Thread Tools
Old 20th September 2006, 12:26   #1 (permalink)
razor4077's Avatar
Question
Hi all,
I own a Santro XG which is a shade over a year old. Recently, my front seats have started making an irritating "creaking" noise which refuses to go away. I went to a couple of Hyundai workshops and a local mechanic. They did the same thing - take the seat out, grease the joints, tighten everything and stick it back in. Solved the problem for a day or so, then the noise came back.
Any idea what the cause could be, and what the solution is? I'm getting fed up of this sound.
Also, any idea if seats can be replaced in the warranty period?
Any help will be appreciated...
Thanks!
razor4077 is offline   Reply With Quote
Old 20th September 2006, 12:42   #2 (permalink)
jkdas's Avatar
My XIng too has the same problem but with only teh co-passenger seat!
__________________
"She may not look like much, but she's got it where it counts, kid."
Old 20th September 2006, 16:56   #3 (permalink)
aZa
aZa's Avatar
hey nothing like that on my car, i had got my seats removed and dismantled for fitting of seatcovers. there isn't much there to "squeak" get it greased up what else.
__________________
-[ " If the ride is more fly, then you must buy. " - Snoop Dogg ]-
Old 20th September 2006, 18:08   #4 (permalink)
razor4077's Avatar
got everything greased up... but to no effect.
another point to consider... my car did take a dunking in a recent flood, where some water came into the cabin. could this be a factor?
Old 20th September 2006, 18:50   #5 (permalink)
Team-BHP Moderator
normally_crazy's Avatar
Food for thought , naughty deeds eh Jk ?
btw - do the seats in the santro have springs under the foam (sorry if that sounds a bit silly) ? if yes you could check them out !
normally_crazy is offline   Reply With Quote
Old 21st September 2006, 05:35   #6 (permalink)
WILDTHING's Avatar
Cool Squeeky Seats.
My best openion would be to install a loud music system so that it drowns out the sound of the squeeky seats or just instal a loud exhaust....
Just kiddin,
the noise probably is from where u fit the screws below to tighten the seats, Do not greese it rather have a carpet piece with a hole between placed under the seat before u tighten the screw, It will stop the noise,Do not let the metal that is your seat and your body of the car touch when the screw is fitted by placing that Carpet piece .
cheers.
__________________
Full Throttle!!!!
WILDTHING is offline   Reply With Quote
Old 21st September 2006, 12:41   #7 (permalink)
razor4077's Avatar
@n_crazy: heh, its ironical... this car hasn't seen many "naughty deeds" and the seats creak, while my old santro was a veteran in that field and didn't utter a squeak
@wildthing: thanks for the suggestion... will see if that helps.
Old 28th October 2006, 12:06   #8 (permalink)
elf
elf's Avatar
@razor4077: Had the same problem. It stems from either:
#1. Your seat track bolts which attatch the seat to the car; or
#2. Springs below / within the seat foam.
If it's #1, then a piece of flat carpet between the bolts & the body should do it.
If #2, then WD40 sprayed every once in a while.
And yes, turning up the volume on your ICE generally drowns out the squeaks / rattles / sounds, though it's a bad idea when you want some peace.
elf is offline   Reply With Quote
Old 30th October 2006, 15:55   #9 (permalink)
suren181's Avatar
Odd it hasnt happened to my four year old Santro.... could it be just that I Hvent upgrade my ICE (the Naughty Deeds part of it i.e)
suren181 is offline   Reply With Quote
Thread Tools
seats in chennai bottle Modifications & Accessories 49 30th August 2008 10:44
my SWIFT is creaking passioncool74 Technical Stuff 3 7th November 2006 09:32
Baleno Creaking Roof kiranpashtakar Technical Stuff 17 18th October 2006 12:47
Recaro seats street racer Shifting gears 5 24th December 2005 09:19
Seats dinya Modifications & Accessories 9 22nd November 2005 16:25
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
