Old 19th August 2004, 21:53   #31
Rehaan's Avatar
Thanked: 22,579 Times
Rudra,
Good morning ....it has aldready been done yesterday (as posted above).
As you said, it is quite possible the moisture had something to do with the wire getting ruined.
cya
R
Old 19th August 2004, 22:30   #32
check out the accelarator cable and throttle body sensors connections and where theyve got wet
anshu12420 is offline   Reply With Quote
Old 20th August 2004, 00:55   #33
Rudra Sen's Avatar
Thanked: 4,092 Times
Originally Posted by [b
Quote[/b] (Rehaan @ Aug. 19 2004,20:23)]....it has aldready been done yesterday (as posted above).
Hey what was posted above??? And what was wrong with the car? And Why good morning??
Old 20th August 2004, 03:42   #34
Rehaan's Avatar
Quote[/b] (Rudra Sen @ Aug. 19 2004,23:25)]
Hey what was posted above??? And what was wrong with the car? And Why good morning?? *
Good morning coz you (and now anshuman) are trying to solve a problem thats aldready been solved
As posted on Aug 19th @11:59am
Quote[/b] ]
Well,
Just got my car back last nite. Had no problems with it for the last 2days before giving it to the service center, but gave it anyway.
Apparently there was a problem with one of the wires running to the fuel pump! ( or so they say ). Was repaired under warranty.
cya
R
Old 31st August 2004, 22:11   #35
Rehaan's Avatar
Ok guys,
So i havent driven my car much since i got it back from servicing where they did something to the fuel pump, and changed the sparkplugs and airfilter... hence waited to confirm before i posted this.
Ive noticed that the car does not start up as easily as it used to..... almost to the degree that it is having trouble starting. It takes about 2revolutions more than it normally would to start, and it doesnt seem to be a starter motor problem since it seems just as powerful. Apart from this the car runs fine.... *so i donno if its some kinda fuel pump problem?
What dyu think
cya
R
Old 31st August 2004, 22:27   #36
Rudra Sen's Avatar
May be fuel injector with gumming problem.
Old 31st August 2004, 22:51   #37
Rehaan's Avatar
Quote[/b] (Rudra Sen @ Aug. 31 2004,20:57)]May be fuel injector with gumming problem.
hmmm... that made me think..... maybe some kinda of backflow problem actually.... that the fuel is flowing back down the pipe towards the pump when the car is off... so it takes time to come back up to the engine when the car is cranked!
cya
R
Old 1st September 2004, 09:03   #38
Rudra Sen's Avatar
Try IFTEX if you haven't already. Do this before you take it back to service station.
"Check Engine" light also indicates ECU "relearning" ? anandpadhye Technical Stuff 28 19th August 2017 09:54
What hangs on your Rear view Mirror IQBAL VEERJI Shifting gears 46 17th December 2010 23:32
