Old 11th May 2004, 23:57   #1
Thanked: 9,721 Times
Am off to Penang on work. Might get "stuck" in singapore ovr the weekend, thought I might go hunting for a set of good spark plugs + k+n air filter
any recommendations on spark plugs - also where to look for parts in Singapore ?
Old 12th May 2004, 00:23   #2
Domnic's Avatar
Arrow
Pick up splitfire plug leads for your car. Also plugs the HKS Iridium is pretty good. Filters are plenty just tell them the model and they will give you one. Direct fit into the oem box. Else get an oval tapered or round one for custom fitting which will yeild more power and better looks under the hood .
cheers
dom
Domnic is offline   Reply With Quote
Old 12th May 2004, 02:04   #3
Thanked: 89,226 Times
Dom,
I have someone really close going to the States soon. I can ask them to pick up any mods for the Vtec.
Quick question, and I know its a long shot. My warranty will be cancelled if I upgrade to after-market sparks, exhaust and a cold air intake?
Old 12th May 2004, 12:47   #4
Rtech's Avatar
Thanked: 212 Times
Originally Posted by [b
Quote[/b] ]My warranty will be cancelled if I upgrade to after-market sparks, exhaust and a cold air intake?
If you change your exhaust, I'm sure thats gonna violate your warranty, but spark plugs?? no way. 50/50 on the intake though, depends on how nice the dealers r!
Old 21st May 2004, 10:44   #5
In order to save you guys some time - did some research on spark plugs for the vtec. The Iridium ones that fit are:
Denso IK 16
NGK IFR5J11
Need to find a place in Singapore (and the time) to pick them up - anyone know where ? Also do leads really make a difference ?
Old 22nd May 2004, 08:01   #6
Rehaan's Avatar
Thanked: 22,586 Times
Hey Ajmat,
I have some issues with changing sparkplugs to splitfires etc etc....iridium im not sure about if there is a downside...but do some solid unbiased research before making the switch.
Simply put, the leads do make a difference!
cya
R
Iridium spark plugs shazikon Modifications & Accessories 67 1st July 2015 15:17
Pulstar plugs! Are the spark plugs obsolete? Is it a scam? Sankar Technical Stuff 8 4th October 2009 01:58
NGK Spark Plugs Tom Modifications & Accessories 7 23rd July 2009 17:11
are spark plugs really required all the time??????? speedsatya Technical Stuff 66 8th March 2006 08:03
Better spark plugs -- Worth it? v1p3r Technical Stuff 1 26th June 2005 14:59
