Old 27th May 2004, 16:34   #1
Rtech's Avatar
Thanked: 221 Times
Unhappy
Hey Guys,
I've never owned a diesel car before we got our Octavia 1.9TDi. I was never really interested in em either, technically or otherwise too.
Hence my questions.
1) What, if any, difference is there between the engine oil used in a diesel engine and that in a petrol?
2) What is the best oil I can get for my TDi?
Need some serious replies please.
Rtech
Old 27th May 2004, 18:44   #2
Jaggu's Avatar
Thanked: 8,685 Times
grade will be diff for petrol n diesel engines, better stick to manufactured specified oils when under warranty and maybe shift to higher performance oils, if u have access to imported crude..
what is the ratings for the manufacturer specified oils? i mean the SAE ratings, usually the range will be mentioned in the owners manual, that will help u find a better alternative and stick to the safe limits..
Old 27th May 2004, 22:16   #3
Thanked: 103,493 Times
Rtech,
The absolute best lube that you can use for the Octavia is Delvac 1 - The diesel sister of Mobil 1. There is nothing that comes close to Delvac 1 fully synthetic in engine protection, performance and efficiency. After 5000 kms of using Delvac 1, you will feel your engine starting better, idling smoother and revving easier through every part of the band.
My Jeep uses ONLY Delvac 1 while the petrol cars use ONLY Mobil 1.
Let me know if you want to opt for it. I can source it cheaper for you (Rs.500/liter vs. Rs700 MRP).
Old 28th May 2004, 12:46   #4
Rtech's Avatar
Thanked: 221 Times
Thanks GTO,
I'll get in touch with you for that oil when it gets closer to my 1st service.
Rtech
Old 28th May 2004, 13:09   #5
Jaggu's Avatar
this brings into mind an ol question?
there is a school of thought that says using Synthetic high grade oil during break in will affect the break in, the fine particles that are shed out into the oil during the break in period helps engine to bed in more.. any thoughts on this??
Old 28th May 2004, 13:48   #6
Originally Posted by [b
Quote[/b] ]there is a school of thought that says using Synthetic high grade oil during break in will affect the break in
Correct, synthetic oil must NOT be used in the first 5000 kms of your brand new engine. During this period, you actually want some wear and tear to take place...synthetic will minimise this and work against the breaking-in purpose.
Old 28th May 2004, 17:11   #7
Rehaan's Avatar
Thanked: 25,038 Times
Hey Rtech,
Some good reading for some more info - The Engine Oil Bible
cya
R
Old 28th May 2004, 18:04   #8
Rtech's Avatar
Thanked: 221 Times
AWESOME link Rehaan, and not just for the Oil bit!
thanks!
Old 28th May 2004, 18:36   #9
Jaggu's Avatar
while on the topic of engine break in check this guy out.. MototuneUSA
Old 6th January 2007, 11:47   #10
Do you still get Delvac 1 in India? I checked with the dealer in Chennai. He only has MX. Can you suggest a place where I can buy it?
Luke is offline   Reply With Quote
Old 19th February 2007, 16:36   #11
Default Oil for Diesel
Rtech,
Hi GTO,
I have recently joined the group and the amount of information the group has is awesome.
I have diesel tata safari 2001 model and was wondering can you help me in buying Delvac 1 or provide me with information from where I can source it. I stay in Mumbai.
sammykhan is offline   Reply With Quote
ARTICLE: Synthetic oil vs Mineral oil GTO On modifying a car 4903 19th July 2018 11:33
Engine Oil Change : Paid Service vs Buying Oil yourself vs Full DIY neosmart Technical Stuff 77 29th June 2017 11:16
What happens to the engine oil when the Oil cap and/or dipstick is opened? D.V.R Technical Stuff 29 19th September 2016 17:35
