| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Aug 2006 Location: Mumbai
| I have got a Matiz (SD - 2000 make) recently. The first thing I have done is change the stock tyres from 145/13" to 155/13" (both with 70 profile - Swapped from my 2001 Santro as I am selling it off). Now I am facing an issue of under steering. I am not very sure whether the issue was there before the tyre change or not but the under steer is really bad. I was about to crash into a road divider when I took a turn at 60KMPH. Is this a common thing with Matiz? (I seriously hope it is not!) Please advice. Also, the pick up is really bad, especially with the AC ON. Any quick and low cost ways to enhance the pick up at low speeds?? Looking for your advice!
__________________ Stay Hungry. Stay Foolish. |
| | #2 (permalink) |
| BHPian Join Date: Aug 2006 Location: Bangalore
| Matiz's low-end torque isn't too great anyway. On top of it you have put a tyre which is bigger. As expected, this has brought down the performance. Some quick suggestions: -- Clean air filter or get a new one. Isn't pretty inexpensive. -- Get injector nozzles checked. -- If there isn't much life left in the tyres, get new ones. Expensive suggestion, isnt it ![]() -- For the understeer: Get you steering checked. I have never seen anything of this sort. My matiz (non-PS) steering is pretty precise. -- BTW, does the understeer only occur on one side or is it both sides. If it does so only on one side, it might be an alignment issue or may be because of tyres with uneven wear (one is new, other in jaded) on the front wheels. |
| | #4 (permalink) |
| BHPian Join Date: Apr 2004 Location: Mumbai
| matiz doesnt understeer that badly.. especially with the strut braces which come standard on it..like sukhoi mentioned get the tyres checked/rotated/replaced.. and alignment done...
__________________ Shalom |
| | #5 (permalink) |
| Distinguished - BHPian ![]() | The Matiz is a very good handler if you ask me. i've followed a Matiz in my Vtec, entering a corner at close to 110kmph. I was shocked to see the car hold on so well, to it's line. I've a feeling you've got suspension related issues. FWD cars are prone to understeer but not at 60kmph and definately not on a Matiz. Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE |
| | #6 (permalink) |
| Senior - BHPian Join Date: Aug 2006 Location: Pune
| As a matiz owner I too can say that have never faced understeer issues, I face a similar problem but I think it is oversteer[I am really getting confused between oversteer and understeer]I feel since I have upsized the tyres on my matiz to the same old santro specifications[A Team-bhp member has already said that following problem caused due to wrong upsizing]. The problem I face is the moment I hit a pothole at speeds of say 60kmph + the car just veers sideways completely without me doing anything with the steering[real scary nearly hitting divider], and a car which is supposed to go straight turns towards the side automatically. Last edited by rahul_intlad : 29th October 2006 at 19:43. |
| | #7 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE | |
| | #11 (permalink) | |
| Quote:
I wish you are right.. I have got the suspension changed immediately (as it was pretty bad - Only the springs / shock absorbers). Also, got the air filter cleaned and injectors cleaned. But, the problem is still on (Mine is a non powered steering). I have been experimenting alot about how to do away with the problem (inexpensive wasy and the only solution I found is that I switch to a lower gear (third in most cases) at a tight corner and I am able to hold the baby in place?? Now I am able to make a turn even at 80 KMPH. I know that I am missing out on some physics/auto mechanics but would be delighted to get enlightened!Yes, when I know the roads too well, I add up a slight handbreak action and see the car drift away (not the typical Tokyo drift but good enough to make you smile!). The only problem is that hand break locks up and I am unable to set the car in normal motion with out loosing speed after the corner. I guess I need more practice!! Also, I think that the best way to practice this drifting thing is at a round about (deserted one with less friction, rainy days / smoother gravel) and keep going round and round at 2nd or 3rd gear with continuous hand break adjustment. What say pros??
__________________ Stay Hungry. Stay Foolish. | |
| | #12 (permalink) |
| Newbie Join Date: Oct 2006 Location: New Delhi
| Hey as a Matiz owner myself also (SG-2000) i have not faced this problems while negotiating curves at 100+ on stock tyres. I would go with Kinetic, that you should get your steering rack checked.
__________________ Speedme _______________________ Live Free Die well..... |
| | #13 (permalink) |
| Distinguished - BHPian ![]() | Maybe it's just your driving style that makes the car understeer. Like you mentioned, using the right gear is important as far as cornering goes. Try this for a change. Fill the front tyre with 2 psi more air than the rear ones. That did a good deal to the way the Vtec took corners. Since these are FF cars, the front tyres experience a lot more tyre flex while braking (due to weight distribution and weight transfer), increasing the psi will make the sidewalls stiffer and help corner with better stability. Shan2nu
| | #14 (permalink) | |
| Quote:
To start with.. It is a WOW.. 100 KPMH+ on turns.. U started to make me feel like a child:( Guys, Is it normal that people can take turns in India at 100+?? To make it more clear, let us say I am driving on a straight city road, at a junction I need to go left and then take a left at the same speed. Spare me on my ignorance and driving capabilities but is it casual to make such turns at such speeds?? Coming back to the main topic, got the steering rack checked.. It seems to be totally normal.
| | #15 (permalink) | |
| Quote:
Yes, I will alter the tyre pressure as u suggested this time! Thanks for the advice! U r expert voice on speeds at which we take turns (new thread?) will be good to read
« HP Power does better than what i expected!
Cranking the car when the engine IS currently running - What happens? »
| Thread Tools | |
Similar Threads | ||||
| Electric Power Steering Vs. Hydraulic Power Steering | joseph5600 | Technical Stuff | 3 | 19th November 2007 19:56 |
| Maruti Esteem - Non Power Steering to Power Steering | udit78 | Modifications & Accessories | 9 | 1st October 2007 16:27 |
| Matiz | raj_sh_us | Technical Stuff | 8 | 5th June 2007 23:53 |
| New Matiz | amit | The International Automotive Scene | 13 | 3rd June 2006 12:57 |
| How about w-matiz or e-matiz | Gtea | Modifications & Accessories | 38 | 3rd February 2006 01:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
