View Poll Results: Your preferred oil change interval?
Whatever the manufacturer recommends 88 27.59%
5,000 - 7,500 kms 66 20.69%
7,600 - 10,000 kms 122 38.24%
10,100 - 15,000 kms 39 12.23%
Over 15,000 kms (seriously??) 4 1.25%
Voters: 319. You may not vote on this poll
Old 9th December 2015, 11:37   #106
srivatsahg's Avatar
Thanked: 85 Times
Default Re: What oil change interval do you adhere to?
Originally Posted by NST440 View Post
They also topped up the brake fluid, power steering fluid and engine coolant.
Am i risking something here by not changing the coolant & or brake fluid completely
No issues, as long as you're not observing anything strange w.r.t Engine temperature gauge on your Instrument cluster. Just remember that you're getting it serviced as per / ahead of schedule.
I would suggest you to change the oil around 23000 (on a safer side).And change of the oil filter, air filter, diesel filter and AC filter annually. i.e. at your third service or 30,000 kms whichever comes earlier.
Last edited by srivatsahg : 9th December 2015 at 11:39. Reason: Additional information provided on Engine Temperature
srivatsahg is offline   (1) Thanks Reply With Quote
Old 9th December 2015, 12:11   #107
Thanked: 34 Times
Around 5000 kms on both the cars. The interval for my Mazda is 10K, however i go in for a change at every 5K as my driving is a mix of traffic/ highways.
For the Brio it is 5K Kms or whenever i am available.
On my motorbike, i used to change the oil every 1-1.2K Kms or a month.
srs_shetty87 is offline   Reply With Quote
Old 9th December 2015, 12:26   #108
Manoj2268's Avatar
Thanked: 85 Times
Once every 7500 kms. I travel nearly 100 kms to and from work and err on the side of caution as it has a retrofitted CNG kit.
Manoj2268 is offline   Reply With Quote
Old 17th March 2016, 13:07   #109
mxh
mxh's Avatar
Thanked: 173 Times
Infractions: 0/1 (4)
Originally Posted by globemaster View Post
Honda recommends service at 6 month 10,000 kilometers intervals. However I change my oil at every 6 months. 99% of the time my car eats up around 6 to 7 K Kilometers by that time. I was told by my ASC that the OEM oil for the diesel City is fully synthetic variety. However it costs 1300 for 4 litres. Is this okay?
Bhpians: I read the thread on what oil to use and got totally confused with so many options. I am planning on using Mobil next time.
Take a look at your service invoice. For my Honda City what my service station used by default is 5W-30 mineral which was specified in the invoice. But what is recommended according to the manual is 0W-20 for higher fuel efficiency. Has anyone tried this oil? Also someone mentioned that if you go for fully synthetic oil then Honda is ok with yearly oil changes.
There needs to be an additional item in this poll though of less than 5000km. Since there are many who don't have heavy running and change oil due to time and not distance. In fact, Scotty Kilmer, an expert car mechanic on YouTube specifically recommends oil changes at 3000 miles which is 4800km for mineral and around 7000 miles for full synthetic. But he recommends changing oil twice a year in both cases.
There are other factors too. In a city with nightmare traffic like Mumbai, my daily running to work is only 17km to and fro, but this journey can take 1.5 hours and sometimes even more. This kind of usage cannot be compared to someone who does the same distance in half an hour with few gear shifts.
mxh is offline   Reply With Quote
Old 8th September 2016, 17:53   #110
vrprabhu's Avatar
Thanked: 319 Times
.... So, I'd -vote for 7.5k - 10k interval.
All the other cars, the Fiesta, The ikon, The Palio once a year.
I have a Palio which is more than 10 years old (< 50,000 kms on the odo).
Used to get the oil changed between 6 to 9 months (mostly mineral : Castrol / Mobil). The owner's manual says oil change be done every 7,500 kms or 18 months (whichever is earlier)
This time, decided to wait for 18 months (as my running is hardly 5,000 kms a year - once a week drive to the office and one 100+ km trip a month is my usual travel), as I had switched over to Shell Helix HX7 10W40 (from Mobil Super 1000 15W40, after doing a complete engine flush).
However, after about 9 - 10 months, the smoothness of shift was gone and it was getting notchy (Distance driven 3,000+ kms).
Replaced the oil (same HX7 - Rs. 395/l, Fiat Oil Filter - Rs. 164/-) last week. Voila! Not only the smoothness has come back, even the engine seems to purr
Guess that the oil change interval is 'INDICATIVE' and the driver will be better able to judge a change / drop in performance....
vrprabhu is offline   Reply With Quote
Old 8th September 2016, 20:29   #111
McLaren Rulez's Avatar
Thanked: 401 Times
For those who want to change their own oil but don't have the space/tools to drain the car from underneath, try getting a vacuum oil extractor (automatic or manual) that extracts oil from the top through suction.
McLaren Rulez is offline   (1) Thanks Reply With Quote
Engine Oil Change : Paid Service vs Buying Oil yourself vs Full DIY neosmart Technical Stuff 76 19th August 2015 18:01
DIY: Mercedes W124 Oil Change & Pela 650 Engine Oil Extractor DeepakMenon DIY - Do it yourself 19 4th May 2015 14:45
Can you change the time interval set for intermittent wipers? girlieonwheels Technical Stuff 14 27th August 2011 11:43
Peugeot XDP oil change interval satish.rpr 4x4 Technical 7 4th July 2011 20:51
Oil change interval - why the difference for a hatch and sedan ? supremeBaleno Technical Stuff 38 12th August 2008 18:14
