Old 30th December 2015, 10:56   #1
ashutoshb's Avatar
Thanked: 880 Times
Default ECU: Can it be traced to the original vehicle?
Dear Gurus,
Kindly allow me to explain the problem, I have been facing.
I own 12 Indica Emax (CNG) vehicles, used as cabs. They are serviced and repaired at one particular Tata authorised service centre in Delhi.
Recently, one of the Indicas was not switching to CNG. Upon detailed inspection, it was found that the ECU had a problem. It was changed, the new one costed around ₹9000.
Now, ECU of another Indica has developed a similar problem, which I find hard to believe.
It might be coincidence, but I suspect, there might be something fishy at the service centre. There is a chance, that someone is trying to make a quick buck, by replacing our vehicle's ECU with someone else's and making money in the process.
My question is, can I somehow find out whether the ECU in my car is the one which came with it from the factory?
I did ask another service centre and they say, an ECM can surely be traced to the original vehicle, but not the ECU.
I have not yet ordered a new one yet, but will only do so when there is no other option left.
ashutoshb is offline   Reply With Quote
Old 30th December 2015, 12:52   #2
Thanked: 462 Times
Default re: ECU: Can it be traced to the original vehicle?
Originally Posted by ashutoshb View Post
Dear Gurus,
In the earlier instance, the car was not switching to CNG. What symptom did you report in the second instance?
If you doubt a scam, please make some mark / signature on the ECUs of all other cars with a marker men. At least in future you will be able to know whether they belong to you or not.
Rahul Bhalgat is offline   (1) Thanks Reply With Quote
Old 30th December 2015, 14:24   #3
HimuraKenshin's Avatar
Thanked: 183 Times
What i advise you to do is get an OBDII toold and connect it to all of your cards and note down the physical hardware number and key ID of each of the ECUs.
Otherwise, this data will only be available at the factory level.
HimuraKenshin is offline   (2) Thanks Reply With Quote
Mumbai - Where can I get original Leather Seat covers Stitched? diesel_power Modifications & Accessories 13 23rd November 2016 09:24
whats better than an original cj3b?? two original cj3b's. 0333 4x4 Vehicles 33 5th March 2009 11:15
can 32-bit ecu's be fitted in e-2 cars speedsatya Technical Stuff 4 12th March 2005 10:55
