View Poll Results: Your choice of accelerator?
Organ-type 186 69.40%
Suspended 82 30.60%
Voters: 268. You may not vote on this poll
Old 25th February 2016, 12:26   #76
Thanked: 40 Times
Default Re: What type of Accelerator pedal do you prefer - Organ vs Suspended?
Voted for the organ type. I have used it on a BMW 3 series and its very convenient to use. You can rest your foot at an angle comfortable to you and floor it as much needed. I personally found this better in flooring the pedal too. I find flooring the suspended pedal a little less straightforward.
Horizon85 is offline   Reply With Quote
Old 25th February 2016, 15:27   #77
Thanked: 136 Times
In my humble opinion, i guess most of the advanced driving techniques like heel-toe shifts, left foot braking were conceptualized keeping in mind an organ type A-pedal.
I have been experimenting with these techniques and in a floating pedal setup even with my size 11 foot, i find it quite difficult to execute the heel-toe down shifts. What i do instead when i drive a floating pedal setup is, i use a 50-50 split of my foot to tackle both the brake and accelerator pedal, which again is pretty risky since there is always a possibility that the foot might slip off one of the pedals.
Same thing goes for left foot braking since in a floating setup its very easy to hit the wrong pedal when you are running through your paces.
Another thing i observed is that with a floating type setup once has to move the legs more since your foot has to either travel with the pedal or once has to slip his foot over the pedal with increase input.
But with an organ type setup your foot always rests on the pedal and firmly anchored to the floor and with the correct seating position once just needs to flex his ankle to dial in the inputs.
Hence having driven both types of pedal setups , as per my personal observations and preferences , i have voted for the organ type pedal setup.
adneo is offline   Reply With Quote
Old 29th February 2016, 15:12   #78
bigblackshark's Avatar
Thanked: 31 Times
Organ type all the way, had it on the civic and it was perfect, now since i drive a city i miss it :(
bigblackshark is offline   Reply With Quote
Old 29th February 2016, 16:01   #79
Thanked: 34 Times
I remember the old Omni that my father had, it had the Organ type accelerator. It was so easy and natural. Then he bought 800 that had Suspended accelerator. It was weird. I had to force my foot on it, at times with toes, before getting used to it.
Voted for Organ type. This is how accelerators should be.
sngautam is offline   Reply With Quote
swift diesel accelerator pedal issue RJ555 Technical Stuff 5 23rd November 2009 14:47
Santro: Return spring for Accelerator and brake pedal? ajith Modifications & Accessories 18 2nd April 2008 20:20
Vibration on accelerator pedal while using the horn kaushik_s Technical Stuff 2 8th September 2007 13:59
Which type of body styling do you prefer? Ajay-GD Modifications & Accessories 34 7th August 2007 20:44
