Old 16th September 2006, 11:35   #1
ramkya1's Avatar
Thanked: 368 Times
Arrow Underbelly Protection
Hai BHPns,
I searched and found a thread on Paint and underbelly protection. I have some doubts like:
1. July, 2005, my new fusion got underbelly coat from ford. Subsequently, it has scrapped some bumps and stones and the metal is clearly visible in some areas.
2. Rust can creep through these spots and damage the metal. Also there can be unseen breaches in the underbelly coating where the paint has thinned out.
3. Do we need to do a once-over every year or just touch it up with some anti-rust paint? Ford says what they use is a reasearched rubber-based paint which is not available anywhere else.
4. Which is the best anti-rust off the shelf underbelly product which we can use ourselves?
Thanks in advance for the info.
-- Ramky
ramkya1 is offline   Reply With Quote
Old 16th September 2006, 13:02   #2
nitrous's Avatar
Thanked: 285 Times
Dude, u dont have to worry about the underbelly much.
Just paint/spray it with dinitrol every 2 years or so if u're living near the sea.
PS:Where do u live?
Old 16th September 2006, 13:02   #3
yogi1771's Avatar
Originally Posted by ramkya1
Hai BHPns,
-- Ramky
dont they check it every 6 months i got my underbody coating done bye auto n care with 5yrs warranty they check it every 6 months
yogi1771 is offline   Reply With Quote
Old 16th September 2006, 13:14   #4
nitrous's Avatar
Thanked: 285 Times
U guys care too much about the chassis.
It aint a biggie unless u're planning to own the car so long that u'd lend it to ur grandkids travelling to college.
Old 16th September 2006, 14:34   #5
ramkya1's Avatar
Thanked: 368 Times
Arrow Re Sale And Rust ?
PS:Where do u live?
I live in Ahmedabad; I don't have a 5 year plan on the car
When I sell, the porspective buyer will looks at rust and condition, so protecting it has a commercial value. I have noticed that the corners, hinges and bottom protions of doors are the first victims and also the underbelly. When people buy they look for these tell-tale signs before putting a value to the vehicle.
I am not aware that they check and paint the underbelly as part of the warranty / Total Maintenance plan. Will ask the workshop guys.
Tnx ---- Ramky
Old 16th September 2006, 21:51   #6
srasania's Avatar
Same thing here..got the Under Body Rust Protection done from AutoNCare here,and with a 5 years warranty on it..
I take it to them once a year to get it checked..
-sr
srasania is offline   Reply With Quote
Old 19th September 2006, 05:09   #7
mithun's Avatar
Thanked: 59 Times
What was the total cost for this ?
What is dinitrol ? Would you please explain more ?
Old 18th November 2010, 12:40   #8
Thanked: 24 Times
Have just purchased a new Captiva. The dealer is recomending an under body rust protection coat costing rs 5500 with a 5 year warranty. What I want to know is , is this necessary to be done. As I understand the underbody is treated and painted and should not ordinarily require this.
On a separate note what about a teflon coating for the paint?, Not able to trace out any recent threads on the above 2 points
vgsr is offline   Reply With Quote
Old 18th November 2010, 14:46   #9
rjstyles69's Avatar
Thanked: 795 Times
vgsr don't get fleeced by the dealer and his under-body coating nonsense. You live in Bangalore and we don't live in close proximity to the sea and rust is really seldom seen at-least here.
Teflon coating , check this thread should answer your queries.
Old 18th November 2010, 14:51   #10
libranof1987's Avatar
Thanked: 4,230 Times
The anti-rust coating is for the under-belly of the car and the engine; it is primarily black in colour.
Actually, this coating would have been more helpful and effective in the monsoon. However, it is still quite monsoon in Bangalore!
Nevertheless, I would recommend you get the coating done. (I have got it done on all my cars). It is not something you'd have to keep doing.
About teflon coating, it is for the body; it is mainly to ensure the car maintains shine and dull shots or where colour has come off brighten up.
libranof1987 is offline   Reply With Quote
Old 18th November 2010, 17:22   #11
MileCruncher's Avatar
Thanked: 357 Times
+1 to that.
@vgsr: You don't need underbody rust coating. The sheet metal used for making the body is already galvanised steel which has a coat of paint. Corrosion will only happen if your paint goes off, which will go even with your anti-rust paint. So I say skip it.
Teflon yes, you may want to do that.
MileCruncher is offline   Reply With Quote
K&N filters & protection from water shazikon Modifications & Accessories 23 22nd December 2011 20:13
Engine / underbelly guard for Safari? Alter_Ego Modifications & Accessories 4 20th April 2010 10:01
Paint Protection poncho Modifications & Accessories 25 4th September 2009 19:14
Paint protection shbhrao Technical Stuff 33 13th November 2007 12:57
Paint Protection treatment rchimni Modifications & Accessories 7 16th March 2005 12:29
