Old 18th November 2015, 22:14   #121
aaggoswami's Avatar
Thanked: 1,426 Times
Default re: Ford EcoSport - Axle breaks on highway. EDIT: Due to accident (details on page 11)
Why is the onus on the owner? It should be on FORD. Who do you think is more capable of a full expert analysis on what actually happened here?
Why the heck can't Ford do a proper analysis on what exactly caused this failure and tell the owner? What have they got to hide?
End of the day, it's the customer who pays 10 lakhs to Ford. This is the least that Ford can do. Ford NEEDS to provide answers to the owner. Ford is ANSWERABLE to the owner.
Agree with you. The failure is not small, whatever the cause.
Originally Posted by Doge View Post
There is no onus on the owner,just that the OP could clear a few things out and provide a little more clarity so that discussions are relevant.
A few more pictures wouldn't exactly be traumatising. Some people have presented some excellent theories as to what could've happened( both in favour of ford and against) and throwing a little more light may be of further help here.
Never thought that I will mention this, but the way wheel has got inside the body, its as good as what happens during offset crash testing. I am sure we all have had a look at those NCAP crash tests.
A bit of my story, but related to damage that can be caused and associated failures.
Attached herewith are a few images of my Wagon R which my sister managed to crash quite a while ago. It was early morning, very less traffic and all of a sudden a newpaper/milkman decided to change lane on a downward slope of a flyover.
To avoid hitting the individual on two wheels, my sister crashed the Wagon R into divider ( which is visible in one of images in a small way ). Car went onto divider, RHS side, but as it was end of downward slope, the distance between left side wheels and road increased, the car ended up on LHS side and was dragged a bit. No human injury or anything, only damage to machine.
You can see that even when a "Tin Can" Wagon R hits divider on its RHS side, and there is visible damage to chassis, WHEEL HAS NOT FALLEN OFF. Lower arm is damaged, so is the tie rod, and even apron was a bit out, but the wheel did not get dislocated neither did the wheel end up damaging body. All this on a small car doing around 60-65. The point of impact is below headlamp to the point where headlamp meets grille.
So how can a Ford Ecosport, which is obviously is better built than a Wagon R, suffer this much damage. Even if its a tyre burst, such structural damage and dislocation should not happen. My friends have suffered tyre bursts on expressway ( NE-1 ) at 110 in Swift Dzire, Swift, Innova. But in no case did the wheel come off or damage of lower arm, tie rod.
There is no Frontal impact to Ecosport and any damage to under-body should not have resulted into so much damage. Even one recovery bottle can be seen to be dismounted from its original location. There is something more than just a tyre burst. And, if a Wagon R, even after crashing into divider, so much that it toppled on left side, dragged, did not have such serious damage to wheel, drive-shaft, EcoSport, under normal circumstances cannot have so much damage.
The cases of Wagon R and Ecosport mentioned here can have multiple differences and many factors, but in general damage to ecosport should not be this much without any external impact.
@Mods : Sorry for writing down my own story and getting a bit offtopic, but I could not find any other way to indicate that Ford atleast owes a proper investigation to owner.
For the Wagon R, its still with me, has better part throttle responses than my Swift and Waggie after repairs still brakes in a straight line.
aaggoswami is offline   (6) Thanks Reply With Quote
Old 18th November 2015, 23:05   #122
Thanked: 31 Times
Originally Posted by rusticnomad View Post
While statistical sampling (to avoid each and every item from the batch being tested) for testing is true for less critical nuts and bolts for example, but for critical parts each one of them goes through non destructive tests like ultrasound, dye penetration tests etc to ensure that no defective part goes through to make it to the vehicle.
Also, parts like axle and shaft etc go (should go) through a robotic/automated testing too -- not sure if they went in this case.
Thank you rusticnomad for the info. Yes ford should do a proper investigation, just putting the blame on tyre burst is not going to help them in the long run. Regarding quality tests as you say if such processes are there its unlikely to be skipped whatever be the production pressures but it could have definitely been rushed.
nitheeshsreeram is offline   (1) Thanks Reply With Quote
Old 19th November 2015, 08:48   #123
Thanked: 49 Times
The last image shows skid mark stretching back to the culvert. My guess is when turning near the culvert, the tyre caught something at speed, which turned the LHS tyre almost 90 degree, causing all the subsequent damage. Now, the Camber force angle on wheels is normally -5 to +5 degree. Imagine the LHS tyre turning perpendicular. The camber force angle will be 180 degree (1/2 the circle). All other 3 wheels are traveling horizontally. LHS tyre alone is perpendicular. So what happens? The inertia of 3 wheels against a complete stop of one wheel results in downward speed vector. The resultant force slams the car body downwards with great force, which caused all the damages. An offset frontal crash would have caused less damage than this sudden turning of one wheel.
rselva is offline   Reply With Quote
Old 19th November 2015, 09:13   #124
Thanked: 89,255 Times
Poornima got a conference call from Ford. Ford experts are launching an investigation into this incident
Finally - look forward to the root cause of this accident.
Ford EcoSport - Axle breaks on highway. EDIT: Due to accident (details on page 11)-img20151119wa0000.jpg
GTO is offline   (22) Thanks Reply With Quote
Old 19th November 2015, 09:40   #125
csateesh's Avatar
Thanked: 113 Times
Attachment 1441212
Have been following this thread for a while and am so happy and glad to hear that Ford has finally launched an investigation into the incident.
csateesh is offline   Reply With Quote
Old 19th November 2015, 11:30   #126
Thanked: 1,081 Times
Good to note that Ford is ready for investigation. Any which way, this is good for Ford; if there is a QA QC problem, corrective actions can be taken by Ford, if the customer is at fault, well the insurance will cover the repair (with goodwill from Ford, as stated in the communication) which presents a case for good customer care.
Is there any timeline given for investigation? Where and how it will be carried out? Will there be someone from Ford US truck centre participate - I understand it was designed there in 2001-02 and launched in Brazil in 2003?
I am hooked to this thread.
Good luck !
i74js is online now   Reply With Quote
Old 19th November 2015, 11:32   #127
Thanked: 54 Times
Attachment 1441212
Glad to hear Ford has finally agreed for an investigation. This will help building Ford's commitment towards satisfying its customers. .
Was it media pressure that made them do so? Discussions in this thread should have contributed to that, I am sure.
As a Ford customer, I feel a bit relieved to hear this.
sudhirnam is offline   Reply With Quote
Old 19th November 2015, 12:15   #128
Thanked: 26 Times
Hooked to the thread. The attitude of most of the companies in India is not helping at all, and to top it all we dont have strong laws protecting consumers.
The news of investigation comes as a relief, now looking forward to what results Ford's Investigation throw and what course of action Ford takes next.
All the Best!
Ritesh_Dogar is offline   Reply With Quote
Old 19th November 2015, 12:43   #129
Thanked: 72 Times
Originally Posted by akhilesh View Post
This is scary and as an ecosport owner I'm worried. I've sent a mail to custmail@ford.com quoting this tread and expressed my concern.
Going through the components which attributed to 2.9L I noticed front speakers, entire dashboard etc.. in the list too which is kind of surprising. I seriously think that these guys extrapolate the figures by including all the unnecessary stuff and rip-off insurance companies
As mentioned I too sent a mail to ford quoting this incident. This is the response I got from ford
Dear Akhilesh Khurana,
First of all, thanks for giving us an opportunity to address your apprehensions on our quality products. I hope by the time you end up reading this communique, we would have reinstated your faith and earned your confidence in Ford products.
Concerning the incident referred in your mail, let me clarify that our dealership team along with third-party insurance and supplier have found the incident to have caused due to an external impact. It is not remotely reflective of the product quality.
Given that such incidents /accidents do not fall in under warranty, we have already intimated the customer to initiate an insurance claim. We are committed to customers and are providing all the necessary assistance so that this vehicle can be repaired and delivered at the earliest.
Please be assured that Ford vehicles are built in line with our global standards and offer world-class quality and safety. Knowing you are safe means a lot to all of us at Ford.
I hope we have been able to address your concerns. Do feel free to write to us for anything else we can assist you. We look forward to welcoming you to the Ford family.
Kind Regards,
akhilesh is offline   (2) Thanks Reply With Quote
Old 19th November 2015, 13:01   #130
Thanked: 49 Times
About time! If Ford engineers have even an iota of curiosity, they would be falling over each other to investigate this interesting (sorry if that sounds insensitive) case. Hope the thread is updated with Ford's conclusions after investigation is completed.
Last edited by Gannu_1 : 19th November 2015 at 16:22. Reason: Removed FONT tags. Please type into the forum directly instead of copy-pasting from word processors. Thanks!
Old 19th November 2015, 15:08   #131
avdhesh15's Avatar
Thanked: 543 Times
What I like is the quick turnaround by Ford - within 1 week we have gone from an insurance quote to an investigation! Now eagerly waiting to see the official diagnosis and hope all ends well!
avdhesh15 is offline   (1) Thanks Reply With Quote
Old 19th November 2015, 15:57   #132
dpkbehera's Avatar
Thanked: 205 Times
Post re: Ford EcoSport - Axle breaks on highway. EDIT: Due to accident (details on page 11)
This brings joy to my heart. I would like to appreciate the response of Ford albeit a bit late. I hope Ford learns from this incident and establishes a new benchmark in customer service in India. I would also like to thank TeamBHP for highlighting this issue. The important lesson learnt is "Yes We Can" !!!
dpkbehera is offline   Reply With Quote
Old 19th November 2015, 16:54   #133
black_rider's Avatar
Thanked: 196 Times
Originally Posted by black_rider View Post
I suspect the steering tie rod on passenger side
Originally Posted by Catalyst_delhi View Post
The Tie rod is cheap but super critical. Would be interesting to know if they recently aligned the car and the Jam nut on the tie rod was not torqued properly. It takes a lot for the tie rod to break.
One can just look at the tie rod end, and you can make out of its sheared off, or the nut just came loose.
Originally Posted by aerohit View Post
I believe this is a classic case of Tie Rod failure
I hope the owner has taken pics of Tie Rod End and Tie Rod Joint also.
Went through the pictures again.
Look at the encircled part of attached image. Tie rod looks bent. If tie rod end had broken or somehow come off from the knuckle, tie rod would have been hanging loose, which its not. Its bent, which means it was very much connected as the wheel turned perpendicular to the direction of motion, and was still in place after the mishap.
I am with the people who think the wheel hit that culvert, and the rest of the car somehow just glanced/avoided it.
Ford EcoSport - Axle breaks on highway. EDIT: Due to accident (details on page 11)-img20151101wa0029.jpg
black_rider is offline   (8) Thanks Reply With Quote
Old 19th November 2015, 16:59   #134
Vinodh_Gowda's Avatar
Thanked: 214 Times
Have to agree with your observation.
Also, it's good from FORD's part to hold an inquiry into this incident and hope it is transparent and ethical enough to come up with the exact cause so as to avoid unwarranted frustration at the owners and the future owners of this good car.
Vinodh_Gowda is online now   Reply With Quote
Old 19th November 2015, 17:10   #135
Thanked: 82 Times
Talking about Tie rods, found good basic stuff to read at http://www.agcoauto.com/content/news/p2_articleid/184
I believe this supports black_rider's post above
KomS_CarLog is offline   (1) Thanks Reply With Quote
Nissan's *Student Brand Manager* Program. EDIT: Details of 2012 programme on Page 2 GTO The Indian Car Scene 26 21st June 2013 10:35
Toyota to launch the Etios and Liva facelift. EDIT : Launched (details on Page 4) sarathlal The Indian Car Scene 190 27th March 2013 16:13
SCOOP! Ford EcoSport Details Revealed. EDIT : Now, caught testing! Scorcher The International Automotive Scene 39 5th January 2012 00:20
Hyundai i10 facelift EDIT: Pic on Page 7, Brochure on page 18 Simhi The Indian Car Scene 451 21st December 2010 16:05
New Tata Indigo Manza Details : Brochure on Page 36 EDIT : Now launched sidindica The Indian Car Scene 689 15th October 2009 16:37
