Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 14th April 2004, 13:53   #1 (permalink)
normally_crazy's Avatar
Default power v/s chassis and the importance of handling
fellas ,
am just curious to know.... if u modify ur stock car to get more power and performance ... how much more power can the chassis handle ? also do we have to strenghten the chassis ?
cheers
__________________
In the end there are 3 things that last: faith, hope and love; and the greatest of these is love.
normally_crazy is offline   Reply With Quote
Old 4th May 2004, 22:04   #2 (permalink)
Even i am searching on this topic if any one knows plz let me know
naqeeb is offline   Reply With Quote
Old 28th May 2004, 14:57   #3 (permalink)
Exclamation
IF YOU PLAN TO STREET RACE WITH AROUND 20-25% MORE POWER THAN THE STOCK ENGINE I DONT THINK YOU WOULD HAVE TO STRENTHEN THE CHASSIE THOUGH STIFFER SUSPENSION WOULD DEFINATELY HELP WHEN CONERING HARD
REGARDS
SANKET
__________________
push it to the limit
sanket12 is offline   Reply With Quote
Old 28th May 2004, 15:07   #4 (permalink)
Rtech's Avatar
One area which I seem to notice is always overlooked when it comes to modding cars here in India is the brakes.
we always read long stories about what ppl have done to their engines, added TC's, intakes, headers, the works. Even the suspension gets mentioned often, but I rarely find any word on upgrades to the brakes.
Good brakes instantly make the car go "FASTER"! Why? 'coz you have the confidence to brake late into a corner! infact, considering road conditions in India, I think brakes are the third most important performance modifcation you can do to your car, the first 2 being wheels/tyres and suspension. *
If I were to do up a car in stages, it would be in this order:-
1. Wheels/Tyres
2. Suspension
3. Brakes
4. Engine modds.
Do it this way, and you will have the quickest car around!
there is a lot of truth in the old Pirelli saying: Power is nothing without control.
__________________
He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it!
____
Old 31st May 2004, 15:00   #5 (permalink)
Rehaan's Avatar
Very good point Rtech!
Tyres are the link between you and the road, and no matter how much power ur engine puts out, how well your suspension is designed or how good your brakes are its all useless if your tyres cant cash that in.
Personally i would do
1. Tyres (/wheels)
2. Brakes
3. Suspension
4. Engine mods
for driving in our conditions, ie mostsly short ~90* turns and not so many long sweeping turns IMO
Whereas if it was for the track (or similar situation) i would go with rtech's order.
cya
R
ps - and about the topic...i would say that there is non concrete answer, obviously the more power your engine is putting our the more rapidly your chasis is going to take the beating. Its not like there is an exact limit which once crossed is too much. Also it depends on the car, and its quality of chasis build. However as a rough guide id agree with Sanket, 20% is do-able.
__________________
The memory of you will ride by our side forever.
Old 4th June 2004, 18:52   #6 (permalink)
Beside a revv-happy engine, one of the most deciding factors for an enthusiast is the way a car handles.
This is a list that I had compiled a while back....of what constitutes a great handling car.
1. Weight
2. Lower Center of gravity
3. 50:50 weight distribution
4. Taut and Rigid Chassis
5. Aerodynamics
6. Tyres
7. Brakes
8. Tight Suspension (Multi-Link, Active, Double wishbone...)
9. Traction Control + Electronics
10. ABS (e.g. how a car behaves in a corner while hard braking)
11. Gearing (the ability to stay in the same gear while taking a corner)
12. Rear-Wheel/AWD
13. Quick + Responsive Power Steering
14. Minimum Body cuts (coupes)
15. No Convertibles
16. Alloy Wheels / Unsprung weight
17. External conditions
18. Differentials (Limited Slip...)
19. Dimensions (Track, wheel base...)
20. Most Imp - The Driver!!!
__________________
Work backward from your imagination, not forward from the past!
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 5th June 2004, 06:36   #7 (permalink)
Shan2nu's Avatar
It's really hard to be specific about what makes a car handle better. But yeah some general factors like track, wheelbase, aerodynamics, tyres, driver etc do make a difference.
The weight of the car isn't always good for handling. You can have a very light car like the XTR with a balanced downforce treatment and make it handle better than a Pagani Zonda which is more than 4 times the weight and power.
The gear ratios, again depend on the track design. F1 cars use different gear ratios for each track. *
A lower COD doesn't mean the car handles better. It's just a measure of how easily the car cuts through air. A lower COD will improve top speed but not necessarily handling and stability.
F1 cars are said to be the fastest machines to lap a track. But they don't run on a low COD. While cars like the Enzo and the Mclaren F1 have COD of around 0.30-0.32, the F1 cars can go all the way to 1.00 or even more.
Just remember that drag can be produced in more than 1 way. "Drag due to resistance" and "drag due to downforce".
On the whole, a good handling car will have all the factors mentioned in the opening post, in the best possible proportions.
Regards...
Shan2nu
Old 5th June 2004, 08:35   #8 (permalink)
In addition to all that, feedback and response - two things which can be added through talent and not pure science. The icing on the cake !
__________________
Rice is cheaper than German Potato's
Old 22nd July 2004, 17:35   #9 (permalink)
what about the state of the road that ur driving on
__________________
Old 22nd July 2004, 18:28   #10 (permalink)
Shan2nu's Avatar
Originally Posted by [b
Quote[/b] ]what about the state of the road that ur driving on
Make that, F1 track standards.
Regards..
Shan2nu
Old 22nd July 2004, 20:50   #11 (permalink)
Point no. 17 = External Conditions
__________________
Old 6th March 2006, 10:46   #12 (permalink)
Rtech's Avatar
Retro week Bump!
Not much has changed since this topic last surfaced. Tuners still mainly concentrate on the engine, leaving other, less glamourous, aspects ignored.
A good example was the last track day in Chennai which highlighed the fact that even a stock engine has too much power for the OE wheels/tyres and suspension to handle.
Something to think about before you spend on trickin' up your car next.
__________________
____
Old 6th March 2006, 10:59   #13 (permalink)
Psycho's Avatar
Well said Rtech
However critical mods to the car other than the engine typically include (depending on the limit of mods) braces (strut and lower) sway bars, modded suspensions, better engine mounts, better suspension bushes (have been using teflon in extreme cases, trying to get down the full bush kits soon), Upgraded brakes ( boosters, discs / drums where required), modding the brake bias. They play a critical aspect in keeping the car together and performing to its best in every condition.
__________________
Psycho
Modding != idea + <ctrl-c> + <ctrl-v>
Modding = idea + <ctrl-c> + <ctrl-v> + Finagle's Law of Dynamic Negatives
Old 6th March 2006, 12:27   #14 (permalink)
rareone's Avatar
Question
After reading the whole thread i m 2 curious 2 knw more in details.
May be someone cud help.
Let me know when is it required 2 upgrade the braking system of the car.
Also what brand/type of braking upgrade is available in India.
Also some more details abt the chasis (When/WHY/How) to upgrade.
Thanx in Advance.
Happy Revving...
rareone is offline   Reply With Quote
Old 8th March 2006, 01:41   #15 (permalink)
nitrous's Avatar
The regular Indian Lancers have the same chassis that the Evos have.
So, the Indian lancer can withstand 300bhp at ease. From stock,Thats over 200%
Rollcages, strut bars help in increase chassis rigidity and resist flexing
__________________
Han:The Red Evo's yours
Sean:What do u mean?
H:U're representing me now...What did U think, I'm gonna let you roll in a hyundai?
Thread Tools
Importance of braking distance bigman Street Experiences 14 22nd June 2009 12:42
Running Power wire under the chassis ibm_jennifer DIY - Do it yourself 18 27th April 2009 18:47
First Aid--Of utmost importance GTS Shifting gears 5 21st July 2006 15:51
The Importance of Marketing GTO Motorbikes 5 17th February 2006 13:01
Hatch Back Vs Sedan ( Ride, handling, comfort, Power etc) muni Technical Stuff 8 7th February 2006 16:33
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
