Thread Tools
Old 9th September 2006, 16:29   #1 (permalink)
iraghava's Avatar
Default OHC VTEC Problem
Hi guys,
I've been facing a problem with my VTEC for the past 10 days or so. Basically it started one night when I was driving back from Delhi the car started missing in the low-rpm ranges & the power went down a bit, now since I was on the highway I couldn't stop anywhere so I limped back home slowly.
Next morning I had it checked in the garage & the plugs were fine so we opened up the Fuel Filter & that was full of dirt so we replaced it with a new one. After this the car drove fine for a couple of days. But in a few days she started to again have this mild stutter as if there was a fuel starvation issue.
Now the interesting thing to note is that if I use the car only for in-town work then this problem does not occur. But when I use her for extended periods of let's say over half an hour then this issue starts happening and the car goes down on power & starts stuttering.
Today I had gone to the garage and the engineer after listening to the point of stuttering after 30 mins of usage said that it's a fuel pump issue & he'll have to change it to sort out the issue.
Do you think his assessment is right?? Or can there be any other problem?
Details of the car:
2003 OHC VTEC
113,000 kms done.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 9th September 2006, 16:47   #2 (permalink)
viper's Avatar
I think he is right. If you had not said his assesment I would have pointed out the fuel pump only.
Viper
__________________
NO ONE DARES COME CLOSE
viper is online now   Reply With Quote
Old 9th September 2006, 17:02   #3 (permalink)
sans33's Avatar
Yes.It's fuel pump problem for sure.But instead of replacing it right now,get it cleaned at dealership.You might be able to avoid expenses for a few thousand kms.
sans33 is offline   Reply With Quote
Old 9th September 2006, 17:55   #4 (permalink)
viper's Avatar
Hey,
Would recommend you change the motor if its is the problem, should not cost more than 2k including fitting charges instead of waiting for the fuel pump to fail on you and being stranded in the middle of nowhere. Better to spend 2 k know than spend on towing etc. later
Viper
__________________
Old 9th September 2006, 19:00   #5 (permalink)
suman's Avatar
Originally Posted by viper
Hey,
Viper
I agree, and in your case, you might end up being stranded in the middle of the highway at night - definitely avoidable!
__________________
Land's end, journey's beginning - Safari Dicor VX 3.0L 4x4
Old 9th September 2006, 19:24   #6 (permalink)
iraghava's Avatar
Hey,
Viper
Thanks for the advice guys and for the concern too. I've had a chat with him & we've decided to open up the pump & clean it & see if it helps. Also if the motor is faulty we'll replace that too since its about 2-3k.
But if both these factors don't help then we will change the pump. He said the cost would be around 8.5k (he wasn't sure) Any of you guys have an idea about the cost??
I'm the last person who would like to be stranded on one of my routine journeys and so am very particular about the maintenance of my cars.
__________________
Old 9th September 2006, 19:27   #7 (permalink)
iraghava's Avatar
Originally Posted by khaadu75
raghava, You should have gotten this checked at the tuners garage that you went to ... maybe a turbo installation wud have cleared this problem !!!
Haan why not!! Jo chal raha hai woh bhi bund ho jaayega saala Like I said to you earlier Khaadu, rather than getting my car worked upon from him I will set fire to it with my own hands!
__________________
Old 9th September 2006, 19:30   #8 (permalink)
viper's Avatar
Hey,
Listen to me change the motor you will not regret the decision. Cleaning it will not solve this problem. There is definitely no need to change the entire pump as 99% the problems(car wont start, shuts after a while, jerking etc) get solved by changing the motor. 8.5k is a decent price costs aroung 6k in Mumbai. The OE Honda fuel pump assembly is expensive. I think GTO mentioned it was around 14k as we changed his Fuel Pump motor last month.
Viper
__________________
Old 9th September 2006, 19:42   #9 (permalink)
iraghava's Avatar
Hey,
Viper
Yeah Viper that's what we plan to do. He also mentioned that 99% of the time these things are solved by changing the motor, no need to change the whole assembly.
__________________
Old 9th September 2006, 21:13   #10 (permalink)
z klasse's Avatar
If you want a fuel pump, you can get a VDO one which is made siemens, its a good brand.. Costs roughly around 1300-1900rs. Get it replaced at a known garage rather than the Honda Dealership.
z klasse is offline   Reply With Quote
Thread Tools
OHC Vtec malcolm Modifications & Accessories 81 18th February 2008 14:22
Ohc 1.5 Vs Ohc Vtec narayan Technical Stuff 85 19th February 2007 21:56
First Mods for my OHC VTEC..... adit1329 Modifications & Accessories 20 19th May 2006 13:29
NHC-Vtec or OHC Vtec..which is a better buy? sunith Sedans 4 2nd May 2006 21:25
Wanted: OHC VTEC or OHC 1.5 adit1329 Shifting gears 4 16th March 2006 17:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
