Old 10th September 2006, 23:03   #1
karthik247's Avatar
Thanked: 16 Times
Default Tight Gearbox
Guys, the 1st and 2nd gears of the car feel really tight. Its a bit too hard to slot the gear liver at times. The car had its service done about a month ago, and the gear oil was changed as well. The other gears are smooth, its just with these two. What could it be???
karthik247 is offline   Reply With Quote
Old 10th September 2006, 23:36   #2
ess_a's Avatar
Which car do you have????
ess_a is offline   Reply With Quote
Old 10th September 2006, 23:37   #3
karthik247's Avatar
Thanked: 16 Times
Mitsubishi Lancer.....
Old 11th September 2006, 15:27   #4
Jaggu's Avatar
Thanked: 8,693 Times
is the clutch adjustment ok?
Would be good just to check the gear oil level again, apart from that see if the cable system is properly lubricated and stuff
Old 11th September 2006, 17:21   #5
esteem_lover's Avatar
Thanked: 451 Times
how much has the car done ? has the clutch been serviced ? is the clutch hard ?
Old 11th September 2006, 18:10   #6
karthik247's Avatar
Thanked: 16 Times
Clutch is fine...not hard at all. The car has just completed its 3rd service at 20k kms. I almost changed all the oils just for the sake of it. I guess i'll get the clutch checked.
Old 14th September 2006, 21:19   #7
karthik247's Avatar
Thanked: 16 Times
Umm..guys, some help here.
Old 14th September 2006, 21:38   #8
humyum's Avatar
Thanked: 2,503 Times
Dude Get the Gearbox forks checked.The forks sometimes hit the ground at speedbreaks or get hit by a stone which causes them to bend a little which leads to hard shifting as the angle changes.
Also check the gearbox+engine mountings and if they are worn out replace.Chances of one of them gettin worn first than the other is possible as gearbox and engine mountings are under different loads.Their wear leads to the engine or the gearbox tilting sligtly towards one side which in turn causes the forks connecting the gearlever to the gearbox to have a change in angle=hard shifting.
I hope this helps..
Old 14th September 2006, 22:02   #9
theMAG's Avatar
Thanked: 1,574 Times
Run these off as a checklist:
1. Check the gearbox cables; they might be catching on something.
2. Try bleeding slightly at the clutch slave cylinder
3. Lubrication: Try changing the Manual Transmission Lubricant to a better brand; preferably synthetic
4. Shot clutch
5. Stiff/seized linkages
6. Problematic gearbox bearing (Spiggot bearing)
Best wishes
Old 14th September 2006, 23:51   #10
Pankaj401's Avatar
I had problem slotting the stick to second gear on my Vtec. And sometimes the gear would jump out to neutral. Turned out to we worn shifter linkage.
Pankaj401 is offline   Reply With Quote
Old 15th September 2006, 09:16   #11
Thanked: 655 Times
Check if the oil poured into the gearbox was the right grade. For eg. the gearbox on the contess uses 20w50 oil and most regular gearboxes use 90 oil. My workshop inadvertently poured 90 oil for a gear oil change and the gearbox tightened up. A change to the recommended oil, set things right.
You could also try Castrol TQ oil. It really frees up your gearbox and it is approved too.
jyobeb is offline   Reply With Quote
Tight clutch in Alto sparkguy Technical Stuff 5 26th October 2009 12:52
Good ICE for my Aveo . Really tight Budget, really!! rahulsingh007 In-Car Entertainment 18 2nd May 2009 09:04
Solution for Tight/metallic brake/clutch vasudeva Technical Stuff 7 27th September 2008 11:57
Steering suddenly got real tight...Repaired ! Mohnish Technical Stuff 9 25th July 2008 22:53
