Old 28th March 2016, 07:58   #31
ajaypjayaraj's Avatar
Thanked: 1,083 Times
Default Re: Dampers for the BMW 320d (F30) - Koni FSD vs Bilstein B6?
Update:
Went for a long drive on winding roads and a mix of smooth and partly rough patched surfaces. The small vibrations caused by the poor surface is felt a little more than the stock suspension while the larger undulations on the surface is soaked up better than F30's stock suspension. But it does not feel anything like a stiff suspension and it behaves better while soaking up the surface with a more dampened sound and feel which improves the comfort of the driver and occupants. It feels more 'German' now! Cornering ability has improved and if you push it, its that much more fun. Thankfully the roads were almost empty on Sunday afternoon and it was fun on the ghats to use paddles and maintain the pace through turns without feeling loss of traction. During hard braking on uneven surfaces at high speeds, it feels more sure footed than before.
ajaypjayaraj is offline   Reply With Quote
BMW 320d (F30) vs Audi A4 barua Luxury, Imports & Niche 304 20th March 2017 20:45
New Skoda Octavia or Pre-owned BMW F30 320d. EDIT: New 320d booked coolboy007 Sedans 54 17th June 2016 15:41
BMW F30 320D powered by ///M - The Ultimat3 Driving Machine AdiSinghV12 Test-Drives & Initial Ownership Reports 25 21st April 2016 07:27
RS after fitting KONI FSD shocks Bomi Long-Term Ownership Reviews 13 2nd July 2010 20:58
