Old 9th August 2004, 02:31   #1
speedsatya's Avatar
Thanked: 712 Times
guys,
just wanted to know some thing about exhausts.
1.why do some cars have exhausts on the LHS while some on the RHS.
2.while cars have their exhausts pointed downwards why do bikes have them pointed upwards.
satya
speedsatya is offline   Reply With Quote
Old 9th August 2004, 13:09   #2
aadix's Avatar
satya buddy, u got a typo error, check it , u typed rhs twice
aadix is offline   Reply With Quote
Old 9th August 2004, 16:21   #3
killjoy's Avatar
Thanked: 191 Times
Originally Posted by [b
Quote[/b] (speedsatya @ Aug. 09 2004,01:01)]guys,
1.why do some cars have exhausts on the RHS while some on the RHS.
satya
no idea
killjoy is offline   Reply With Quote
Old 9th August 2004, 16:53   #4
Jaggu's Avatar
Thanked: 8,684 Times
vaastu?? lol..
k my guess on RH or LH is, exhausts are designed so that it blows away from the side of the street away from pedestrians.. so in a LT hand drive country (where the vehicle is originally designed) chances of exhaust on to the RT..
up and down.. not really in certain cars basically the bend is to avoid the vacum formed at the rear end at high speeds from burning up the bumper and plastics.. earleir corsas had this prob if i remember correct..
bikes its more to do with aerodynamics and aesthetics..
Old 9th August 2004, 19:25   #5
Shan2nu's Avatar
Thanked: 89 Times
Even in some bikes if you've noticed, the xhaust pipe might be pointing upwards, but the xhaust outlet is usually curved to make it straight.
As far as cars are concerned, i don't think it really makes a difference, it's just a matter of where the company wants it. The Vtec has it's xhaust on the rhs but if you look under the car, the xhaust pipe coming from the engine to the rear wheel, is in the middle.
Regards...
Shan2nu
Old 9th August 2004, 19:46   #6
Jaggu's Avatar
most of the cars have the pipes running in the middle so that they can be accomodated under the hump in the chasis (for ground clearance), unless they have 4 wheel tranny.. and only the end piece will be routed to the sides
Old 11th August 2004, 00:24   #7
Psycho's Avatar
Thanked: 95 Times
Well here are the reasons:
1) As for the LHS and the RHS on Cars it is dependent as to where the fuel tank is located as the tailpipe would be on the other side of that for safety reasons so as not to heat up the fuel tank.
2) As for the bikes the angling of the exhaust upwards gives the exhaust pipe more length hence more area to muffle the sound.
Hope that answers ur query
Old 11th August 2004, 21:13   #8
speedsatya's Avatar
Thanked: 712 Times
thanx everyone
satya
Magnaflow perfomance exhausts shazikon Modifications & Accessories 88 19th May 2018 20:07
Modifying the exhausts of commercial vehicles normally_crazy Commercial Vehicles 6 6th July 2009 18:07
Free Flow exhausts For Maruti Esteem Petrol MPFI n_aditya Modifications & Accessories 66 10th July 2007 14:12
Of Free flow exhausts and Warranties GTO Modifications & Accessories 39 26th December 2006 13:05
4 cylinder and 2 exhausts max8791 Modifications & Accessories 19 7th November 2005 23:55
