Old 2nd October 2015, 22:58   #1
Default Molten & sticky material on the underside - What is it?
Dear Friends,
I have observed a tar type, molten and sticky material beneath the bottom of my car (Fiat Palio 1.2 nv Petrol).
I am unable to assess and conclude anything about that material. I am attaching some pictures of it.
What is that tube/pipe around?
From where has it come?
Is it something risky?
Thanks.
Navin Talati is offline   (2) Thanks Reply With Quote Received Infraction
Old 3rd October 2015, 09:14   #2
SunnyBoi's Avatar
Thanked: 2,832 Times
Default re: Molten & sticky material on the underside - What is it?
That is a melted gear cable. No cause to worry, its there in all palios including mine. The outer casing of the gear cables will melt due to the close proximity with the exhaust. Even if you change cables, it will melt soon so there is no point in changing the same.
SunnyBoi is offline   (9) Thanks Reply With Quote
The Damping Material and Sound Deadener Thread kb100 In-Car Entertainment 1173 19th June 2018 00:40
Alternative material for damping amit_sound In-Car Entertainment 183 30th April 2016 12:36
Rusting on Underside of Punto amoghchaphalkar Technical Stuff 9 12th July 2009 15:19
How effective is sound deadening material in tackling rattling ? swathyd In-Car Entertainment 19 15th August 2008 20:15
Scraping the Underside of my OHC aveek Modifications & Accessories 21 21st October 2005 14:15
