Old 16th August 2006, 14:34   #46
sbasak's Avatar
Calculating torque/power by interpolation may not be accurate always.
Only the actual power-torque-curve can show the true torque/power at any RPM. The relationship is often not linear.
sbasak is offline   (1) Thanks Reply With Quote
Old 16th August 2006, 18:55   #47
Thanked: 26 Times
Originally Posted by anToNIcHeN
Hi all,
I know this is a very old thread... But just to get my doubts clarified....
I heard a friend of mine saying that putting Petes performance kit on the car would increase its torque... how far is this true?...
how would Petes kit help in increasing the torque?....
Also how would you measure the torque? (what methodolgy is used?)
My friend also said that higher torque means... you can shift gears at lower speeds? is it true?
regards,
ant.
http://www.team-bhp.com/forum/164091-post39.html
This link says that, more fuel is burned to get more power... does it mean that torque is also increased?....
can i conclude that, when more fuel is burned within the given time, torque is also increased?...
Also, can you guys answer this query also?
1. how would you measure the torque? (what methodolgy is used?)
2. can you shift gears in lower RPMs when the torque is increased?
regards,
ant.
anToNIcHeN is offline   Reply With Quote
Old 16th August 2006, 19:13   #48
Shan2nu's Avatar
Thanked: 89 Times
Yes thats true. For that reason, all torque/power curves are calculated at full throttle (at any given rpm).
TC, SC and NOS work on the same principle. More air in the cylinder = more air fuel mixture = bigger explosion = more torque and power.
Shan2nu
Old 16th August 2006, 19:19   #49
Shan2nu's Avatar
Thanked: 89 Times
For cars, they use dynos to calculate the torque curve and from this, the power curve is derived.
As long as the vehicle speed allows for that gear to revv the engine at above the idling speed, it'l work. But this maynot be good for the engine. Always check the car manual for recomended shift points.
Shan2nu
Old 22nd August 2006, 04:35   #50
SLK
SLK's Avatar
Thanked: 192 Times
Well, I've got nothing more to explain .... but I had made an excel file with graphs to depict torque and power curves of various cars ... but in the absence of detailed information its just a play-around thing. BUT it surely helps you understand how things work between power and torque.
I have a few cars input there.... plz don't ask me how I filled in the data as I can't explain it. Study the sheet hard enough you will know.
Cars input: Santro erlx, zen, wagonR, City ZX, City ZX Vtec, Baleno
if you see the pic below you can download the sheet else you can't..
PS: the data might just be far from even an estimate.
SLK is offline   Reply With Quote
Old 22nd August 2006, 18:10   #51
Thanked: 7 Times
Infractions: 0/1 (4)
Hi anToNIcHeN
Torque is measured this way
Torque = (Horse power * 5252) / RPM
and Horse power is measured this way
Horse Power = (Torque X RPM) / 5252
Bye
Alex
alexrabbi is offline   Reply With Quote
Old 23rd August 2006, 21:42   #52
jat
Check this (Physics behind car's movement) link on the team-bhp
jat is offline   Reply With Quote
Old 1st October 2006, 20:02   #53
Default BHP@RPM Mystery
hello bhpian's,
one technical question :-> suppose there are two vehicle's A & B , both having similar specification ( engine ( V4-4valve), layout, wheelbase.., engine capacity etc..etc..) but different BHP@RPM..........."A" having 250 BHP @ 7000 RPM while "B" having 250 BHP @ 10,500 RPM...........now u have to tell from both of the vehicles which one is better and why?
devsus is offline   Reply With Quote
Old 1st October 2006, 20:09   #54
nitrous's Avatar
Thanked: 285 Times
Well, when it comes to road use, its better to have the peak power earlier.
And when it comes to racing, its better to have the peak power later.
Old 1st October 2006, 20:37   #55
ess_a's Avatar
Why should the peak power come later?
ess_a is offline   Reply With Quote
Old 1st October 2006, 20:47   #56
danlalan's Avatar
Thanked: 135 Times
well for top speed or for high end power...10,500 is good....
danlalan is offline   Reply With Quote
Old 1st October 2006, 21:01   #57
well, u r very right that's why in formula 1/motogp...... RPM level goes to 20,000RPM/16,000RPM..............
Old 1st October 2006, 22:10   #58
Thanked: 103,537 Times
Generally and with all things being equal...the 2nd engine will be smaller in size than the 1st engine. Thats how it is able to meet 250BHP at 10,500 rpm while the 1st makes the same amount of power at a much lesser RPM.
Weight is an important consideration in racing, and there are several rule restrictions. Thats why we see high-revving 3000cc (now 2400cc) Formula 1 engines producing 800 bhp but at 17000 - 18000 rpm. Compare that to an Accords 3000cc engine which makes about 30% of the power. But then, Formula1 engines are not built to last 2,00,000 kms and meet emission requirements.
Some stock engines converted to race use have their revv limit increased only to avoid unsettling the car in a corner. The last thing you want in a challenging corner is to upshift and upset the balance.
It all depends on the application and is difficult to say which of the two will be better. Buttttttttttttttttttttttt more RPM does not necessarily mean more power. Yet it certainly means more wear and tear.
Old 1st October 2006, 22:45   #59
ess_a's Avatar
But my question remains... why is it better for the peak power to come late? If the same power can be obtained at lower rpms, wont the car accelerate faster?
One thing can be the size of the engine (as GTO pointed out that weight is a factor) and smaller engines ( those used for racing) need muuuch higher rpms to deliver the same out put..
But then nitrous is pointing out to something different....
Please someone clarify...
Old 1st October 2006, 23:15   #60
Pankaj401's Avatar
If you get the peak power later in the rev band you can achieve greater top speed becuase that's where the greater power is needed to counter the aerodynamic drag force.
Pankaj401 is offline   Reply With Quote
My Kleemann K4 : 650 BHP and 900 NM of torque! gemballa Super-Cars & Imports in India 172 23rd November 2013 09:54
200 BHP and torque up to 400Nm Fortuner ! hail Pete's! jkdas Modifications & Accessories 13 18th September 2009 15:57
torque vs rpm vs bhp graph : DDIS 1.3 MJD goandude Technical Stuff 2 27th July 2009 11:07
Actual bhp & torque. veyron-w16 Technical Stuff 0 22nd December 2008 22:50
Torque and BHP Subbu Technical Stuff 2 9th August 2006 15:14
