Old 20th September 2006, 19:55   #1
Question
Hello,
I have heard few telling, engine RPM/Speed can rising automatically without pressing accelerator pedal of an Automatic Transmission vehicle in drive position (gear lever).
Is this true? Can this happen?
If Yes, what may be the possible cause and how to find whether what they say is true.
Will this data be stored in ECU/ECM, what are the possible analysis procedure.
shaktideep is offline   Reply With Quote
Old 20th September 2006, 21:37   #2
Shan2nu's Avatar
Thanked: 89 Times
This is really wierd but it's true, when i test drove the Civic A/T, the tacho would rise without change in speedo reading.
I've never seen this on any M/T. Haven't driven many A/T though.
Shan2nu
Old 21st September 2006, 15:42   #3
This doesnt happen . As most of us are not used to AT , we may ourself step on the Acc pedal without our knowledge. Other there is nothing which can make the rpm shoot up!
sniffertoy is offline   Reply With Quote
Old 21st September 2006, 19:55   #4
Shan2nu's Avatar
Thanked: 89 Times
I did press the acc pedal but i was refering to the inconsistency between the tacho and speedo. On a M/T the tacho cannot rise without the speed increasing (unless you've got a bad clutch).
Shan2nu
Old 21st September 2006, 20:19   #5
condor's Avatar
Thanked: 4,897 Times
Can you pls elaborate?
Is your gear lever in 'D' ?
Is your car in motion when this is supposed to happen?
Typically, if your car is at rest [gear lever not in 'D'], then the engine is idling, and tacho would should idling speed.
If the car is in motion, and you get your foot off the acclerator, the engine rpm should start decreasing, till the gears are changed internally, when it may show a slight increase in engine rpm before it continues to fall. This is assuming you have not engaged Cruise control.
[Been a while since I drove an A/T, so guys, pls correct me if I am wrong here .. tacho should continue to show a steady drop]
If Cruise Control is engaged, the engine rpm may drop / rise depending on gradient.
Old 21st September 2006, 22:51   #6
vivekiny2k's Avatar
Thanked: 184 Times
if the transmission has to shift down, the tacho would rise even if speedo is constant.
I have observed this when:
1. I press accelerator too hard. it shifts down to give that extra punch.
2. uphill enountered. it shifts down to give that extra torque.
in both cases the tacho goes up.
if this was not the case, the mechanism which takes care of these condition can be faulty, and give a false downshift causing ur tacho to rise.
experts on ECU/AT mechanism?
EDIT: to 4th post of shan2nu, I am sure u know it but i have observed that in A/T different cars take different reaction time to upshift/downshift...and hence tacho keeps shifting basd on the conditions i mentioned above. it's like it is not able to make up it's mind on which gear to settle.
vivekiny2k is offline   Reply With Quote
Old 22nd February 2011, 16:39   #7
niteshbids's Avatar
Thanked: 64 Times
Default Re: Can Engine RPM/Speed shoots up automatically in AT vehicle
Hi All,
even though it is quite an old thread, i just bumped onto it today and thought i'd give my 20cents for the benefit of everyone interested.
I am an engineer working on auto transmissions and i know what you guys are talking about here. The reason that you don't always see a linear corelation between the engine speed and the vehicle speed as in the case of an MT vehicle is that in an AT vehicle, you don't have a clutch between the engine and transmission. There is a torque converter instead. A clutch would give a 1:1 sped ratio (the engine speed and transmission input speed are same) unless the clutch is worn out. The torque converter on the other hand uses fluid to transfer the torque and has a variable speed ratio (the engine speed can be higher or equal to the transmission input shaft). As a result, when you press the accelerator pedal, the engine revvs up first and then the vehicle starts speeding up.
The downside to it is obvious - you feel a lag or feel that the engine is revving up without any acceleration, but the upside is that after that lag is over, you get more torque going into the transmission as that is what the torque converter does - It multiplies the torque going into the transmission.
niteshbids is online now   Reply With Quote
RPM shoots up when clutch depressed rao_battula Technical Stuff 83 27th September 2016 15:28
RPM shoots up when changing gears lambdaplus Technical Stuff 110 3rd February 2013 03:23
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
Weak clutch on Esteem - Car speed not matching engine RPM gaurav.28ch Technical Stuff 2 26th November 2008 17:47
RPM shoots up... gkrishn Technical Stuff 11 21st July 2005 23:02
