!! Well then, as being a refugee under the former point, I thought we should discuss this - the Optimal Gear Shift Points. Check out this link http://www.datsuns.com/Tech/whentoshift.htm that explains the finer points of shifting. To contribute to this discussion, my gear shifts on my Swift are designed to keep the car moving swiftly (pun somewhat unintended) at any point of time: 1st gear is changed at 1500rpm/15 kmph 2nd gear at 1500 rpm/25 kmph 3rd gear at ~1650 rpm/35 kmph 4th gear at ~ 1800 rpm/45 kmph 5th gear at ~ 2000 rpm/ > 50 kmph On my earlier 1.6 Ikon is an altogether different story with the gear shifts very closely resembling the ones in the article ![]()
__________________ If you lose your temper, you’ve lost the argument |
| | #19 (permalink) |
| Senior - BHPian | WOW nice. I usually do short shift or over burn when doing any drag etc stuff. Mostly short shifting. This may be helpful. BTW. if i am unable to understand i know that you know whats in that article ![]() Relp Needed!!! I was seeing at the swift gear ration from its website: Gear ratios : 1st 3.545 2nd 1.904 3rd 1.280 4th 0.966 5th 0.757 How to convert into the ratios in the artcle 3:1 2:1 ?
__________________ tinypic.com/player.php?v=35mo01l&s=4 Last edited by adya33 : 10th October 2006 at 09:31. |
| | #20 (permalink) |
| Newbie Join Date: Oct 2006 Location: Pune
| Originally Postedby SLK Well maruti recommends... 1st to 2nd - 10 km/h 2nd to 3rd - 20 km/h 3rd to 4th - 30 km/h 4th to 5th - 40km/h ~~~~~ : this seems to work nearly with my second hand M800;1st to 2nd - 10kmph 2nd to 3rd - 25kmph 3rd to 4th - 40kmph 4th to 5th - <I wish I had this one> Grrr....the car wont even take me to 60kmph in the 4th gear .... GRRR, I hate it, ![]() |
| | #21 (permalink) | |
| Senior - BHPian | Quote:
Even on my Pulsar, I always upshift to 5th at about 50 KM/H and in the cars I always shift to 5th at about 60 KM/H. In all the Maruti cars that I've driven, I the gear knocks if I shift to 5th at 40 KM/H. I'm wondering why Maruti is giving these kind of stupid infos just for the sake of FE ?
__________________ Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly. | |
| | #22 (permalink) |
| BHPian | My experience with mileage has been that it does not depend on what rpm i upshift of downshift but how often i do it. in normal city driving in a city like bangalore I hardly go upto fourth gear, but continue driving for as long as I can in third even if I am doing 60kmph because I know that the moment I move into fourth either something will dart across or I would have reached a traffic signal. Another advantage of this that you can make use of engine braking when you need to stop at a signal. I used to drive a Palio 1.2 earlier and in the city thast thing used to give me 12kmpl eay with normal driving when everybody used to crib about its FE. The reason I drive this way is that in most of the new vehicles today both of 4th & 5th are overdrive gears. Logically speaking I should get better mileage when in 4th but I dont..
__________________ One piece at a time. |
| | #23 (permalink) |
| BHPian Join Date: Aug 2005 Location: Bangalore
| I have a question... please excuse if it sounds stupid! If I hit a high rpm let us say 2.5-2.8K in 2nd or 3rd gear and reached a speed of 55-60Kph, then instead of going to 4th and then to 5th, can I jump directly to 5th? Since the engine has reached a higher rpm and the vehicle is also moving at a higher speed, will it not help FE if we move to 5th and save all that clutch usage and acceleration/decceleration involved in 4th? Also are there any -ve impacts with this approach? I've never tried this, but this thought crossed my mind while reading this post. What say experts? Last edited by madhav : 11th October 2006 at 09:59. |
| | #25 (permalink) | |
My knowledge is that downshift can be done in the way you've written.....BUT I still have serious doubts regarding upshifting.
| | #26 (permalink) | |
| BHPian Join Date: Dec 2005 Location: Chennai
| Quote:
Still experts' opinion matters.
__________________ Have a pleasant and safe driving | |
| | #27 (permalink) |
| BHPian | I do this normally on the highways when I touch about 70 in 3rd and jump directly to fifth. Have had no problems so far. But like I said earlier make sure you know that the engine can take the load with no effort.
| | #28 (permalink) | |
| Senior - BHPian | Used to do the same with my Esteem and no issues at all. Follow the same in my Safari & Scorpio as well and no problems whatsoever. A little bird told me (on whose advice I started this practice) that it makes a difference to the FE. I have never really checked... Quote:
| | #29 (permalink) | |
I dont skip any gears and go through all of them religiously even if i know i can skip 1-2 gear and go directly to a top gear, which really helps me in building up the momentum that i need for the top gear Another major FE hamperers are using the clutch as a rest and though not related to FE but, lots of people rest their hands on the gear knob and such long time habit can result in gear ratios getting messed up...so please dont use either the clutch or the GK for resting your body parts![]()
__________________ [b][i]The nail that sticks out gets hammered !!! | |
| | #30 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Earlier I used to follow sequential upshift of gears......but after grooving I used to ride from 1st to 3rd & 2nd to 4th........after giving initial acceleration say up to 10-15 I used to shift to 3rd & move on fast especially after standstill.......same with 2nd at 40 to 4th.........I started this practice & found that using less gear shift gives relief in city driving........although not observed FE.............. Enjoy.......... Last edited by finetuning : 14th October 2006 at 13:33. |
| Thread Tools | |
Similar Threads | ||||
| Santro gear shifts suddenly into neutral | nura | Technical Stuff | 18 | 11th August 2008 14:21 |
| Swift 2nd Gear Problem EDIT: Now first gear problem | BUSA | Technical Stuff | 81 | 10th February 2008 11:58 |
| Toyota launch of compact hatchback shifts up a gear | navdeep | The Indian Car Scene!! | 9 | 13th April 2007 11:44 |
| Paddle shifts on Indian cars - will it work? | Shan2nu | The Indian Car Scene!! | 45 | 23rd August 2006 14:02 |
| VW Passat 3.6 V6 (with Paddle Shifts) | amit | Test-Drives & Initial Ownership Reports | 19 | 21st February 2006 11:15 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
