Old 19th September 2006, 19:17   #1
wolfinstein's Avatar
Default XETA's First service coming up and Brake Issue..!
Hi guys,
Well today my XETA is 4040 Kms old, Since the first service will come up by next weekend or so..Just wanted to enquire What should one get checked up in a Indica besides engine oil change, filter change...!
Secondly,
Now that the monsoons are over, I have noticed that XETA's brake are becoming sluggish than before, Earlier the car used to stop immediately now the braking time and distance has increased.
I have noticed that the wheel bearning cover has got a rust layer and so has the Brake disc on its circumference.
Advice, How to get this rectified, Since today I almost ran into a donkey on the 34 Sector Area in Noida, the dumbo just ran in between the road..!
wolfinstein is offline   Reply With Quote
Old 20th September 2006, 23:09   #2
Some Help Guys....! Please
Old 20th September 2006, 23:22   #3
Thanked: 352 Times
Originally Posted by wolfinstein
Hi guys,
i think it is quite common....
tifosikrishna is offline   Reply With Quote
Old 20th September 2006, 23:26   #4
Ya , I understand the brake cover having the rust, but sluggishness in brake usage after the rains has me worried, What could it be..I don;t think its time for the brake pads to wear out so soon, On my lancer they wear off after 20- 28 K Kms..!
Old 21st September 2006, 08:54   #5
condor's Avatar
Thanked: 4,894 Times
Wolf, have posted this point previously, separately. But here goes:
If you are getting an oil-change, Check engine oil level after you get the car back. The recommended level can be higher than the upper level on the dip-stick. Have noticed this on our Marina & Sumo.
Marina's recommended is 5.5 litres, but 5.0 litres is enough to bring it to the upper level on the dip-stick.
Old 21st September 2006, 11:36   #6
tsk1979's Avatar
Thanked: 16,418 Times
The brake pads are okay most probably.
In indica such problem is rectified by bleeding the system.
Most probably you have moisture/air in the brake system.
They will drain the brake fliud, put in new one and expel air from the system.
Tata Indica e-xeta petrol with 17.1 kmpl and e-xeta LPG sidindica The Indian Car Scene 7 9th July 2011 12:39
Fiat Grande Punto: Buying, First Service and first 3 months lawyer123 Test-Drives & Initial Ownership Reports 17 29th May 2010 18:18
Indica Xeta - First Experience-How Xeta won the race nirmalkumar Test-Drives & Initial Ownership Reports 12 20th April 2008 16:41
Only brake OR clutch+brake swiftcrazy Technical Stuff 8 10th July 2007 23:19
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
