| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jul 2006 Location: surat,gujarat
| I have a 05 Turbo baleno and I have alot of white smoke coming from the exhaust. Friends have told me its probally my head, others say the turbo or fuel from reliance petrol pump. the longer I run it the worse it gets, some days its smoking a little others alot. Also seems to smoke more when I get on the gas, but does smoke at idle. can anyone tell me what should be the proper diameter of oil feed line and oil drain lines from turbo? I was curious to what I should do to determine the problem and what u guys think the problem probally is. Any feedback is good. |
| | #2 (permalink) |
| Senior - BHPian | White smoke isn't good. Usually, it signifies fried rings, letting oil into the chamber, thus resulting in burnt oil and hence, white smoke. Check AFR and compression immediately. Could also be due to busted head gasket letting in oil- check your radiator and see if you find traces of rainbow-coloured patches. Or odd patches, if running anti-freeze coolants. What turbo are you running? Which ECM?
__________________ DAD |
| | #3 (permalink) | |
| Senior - BHPian | Quote:
Just do what I suggested you to do and we shall take things from there. I am pretty sure you have fried your pistons. Viper
__________________ NO ONE DARES COME CLOSE | |
| | #4 (permalink) |
| Distinguished - BHPian ![]() Join Date: Feb 2005 Location: Mumbai-India
| Is it the same baleno which was mentioned in recent thread here http://www.team-bhp.com/forum/modifi...ictures-3.html (My Turbo baleno pictures...) The nick name is similar neo trace & neo_trace so i guess he is the same user, yes neo you have fried your piston rings/ head gasket, time to rebuild your engine this was bound to happen.
__________________ Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap. Last edited by Ford Rocam : 16th September 2006 at 10:34. |
| | #6 (permalink) |
| BHPian Join Date: Jan 2005 Location: mumbai
| 95% its yr rings.. but if u still want to confirm then first chek yr turbo ... if its leaking... also yr turbo oil feed line... if there is a lot of oil press it sometimes tends to throw drops of oil into the turbo which wud cause white smoke.... so u can restrict the line a little bit... if not all this then its time for a rebuild mate... al the best... fs
__________________ nitrous dried but i am still turbo charged |
| | #7 (permalink) |
| Senior - BHPian | It reminds me of Sideways' previous turbo-lancer project. The first time i was checking it out , it was bellowing white smoke and the discussion was about a disintegrated turbo-core.
__________________ hindu.com/mp/2008/08/25/stories/2008082522220200.htm |
| | #8 (permalink) |
| Distinguished - BHPian ![]() | In my case the car used to smoke at first start in the morning. Basically the CHRA had become defective and when the vehicle ws turned off it was letting oil from the turbo housing leak into the exhaust. But once that oil got burnt / evaporated it was fine - i.e. no smoke while running. But in Neo's case it looks like he's fried his engine. Sorry mate.
__________________ Action on the MMST race track, Chennai - 30th & 31st August |
| | #9 (permalink) | |
| Quote:
today i went to mechanic and he ristricted oil feed line with high press regulator then he loosened exhaust manifold and gasket from engine but from engine there were no smoke only u can feel gases by hand, u cant see (i didnt see any white smoke from engine) coolant is fine spark plugs are clean too oil level and pressure are same (as in 2 days) no voice in engine same accelaration and power as i felt before no oil in to intake body or intercooler or BOV Temp. normal of engine and oil no smoke in head pipe( a small pipe betN head and intake air pipe with humidity sensor) __AND today white smoke was showing up low and sometimes only smoking is a yesterday's problem and i replaced new oil feed line 10 days ago New custom made oil feed line was sending more oil in to turbo (i have checked today that in @10 seconds of engine run, oil feed line was sending quite more than a half litre oil to turbo...and i think its very much .....now i have restircted line) i think overfilling oil in the turbo with new bigger dia oil feed line has caused leakage from turbo seals and exhaust is burnning oil Any feedback is good. | |
| | #10 (permalink) |
| well then as per what you have checked the engine is perfect... its definately the turbo.... chek yr oil feed line again n also the oil exit path from the turbo to the chamber... the outlet pipe of the turbo oil line shud be atleast an inch above from where the chamber starts .. orelse the oil wud stay in the turbo causing a leak n throw white smoke... ..it wnt effect yr engine in n e way only the oil level wud decrease n decrease the life of the turbo...... good luck
__________________ nitrous dried but i am still turbo charged Last edited by ZenGT : 17th September 2006 at 18:32. |
| | #11 (permalink) | |
| Senior - BHPian | Seems you have tried out almost everything and most writers are pointing to either fried rings or pistons....Just a suggestion, try filling nirmal petrol (without additives) from a different pump. A friend of mine who uses a Diesel Safari (turbo) had a similar prob and coincidentally used to fill gas from primarily reliance joint or else the Hi-speed from BP. His problem vanished after he changed pumps and started filling normal diesel.. Experts please comment... Quote:
| | #12 (permalink) |
| Distinguished - BHPian ![]() | Neo, you are absolutely right about the oil feed line, would reccomend putting in a 100 jet in between the oil feed line and the turbo to make sure that the feed is continually restricted, another reason why this tends to happen is if the oil out from the turbo does not flow freely into the engine sump, please check as this would cause an immediate turbo failure.
__________________ Learning is a continuos job that keeps me busy. |
| | #14 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
__________________ Learning is a continuos job that keeps me busy. | |
| Thread Tools | |
Similar Threads | ||||
| Esteem 2001 White smoke on Cold start | Slick | Technical Stuff | 9 | 3rd April 2008 02:16 |
| Turbo emits lot of smoke and top speed has gone down | RajTurbo | Technical Stuff | 40 | 22nd March 2007 18:28 |
| black smoke from exhaust | 2fast4u | Technical Stuff | 23 | 31st August 2006 10:07 |
| Dark Greyish Smoke bellows from exhaust pipe | Rahulk76 | Technical Stuff | 7 | 13th March 2006 00:06 |
| Pics : The Cayenne Turbo (Silver and White) | v12 | Super-Cars & Imports in India | 57 | 16th January 2006 19:51 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
