Old 12th September 2006, 14:02   #1
dsinz's Avatar
Post
Hello guys
I have a problem with my ALTO LXI. When I am taking a turn and I am in my second gear and I smoothly take the turn without AC. When AC is on and if I take the same turn, some times the vehicle turns off.
What could be the reason? Should I revv a more? to keep the momementum with AC or is it a problem with Car?
Please do let me know your views and suggestions!
PS: Still a L board - Driving since 20 days
dsinz is offline   Reply With Quote
Old 12th September 2006, 17:39   #2
shiva_cool87's Avatar
Shift to 1st and then turn.....so zimble.....
shiva_cool87 is offline   Reply With Quote
Old 12th September 2006, 18:16   #3
DueLLeR's Avatar
Thanked: 61 Times
You could be driving at extremely low rpms. When the AC is on, there is less power available for the engine to move the car forward with the same amount of throttle. But the MPFi engine should take care of that by measuring the load on the engine and automatically increasing the fuel supply. In fact, with an MPFi engine the car can accelarate slowly even with no throttle through the gears.
In your case, I think the engine shouldn't stall unless you are at extremely low rpm and the engine is under considerably high load like when going up a slope. Either way, the MPFi engine shouldn't stall under normal operating conditions. Does your car jerk to a stop?
DueLLeR is offline   Reply With Quote
Old 12th September 2006, 22:53   #4
esteem_lover's Avatar
Thanked: 451 Times
shift to the lower gear when you slow down or else revv more, but shifting down is recomended.
Old 13th September 2006, 00:35   #5
ECM
ECM's Avatar
Thanked: 9 Times
As members suggested check out RPM at MASS.Default is around 900 rpm.
ECM is offline   Reply With Quote
Old 13th September 2006, 11:51   #6
dsinz's Avatar
Post
One or two times it jerked, but another couple of instances it just switched off.. :(
Optra Magnum AC switching off during hard driving benzinblut Technical Stuff 21 30th June 2011 12:19
Punto music system (not stock) not switching off after switching off engine!! praz Technical Stuff 17 9th March 2011 09:55
Why diesel engines are revved before switching ignition off? DCEite Technical Stuff 57 7th May 2008 00:53
Swift switching off abinesh Technical Stuff 18 4th July 2007 20:38
Idling the Turbo engines before switching off.. Could this be a solution? DRC Technical Stuff 14 5th April 2006 21:19
