Old 21st October 2015, 13:49   #16
Thanked: 103,375 Times
Default Re: Low engine temperature - Engine isn't getting warm enough
Originally Posted by rr_zen View Post
While the usual concern would be what if the temp gauge shows a lower temp than normal, my concern is how would I even identify this phenomenon in cars that do not have a temp gauge.
Which is why 93% of BHPians want the temperature gauge back on all cars - Link (Good 'ol Temperature Gauge : Yes or No?).
Every engine has an 'optimum' temperature that it performs best at. The OP probably wouldn't have realised that he had a problem, if it weren't for the gauge.
GTO is offline   (5) Thanks Reply With Quote
Old 21st October 2015, 14:12   #17
arunphilip's Avatar
Thanked: 4,818 Times
Interesting thread. While the usual concern would be what if the temp gauge shows a lower temp than normal, my concern is how would I even identify this phenomenon in cars that do not have a temp gauge. For eg, the A-Star
The short answer is you wouldn't, unfortunately. You can take your own temperature readings now and then, with for instance a Infra red thermomenter, but its not very practical and you would take a considerable number of readings to figure out if anything is wrong.
Some cars expose the coolant temperature via one of the sensors readable by OBD-II. That'll give you insight into how the coolant temperature rises upon startup until the thermostat opens the flow into the radiator, at which point it will stabilize (or fluctuate as the high-speed cooling fan comes on and off).
Here again, as Jeroen has mentioned, you'd need to have a baseline to compare against (or the experience to get by without a baseline), when you know things were working normally and correctly to realize something is now amiss.
arunphilip is offline   (1) Thanks Reply With Quote
Old 21st October 2015, 15:31   #18
Abhi_abarth's Avatar
Thanked: 129 Times
Check what the manual says. This looks a little low to me.
Jeroen
Not able to embed the image due to poor quality hence typing the text :
'Under normal conditions, the needle may hover around the scale according to the car use and engine cooling system management that the system self adjusts continually, but it should always remain out of the red danger section'.
Abhi_abarth is offline   Reply With Quote
Old 21st October 2015, 15:37   #19
SnS_12's Avatar
Thanked: 874 Times
Well, in my 2008 Indica Xeta petrol I have noticed that when I used to run the car without the air-condition the temperature gauge would reach the halfway mark and when I switch on the air-condition it would stay at quarter. Never really applied my mind why this used to happen as the car was running normally otherwise. But, now I would be interested to know if anyone else has faced this issue and the reason for the same? As, Jeroen said running below idle operating temperature would also damage engine internals. So now I don't know what was the ideal engine running temperature in my Indica, which by the way has been sold off now.
SnS_12 is offline   (1) Thanks Reply With Quote
Old 21st October 2015, 15:38   #20
vikram_d's Avatar
Thanked: 940 Times
Most cars which don't have a temperature gauge normally come with two temperature based warning lights on the instrument console. One for high temperature and one for low temperature and if the engine temperature goes dangerously low the low temperature light along with CEL will come on.
Old 21st October 2015, 15:41   #21
thedragula's Avatar
Thanked: 262 Times
As everyone has pointed out, this could be the thermostat valve going bad. However, the thermostat valve only regulates the flow of coolant to the radiator. i.e., if it gets too hot, some coolant is diverted from the engine circulation to the radiator after which the cooled liquid returns to the engine lines to cool down the engine. If the coolant valve has gone bust, while your temperature will remain low, it will also fluctuate, especially in cases where the car is stationary due to which the radiator becomes less effective.
If the temperature is low and is at a constant, you need to check the radiator cooling fan. The relay which controls the fan itself or the relay which regulates the speed of the fan must have gone bad. In such a case, the fan runs continuously without stopping once the coolant has cooled down below ~85 degrees.
Before you open up the thermostat valve, do a visual check on the fan and the frequency and speed of operation.
thedragula is offline   (3) Thanks Reply With Quote
Old 21st October 2015, 16:16   #22
jfxavier's Avatar
Thanked: 1,290 Times
I have seen that the coolant temp of my car is around 90 deg C. This info is from the ECU via the OBDII adaptor and Torque app.
With less and less raw data available to the driver, these adaptors are the only source of information.
You will quite like the amount of information that the ECU can provide if you get the OBDII adaptor & app.
jfxavier is offline   (1) Thanks Reply With Quote
Old 21st October 2015, 16:19   #23
Thanked: 8,936 Times
On most cars with a temperature gauge you can actually 'see' if the thermostat works correctly. If you start from cold and start driving you will see the temperature rising. The minute the thermostat opens you can see a small, but noticeable, drop in the temperature reading. Once the thermostat is open it will start regulating smoothly, but the initial opening is often noticeable.
Jeroen
Jeroen is online now   (1) Thanks Reply With Quote
Old 21st October 2015, 16:35   #24
aniketi's Avatar
Thanked: 785 Times
Infractions: 0/1 (5)
Originally Posted by anish5225 View Post
I have been noticing something strange with the engine temperature on my 2009 Optra Magnum Diesel run 70000 KMs. In the past, after diving for ~ 10 mins, the temp gauge used to reach the halfway mark and stay there for as long as i drive.Then on, it will not go above or below this point no matter how long or how hard I drive.
But since the past few weeks, the temperature gauge hardly touches the earlier settling point even if I drive for an hour or two. Only reaches about midway. If I use the AC, the temperature drops a few notches further. Any idea what could be wrong?
Thank You
Anish
Exactly same problem I observed in my brothers Indigo Petrol. Temprature guage shows well below half way mark and it stays there only. If we put AC on, it goes down further. This is happening for last more than 2-3 years now. When I asked my brother about it, his reply was its like that only. He has bought Indigo in resale 5 years back. No problem faced till date. My brother is person who don't spend anything unless its obsolutely needed or its stalling the car
aniketi is offline   Reply With Quote
Old 21st October 2015, 23:19   #25
parth.jain's Avatar
Thanked: 108 Times
I have always believed that one of the functions of the thermostat is to switch on the radiator fan. Usually, cars with single radiator fan has a 'double' speed fan. When the car gets heated up the fan runs on normal speed and when the ac is turned on, it runs on a higher speed.
You can check if the radiator fan starts as soon as the car is started but air con is switched off, if yes, then something is definitely wrong!
I hope I am not wrong.
parth.jain is offline   Reply With Quote
Old 22nd October 2015, 08:03   #26
Couple of thoughts. In the context of this discussion thermostat has been used as meaning the thermostatic valve in the cooling liquid. I.e. A mechanical three way valve that opens and closes based on temperature.
What you mention is a thermostatic electrical switch that switches, based on temperature, the fan. Sometimes you might find that the fan uses a special kind of coupling which responds to the air temperature blowing through the radiator. So it's not electrically controlled but thermostatically. You will find these on some older Mercedes. And some cars/engines have the fan permanently driven, so in that case the thermostatic valve does all the work so to speak.
Jeroen
Jeroen is online now   Reply With Quote
Old 22nd October 2015, 08:41   #27
To add, on my Alfa Romeo Spider the normal cooling fan is permanently driven via a V-belt from the pully on the crank. So its the thermostatic valve in the cooling circuit that controls the temperature ( and by the way is a weak spot as I have replaced it numerous times). But it also has an additional, second, electrically driven fan, in case you switch on the AC. This second fan is electrically driven and also has an thermostatic electrical switch. So there are quite a few different set ups of thermostats (mechnical, electrical), fans and system lay outs about.
Jeroen
Old 22nd October 2015, 08:45   #28
jfxavier's Avatar
Normally a thermostatic valve is bypassing the coolant and as the temp. increases the sealed cartridge expands and moves the valve spindle against the spring (which keeps it in the bypass position) and lets the coolant go through the cooler/ radiator. If you find that the valve is stuck in the "open to cooler" position, it might be possible that it is stuck due to some solids coming in between the moving parts and it just needs cleaning up. Maybe you can check the coolant quality and flush/ replace the coolant if you find that the coolant is contaminated/ dirty. In that case, you might want to check for the source of contamination as well.
Normally the valves get stuck in the "bypass" position. Very rare to see the valve stuck in the "open" position as there is a spring trying to close it. It might be possible that the spring is broken, but very rare as I said.
Old 22nd October 2015, 18:18   #29
Thanked: 74 Times
Originally Posted by Abhi_abarth View Post
Reading all the posts, I have started feeling scared as my palio S10's temp gauge always stays within the 1/4 mark
While driving a friends Palio 1.6 (1st owner of the vehicle) I noticed the temp was at 1/4 mark (engine was running for more than 1 hour), it seems it was this way from the day he took the delivery and he never had issues
IPathan is offline   (1) Thanks Reply With Quote
Old 22nd October 2015, 21:24   #30
I agree with other bhpians that the coolant valve probably is at fault here. And in our Zen, the cooling fan runs continuously when the AC compressor is running, else it runs intermittently - almost only when the car is stationary. Maybe this is the reason why you are seeing lower temps when the AC is running.
I hope it's not a serious issue and is easily fixed!
SreeT is offline   Reply With Quote
Knocking noise on a Mach 500 LB only in a warm engine Karlitoz Motorbikes 9 7th September 2011 01:24
Engine Temperature Level for Innova??? Archish Technical Stuff 5 28th April 2009 14:09
Engine Warm Up katalyst Technical Stuff 20 10th September 2008 20:58
Aircon and engine temperature- Inverse relation abhi182 Technical Stuff 9 4th October 2006 13:26
