Old 10th June 2004, 14:36   #1
VMG
VMG's Avatar
Thanked: 19 Times
Hi
Anyone has tried this Turbo Jet Diesel from HP? Any comments please. I own a Scorpio.
Also any road test results on Lancer 1.8.
Thanks.
VMG is offline   Reply With Quote
Old 13th June 2004, 01:16   #2
Revvmaster's Avatar
Thanked: 45 Times
Hi VMG
Lancer 1.8 has been driven by 3 of the moderators here. The link to that thread is here
Lancer 1.8 INVEX Driven
Revv
Revvmaster is offline   Reply With Quote
Old 13th June 2004, 11:37   #3
hi vmg
have been using the turbo jet diesel in my tata 207di for quiet some time now, the mileage has increased by around 2kmpl & less fume from the rear
sanket
sanket12 is offline   Reply With Quote
Old 13th June 2004, 17:53   #4
Thanked: 103,674 Times
Turbo-Jet Diesel is nothing but regular diesel with some additives that keep your fuel delivery system free of any dirt and deposits.
It doesnt give you additional power, and doubt that it will lead to anymore fuel efficiency either.
Old 2nd October 2004, 16:57   #5
I have been using Turbo Jet in my VW , it has surely increased the mileage and the exhaust is clean, Engine noise is also softer than before.
toyota is offline   Reply With Quote
Old 2nd October 2004, 17:12   #6
normally_crazy's Avatar
Thanked: 394 Times
it smoothens the engine , which sounds more silent ...and pick is very marginally increased. FE again depends on the way u drive but i dont see any change in FE happening
cheers
normally_crazy is offline   Reply With Quote
Old 2nd October 2004, 21:12   #7
Rudra Sen's Avatar
Thanked: 4,295 Times
Originally Posted by [b
Quote[/b] (normally_crazy @ Oct. 02 2004,15:42)]it smoothens the engine , which sounds more silent ...and pick is very marginally increased.
...And you keep buying chain everytime before you go to bunk
Renaissance of my JET - White FIAT Linea T-Jet+ (27,000 Kms Up) Sathya_sc Test-Drives & Initial Ownership Reports 225 4th August 2014 20:29
Fuelled FIRE into my (T)JET - The Fiat Linea T-Jet bnzjon Test-Drives & Initial Ownership Reports 123 12th May 2013 00:16
Jet no longer operates Airbus (jet) between Bangalore and Hyderabad! androdev Shifting gears 17 22nd December 2008 07:29
