Old 26th May 2004, 21:18   #16
Rehaan's Avatar
Thanked: 25,043 Times
Originally Posted by [b
Quote[/b] (Tom @ May 26 2004,16:39)]they must have been reading this thread....LOL
Quite possible
Old 26th May 2004, 21:47   #17
If they were reading this thread then it says a lot about how good this site is!!!
Great going guys!!
Besides in the Autocar India article i think they say just the valves dont open but the gases trapped in the cylinder help the pistons move so that will avoid uneven wear.and the transition from 3 cylinders to 6 is done is 40 miliseconds!! Now that is awesome!
Wraith is offline   Reply With Quote
Old 29th May 2004, 00:43   #18
Is whole thing of cutting of cylinders as per requirement efficient?I mean when ur running a say a v8 or 4 cylinders u loose a lot of power in running the idle cylinders(frictional) or is the loss neglible compared to the gain in fuel economy ?
Heard the Delhi police used to run the Yamaha RD350(once upon a time) on single cylinders to conserve fuel.
What about the balancing of the engine when run on such a setup?
Anyone who knows this please clear my doubt.
bicyclerider is offline   Reply With Quote
Old 31st May 2004, 19:28   #19
Jaggu's Avatar
Thanked: 8,693 Times
this gives a lot of explanation displacement-on-demand (DOD) technology
Old 31st May 2004, 19:43   #20
Rtech's Avatar
Thanked: 221 Times
Quote[/b] (Wraith @ May 13 2004,18:17)]One query i have is...is there any system on sports cars which can be used to drive them in economy mode when u r not in the mood to be a boy racer? and is it cheap?
I mean like in a v10 engine can we use only one bank of cylinders if required and get more efficiency?
Or are there any presets for power and torque curves to get more mileage or more power?
There is a cheap way, something that has been in use on Corvettes for a long time now. They have some kinda system whereby you shift directly from 1st to 4th when you are just cruising around (i guess you could do that yourself too on a manual!). They also have a "Valet" mode which allows the car to be revved to a lower rpm. Useful when you give the car for servicing!
Cadilac's Northstar V8's have used this cyclinder cut of since the advent of the STS. No problems seemed to arise out of it, and this is now more than a decade old.
Quote[/b] ]Heard the Delhi police used to run the Yamaha RD350(once upon a time) on single cylinders to conserve fuel.
Now thats just asking for trouble as the the fuel would jsut accumulate in the cylinder causing hydraulic lock at some point. Thats if the engine doesn't sieze first due to lack of lubrication!! If they wanted economy, why didn't they just get a Hero honda CD100!!!
Old 1st June 2004, 15:29   #21
Jaggu's Avatar
actually rds can be run on single cylinder make sure u remove the plug.. its called limp home mode
Old 1st June 2004, 17:19   #22
Rehaan's Avatar
Quote[/b] (rtech @ May 31 2004,18:13)]something that has been in use on Corvettes for a long time now. They have some kinda system whereby you shift directly from 1st to 4th when you are just cruising around (i guess you could do that yourself too on a manual!).
Hey Rtech,
The Viper had something similar, if you went too high up the revvs in 1st gear it forced you to shift into 4th on the MT. This device naturally lived a very short production life!
On the viper though i beleive a reason was that 2nd gear was just too violent to manage to control!
cya
R
Old 1st June 2004, 17:37   #23
Rtech's Avatar
Thanked: 221 Times
The reason they had and still use this on corvettes is to get a decent EPA figure - i.e. their fuel consumption figure, thereby avoiding the gas guzzler tax that is levied.
I never heard about this on the Viper though, thats news to me.
Old 1st June 2004, 18:40   #24
Thanked: 103,639 Times
Quote[/b] ]if you went too high up the revvs in 1st gear it forced you to shift into 4th on the MT. This device naturally lived a very short production life!
Its called the skipshift. And is indicated by a blinking white arrow on the dash, when you revv hard in the first gear. The EPA had something to do with this.
Old 1st June 2004, 19:10   #25
Rtech's Avatar
Thanked: 221 Times
I was talking about the corvette GTO. The sole reason they installed that system was coz of the EPA.
Like I said, I don't know about the Viper.
Old 1st June 2004, 19:25   #26
Rtech's Avatar
Thanked: 221 Times
Quote[/b] ]Its called the skipshift. And is indicated by a blinking white arrow on the dash, when you revv hard in the first gear. The EPA had something to do with this.
Was just reading up on the skip-shift. The ONLY reason it exists on both the Viper as well as the Corvette is to satisfy EPA regs and bring fuel consumption and emmissions down, and hence avoid the guzzler tax.
Infact, contrary to what Rehaan and GTO have said, the 1st-4th shift ONLYtakes place under very light throttle inputs. If you revv it up, it will allow you to shift into 2nd like normal.
It really doesn't make sense on a sports car like the 'vete or Viper to force you to miss 2 gears when you are driving it in anger!
Rtech
Old 2nd June 2004, 19:03   #27
Rehaan's Avatar
Hey Rtech,
my bad, i had read about this on the viper about 4years ago...i guess i messed up the reasons!
cya
R
Old 3rd June 2004, 13:57   #28
OOPPPSSSS!! Corrected.
10 Million USD X-Prize for Fuel Efficient Cars sriramv.iyer The Indian Car Scene 4 1st May 2010 06:59
Least Fuel Efficient cars DriverR The International Automotive Scene 11 22nd May 2009 21:50
Dunlop SP Sport 9000/ SP Sport 2000/2000E rajeevrs Tyre & Alloy wheel Section 4 29th July 2007 10:25
Why do we have less Fuel Efficient cars in India ? Karandeep81 The Indian Car Scene 25 14th June 2007 15:22
help me decide-palio sport or adventure sport 1.6 for city driving premchetan Hatchbacks 46 9th February 2007 17:44
