Old 17th July 2017, 16:05   #31
Thanked: 51 Times
Default Re: Damaged Apron - Repair vs Replacement
A pic of the repair carried out in the cracked LH side apron of my WagonR
Since the repair i have driven my car by another 1500 kms with no apparent problems.
Please share your views
finiteinjustice is offline   Reply With Quote
Old 6th December 2017, 17:19   #32
Thanked: 597 Times
Infractions: 0/1 (4)
Usually repair/replacement of Apron ends up in alignment issues, which is very very difficult to correct and hence tyre wear.
Even if its just a hairline crack, I would suggest to check and correct alignment after the work is done.
I have been asked to change the cross member as the cross member is bent. Is replacing it very difficult and will it affect the apron?
bhpfaninblr is offline   (1) Thanks Reply With Quote
Left ORVM Damaged - Replacement? remcy007 Modifications & Accessories 13 22nd September 2016 18:25
Swift Fender & Bumper Damaged - Repair & Repaint fine69 Technical Stuff 22 18th August 2014 23:29
Head-Unit's front panel damaged - Repair or replace? bigvishnu In-Car Entertainment 6 23rd January 2014 10:30
Esteem apron bent Hashim Technical Stuff 40 26th October 2012 20:22
Rear bumper damaged at A.S.S, Promised replacement bumper. Edit: Got new Bumper. amitk26 Technical Stuff 18 26th February 2011 23:52
