Old 15th September 2006, 12:12   #1
DRC
DRC's Avatar
Thanked: 48 Times
Default Rhythmic sound from some where...
Techies,
One of my fried who has a Palio 1.2, has some problem. Tuesday, he had a coolant drain out, flat tyre and some rhythmic sound coming out of somewhere.
Coolant, issue got sorted out, culprit, a rusted dummy plug which had developed a hole and let go all the coolant.
This fliping sound is becoming hard to solve. Javali motors told that they have checked, the wheel bearing, half shaft, breaks, etc.. everything is fine but the sound still persists. Their speculation is " there are 3 bearings inside the gearbox, one of them may be shot. They need to open the gear box to find this problem"
I am growing concerned. Can just a flippoing sound get so serious. Any thoughts, out of the box ideas before opening the box are appreciated..
Please help.
DRC is offline   Reply With Quote
Old 15th September 2006, 13:13   #2
Thanked: 9 Times
Where is the sound coming from?
Floyd de Souza is offline   Reply With Quote
Old 15th September 2006, 14:23   #3
tsk1979's Avatar
Thanked: 16,422 Times
Rotate the tyres and see if nature of sound chages.
Best way is to cruise at 60-80kmph in neutral on a quiet road with windows rolled up.
If its flip flop kinda rythemic, the belt inside the tyre could be shot.
Does the car wobble slightly at low speeds on smooth roads(10kmph)? and gets okay at higher speeds?
Old 15th September 2006, 14:29   #4
Pankaj401's Avatar
Is this a clicking sound? Do you get it when you press on throttle and then let it go immediately? If that is the case it could indeed be the gearbox mainshaft bearing(s).
Pankaj401 is offline   Reply With Quote
Old 15th September 2006, 15:06   #5
DRC
DRC's Avatar
Thanked: 48 Times
Sound appears to be coming from left front wheels,
Checked everything. Changing the wheels, also. but the problem persists.
Old 16th September 2006, 20:30   #6
2fast4u's Avatar
i am just guessing could be some thing has got into the rubber boot in drive shafts / cv. try moving wheels on a hoist / jack to see if sound persists.
2fast4u is offline   Reply With Quote
Old 18th September 2006, 11:34   #7
DRC
DRC's Avatar
Thanked: 48 Times
Sure will try...
Car is now in Greentracks... Will be visiting today/
Old 18th September 2006, 16:26   #8
Neel's Avatar
Thanked: 24 Times
Check your front brakes and see if the discs are fine.
-Neel
Neel is offline   Reply With Quote
Figo's screeching sound (and some other problems) solved! anilisanil Technical Stuff 7 4th September 2010 00:10
Audi's Sound Concept cabin defines auditory excess: 62 speaker surround-sound ! dar3dev|l In-Car Entertainment 10 22nd June 2010 15:23
Help in ICE-hearing some hizz sound from FE Components dkarthikkeyan In-Car Entertainment 6 22nd February 2010 09:13
Some ideas how I want to do some mods to my M-800 chokxxi90210 Modifications & Accessories 1 21st March 2008 08:16
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
