Old 21st September 2006, 01:34   #1
abhibh's Avatar
Thanked: 34 Times
Default Is this possible ?
I dont know how to put this in front but i will try my best to elaborate it...
Till no i use to thought that if i shift from a higher gear to a lower gear in high speed the car will do sudden breaking. (Tried it 2 times and this happened) but today when i was just chatting with my frnd in dehradhun he told me he has driven a lancer near his place in which if he shifts from 4th gear to 3rd gear at speed of 100 there is no sudden breaking etc...
I mean is this possible ?? If yes how ?
P.S. Please tell me if you are not able to understand my question.
Thanks.
Old 21st September 2006, 04:29   #2
Thil's Avatar
Originally Posted by abhibh
Thanks.
It depends on the RPM level and the clutch engagement at the time shifting.I am sure your friend would have shifted from higher gear to lower gear during lower RPM level and slight clutch engagement.
Engine breaking is a good way to control the vehicle if used properly.
Thil is offline   Reply With Quote
Old 21st September 2006, 08:58   #3
gd1418's Avatar
Thanked: 656 Times
Default Braking
There would be a slight drop in the vehicle speed and the revvs will go higher. The engine whine will be increased. The sudden breaking feel may not be there at a speed exceeding 100 kms while shifting down from 4th to 3rd..
Thanks.
Autocop remote repair possible? mohit Modifications & Accessories 24 8th November 2017 15:41
Is a Rs 1 lakh car possible?? v12 The Indian Car Scene 28 13th February 2006 19:13
Fiat: Tata Possible Partner In India hasopi The Indian Car Scene 25 25th April 2005 22:02
Mahindras running on pure kerosine - is this possible???? normally_crazy Technical Stuff 6 12th January 2005 01:16
