Closed Thread
Old 20th September 2006, 15:54   #1
da MotorHead's Avatar
Hi Folks/ and all technical gurus,
My Octi RS just finished 20000. The cruise control system which i so fondly use on the toll road did'nt work today. I checked the manual for fuses, but apparantly there is a fuse for everything but cruise control. Although the car is under warranty, I'm scared to take to the showroom. God knows how much they'll rip me off. Skoda A.S.S is not news.
Does anyone have any idea as to what could have happened. That way atleast they'll not try to fool me. The third service is due in 500 kms.
Please advise,, and fast..
Thanks,
dMH
da MotorHead is offline
Old 20th September 2006, 16:15   #2
OK stupid as this question may be.. is there a manual override for the OD like there is on the L&K? If so was it off.. coz the same thing happened to my Dad on the expressway once and I had a hearty laugh at his expence.. had the manual override thats located on the indicator side turned off..
2L8uLoose is offline
Old 20th September 2006, 16:21   #3
Frankly, hows the question stupid , i have no clue. And i don't know what OD is. The Cruise control switch is turned on and when i use the slider or the SET button to activate the system or maintain a fixed speed, nothing happens. The car starts slowing down instead of maintaining that speed.
Old 20th September 2006, 16:52   #4
dMH, here is a link I got from Google. It may help but I think that this is something that you should get the dealer to check ASAP. A malfunctioning cruise control system may lead to dangerous situations if it suddenly starts to acclerate the car when you dont want it to.
1. http://www.popularmechanics.com/auto...tml?page=1&c=y
2. a BMW owner bemoans his car's curise control failure -- but not much help from other forum members here!!!!
http://forums.bimmerforums.com/forum...ferrerid=56200
Good luck,
Ravi.
roovee is offline
Old 20th September 2006, 18:12   #5
sinhsha's Avatar
Thanked: 71 Times
Hey I am quite sure it's only fuse blown. Check your manual once again and check all the fuses in the fuse panel in the dash as well as inside the engine compartment (over the battery). If all fuses are ok then check the relays. It's nothing but most probably a fuse blown or a relay blown (though unlikely). Driving on cruise at low speed in undulating surface for prolonged time (lot's of uphills and down hills) create current overload in the system and fuse is of low amp to get blown rather than damaging the system.
sinhsha is offline
Old 20th September 2006, 19:05   #6
Ok roovee i checked the link. Thanks. I found that none of the break lights are functional which explains the cruise control malfunction. But I also checked the fuse for the brake lights. its fine. So now i have a new problem.
dMH
Old 20th September 2006, 21:23   #7
Thanked: 89,308 Times
You really havent mentioned whether an expert has had a look at it. Dont drag this anymore....just have the dealer personnel or someone who is familiar with RS have a look at it.
I think this storys ending will be like looking for your glasses all over the house.........and then finding them on your forehead.
GTO is offline
Old 20th September 2006, 21:33   #8
Actually i agree with GTO. I'll show to a dealer and post the final result.
dMH
Old 20th September 2006, 21:41   #9
Mpower's Avatar
Thanked: 1,682 Times
OD-off button? Is the car an automatic?
Mpower is offline
Old 21st September 2006, 09:25   #10
Nope Regular 5 speed Manual.
Old 21st September 2006, 20:12   #11
Ok, My last post for the thread. Took the car to the Dealer. The brake switch malfunctioned and he changed it under warranty. For the first time i got reasonably good service and spent nothing. The cruise control is back to normal.
Happy Motoring,
dMH
Old 21st September 2006, 22:06   #12
Thanked: 9,723 Times
Thanks for the answer
Thread closed
ajmat is offline
Closed Thread
Aftermarket Cruise Control turbo_c Technical Stuff 45 14th November 2017 22:04
Royal Enfield Thunderbird 500 : Brakes Failed : No Quality Control shan2129 Motorbikes 45 21st April 2016 11:24
Multi map selection using the cruise control on my Octavia vRS Born2Slow Technical Stuff 17 13th March 2012 21:43
Active Cruise Control in BMW sanjaykk The International Automotive Scene 24 25th February 2008 10:50
Installing a cruise control Tarun Modifications & Accessories 52 27th March 2005 21:24
