Old 19th September 2006, 12:33   #1
agbenny's Avatar
Thanked: 115 Times
How is VGIS functioning in GM cars?, anyone knows? Is is something like a Turbo in Diesel engines?
Thanks in advance.
agbenny is offline   Reply With Quote
Old 19th September 2006, 14:23   #2
DRC
DRC's Avatar
Thanked: 48 Times
Look into their brochure, it will explain.
Basically, the Geometry of the intake system is modified to suite the necessity of torque and speed.
DRC is offline   Reply With Quote
Old 19th September 2006, 17:25   #3
mtnrajdeep's Avatar
Thanked: 101 Times
Originally Posted by agbenny
How is VGIS functioning in GM cars?, anyone knows? Is is something like Turbo in Diesal engines?
Thanks in advance.
VGIS stands for Variable Geometry Intake System. In this system, the length of the intake manifold is varied according to the rpm of the engine. (using a set of flaps that are automatically activated, maybe).
"To provide a smooth power delivery and torque across all engine speeds, the air intake system needs to be narrow and long at low rpm and short and wide at high rpm. Since these are conflicting requirements, most inlet systems are a compromise between low and high rpm performance. Varying the inlet tract gives the best of both worlds and variable intake systems in which the inlet tract length varies depending on the rpm is now increasingly common in many cars.
The Optra 1.6’s Variable Geometry Intake System (VGIS) uses a valve to alter the length of the air intake tract, making it longer when the engine is running low revs and shortening the path of air when the engine is running at higher rpm. This improves throttle response and offers a flatter torque curve and is the main reason for the Optra 1.6’s good driveability."
Source: http://www.indiacar.com/index2.asp?p...oyale_a_sep05/
mtnrajdeep is offline   Reply With Quote
Chevy OPTRA 1.6 VGIS for Sale @ Hyderabad manne Shifting gears 2 19th September 2007 22:30
Why not VVtech . VGIS etc on all the cars? hrishig Technical Stuff 7 31st July 2007 14:02
Optra vgis pertol for ~7.2L : Is it worth?? gava Sedans 25 16th July 2007 11:36
optra VGIS bluenest99 Sedans 0 24th June 2007 01:46
