Thread Tools
Old 20th April 2007, 03:20   #61 (permalink)
Shan2nu's Avatar
I'm sorry, but according to you, torque is work done.
Now, W = F s cos theta. And F = m a.
a is acceleration. As we all know, acceleration is a factor of both time and movement. Time since a = (v-u)/t, and movement, since if you have a finite value for a, some sort of displacement has occured.
So when you apply torque to a rusted bolt, whats accelerating? Or are you trying to prove that torque is not being produced in this case? (which you can't)
Torque is not acceleration.....but it can be used to create acceleration.
But, the fact remains that torque can exist without time or movement.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 20th April 2007, 03:40   #62 (permalink)
SLK
SLK's Avatar
Originally Posted by The Wolf View Post
V1p3r: Dude torque is the measure of a force's tendency to produce torsion and rotation about an axis, irrespective of howmuch rotation it is causing!!!
Well, torque is useless without rotation!... does NOT mean there is NO torque possible without rotation.
You don't have rotation your torque is useless!. AND if you have rotation... what matters is how much rotation!.... AND if you have torque and rotation (the only useful combination).... then you are actually talking about power (and thats what I said).
__________________
Č╠╣€€Я$
$£Қ
SLK is online now   Reply With Quote
Old 20th April 2007, 03:47   #63 (permalink)
The Wolf's Avatar
LOL!!! Dude can you pls tell me what rotation are you speaking about?? Is it the crank or the wheels???
__________________
I cried coz I had no turbo, till I met a man who had no VTEC!!!
The Wolf is offline   Reply With Quote
Old 20th April 2007, 03:48   #64 (permalink)
Shan2nu's Avatar
Exactly, what i said. You don't need RPM to have torque but you need it to have power.
Torque is produced at "19000rpm" in a F1 engine.......as well as at "0rpm" when you're stuck with a rusted bolt.
Shan2nu
__________________
Old 20th April 2007, 03:52   #65 (permalink)
SLK
SLK's Avatar
LOL... since its all measured at the crank .... then we talk about the crank.
BUT since Shan2nu said.. its not R P M!!!... but any R would do... I used the 'R' to be on the safer side!
__________________
Č╠╣€€Я$
$£Қ
Old 20th April 2007, 03:53   #66 (permalink)
The Wolf's Avatar
Shan2nu, I think SLK and v1p3r are speaking about wheel rpms while we are speaking about crank rpms which is where the torque is measured at!!!
__________________
Old 20th April 2007, 04:05   #67 (permalink)
Shan2nu's Avatar
Ok lemme clear things out.
Torque can be produced at "0rpm" (my point which is true).........but Torque produced at 0rpm is useless (SLK's point which is also true).
Hope that helped.
Shan2nu
__________________
Old 20th April 2007, 04:15   #68 (permalink)
The Wolf's Avatar
Slk, well then if the crank isnt moving does it mean the torque isnt being produced??? Just put a lighter crank and you will know if there is any torque being produced there at all....you get my point??
__________________
Old 20th April 2007, 04:21   #69 (permalink)
v1p3r's Avatar
Torque is not being produced. Just like when you hold a 100 kg load in your arms, they may ache, but you are not doing any work.
Torque is a function of acceleration. It can also be defined as the rate of change of angular momentum, ie T = dL/dt . If you look at that, you will realise that you CANNOT have torque without a relation to time and space. In fact, in physics, you cannot have ANYTHING without a relation to time and space.
I suggest you look at this definition. It will help you out.
__________________
I've lost my phone. Please PM me your phone number if I'm on your contact list.
Old 20th April 2007, 04:30   #70 (permalink)
SLK
SLK's Avatar
Ahh, I get your point .... but... its not about that .. the torque is inadequate to move a crank. It was just about the fact.. that if its not rotating... its no good use... you can't move your car an inch.
the same 'x' amount of toque at 'y' rpm will help you move your car at some speed.... and that same 'x' torque at '2y' rpm would give more speed.... and the same 'x' torque at 0 rpm won't give you anything. (why is it at 0 rpm?... coz there is an opposite force not letting you move)
Its all theory ... lets not put lighter cranks!
__________________
Č╠╣€€Я$
$£Қ
Old 20th April 2007, 04:53   #71 (permalink)
The Wolf's Avatar
SLK, aaah now you are speaking the same language as me and shan2nu... The word "inadequate" was what I was looking for from you!
Ok, I guess its time to take this thread beyond "Torque"!!! LOLzzzz...
__________________
Old 20th April 2007, 04:56   #72 (permalink)
Shan2nu's Avatar
Here's something from the same page.
"Steam engines and electric motors tend to produce maximum torque close to zero rpm, with the torque diminishing as rotational speed rises (due to increasing friction and other constraints). Therefore, these types of engines usually have quite different types of drivetrains from internal combustion engines."
And here's more (similar to what i explained)
"Torque is a twisting force applied to an object, like a wheel or a crankshaft. Note that motion is not required for torque to exist! If you stand on a lug wrench that is on a frozen lug bolt, you are applying a torque to that bolt even though there may be no movement. For our purposes, we will consider that torque is measured in pounds-force feet (lbf-ft) meaning the equivalent of a given force, in pounds, acting on the end of a lever of length in feet. For example, standing with 180 pounds body weight on a lug wrench one foot long yields 180 lbf-ft of torque. A child of 90 pounds standing on a two-foot lug wrench applies the same torque. "
Source - Torque and Power
Torque is force * distance where force is the pessure exerted on the spanner and the distance is the lenght of the spanner.
You're getting confused between existance of torque at 0rpm and it's use at 0rpm.
Shan2nu
__________________
Old 20th April 2007, 09:25   #73 (permalink)
^^ For n00bs like me...can you give examples like what Shan2nu gave (about the spanner and the nut)..thats helps non-techie nuts like us understand and learn a little what the hell you guys are talking about..
OT: I started reading this thread hoping that i would learn to shift gears in a correct manner by seeing the title (i am very n00b driver)...but it looks like I can give a Physics graduation exam with all this technology...in a way its good, but would be better with good plain vanilla examples
kalpeshc is online now   Reply With Quote
Old 20th April 2007, 11:06   #74 (permalink)
Shan2nu's Avatar
To begin with, you can follow the shift points recomended by the company. Then you can start improvising, based on your performance requirements.
Shan2nu
__________________
Old 29th May 2007, 09:51   #75 (permalink)
vid6639's Avatar
I'd like to know how difficult it is to sown shift to 1st at really slow speeds.
Usually there are a few speedbreakers that one needs to negotiate in 1st gear. While approaching the hump at a really slow speed, many a times the car refuses to slot into 1st. I generally have to completely stop the car shift to 1st then go over. shifting to 1st even when the car is really slow just about to stop is not possible.
Also, how does one know if the synchro rings are worn out?
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Thread Tools
Santro gear shifts suddenly into neutral nura Technical Stuff 18 11th August 2008 14:21
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 81 10th February 2008 11:58
Toyota launch of compact hatchback shifts up a gear navdeep The Indian Car Scene!! 9 13th April 2007 11:44
Paddle shifts on Indian cars - will it work? Shan2nu The Indian Car Scene!! 45 23rd August 2006 14:02
VW Passat 3.6 V6 (with Paddle Shifts) amit Test-Drives & Initial Ownership Reports 19 21st February 2006 11:15
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
