Closed Thread
Old 4th October 2004, 16:09   #1
drifter's Avatar
Thanked: 13 Times
Mod Note : Please continue the discussion in this thread (How to detect *Odometer Fraud*). Thanks
hey guys,
i was wondering if theres ne way to clock the digital odometers we r getting in cars these days...like the one on an accent crdi.
I dont intend to clock my car...but jus wanted to know how it can be done if it can be done in the first place.
Last edited by GTO : 5th February 2013 at 13:19. Reason: Adding link to new thread
drifter is offline
Old 4th October 2004, 16:14   #2
Thanked: 9,917 Times
It can be done - I have seen it done on a BMW - a colleague had exceeded the annual milaege allowed for his leased 530d so he got the car serviced by a BMW specialist to avoid the official BMW service record being updated and then they plugged in a laptop and shaved 2000km off. In fact, it is easier to tamper compared to mechanical odometers
ajmat is offline
Old 4th October 2004, 16:37   #3
Domnic's Avatar
Yeah its true, Simpler than a mech odo. Plug in, if the system using has the rights you can change it. For example Ford dealers can not change any variables in the car, all they an do is clear error codes, flash the memory and change small variables such as fuel type etc as they are not given the rights by the company. But off late you do get hand held reprogrammers which can help out in shaving off a few thousand kms . Do a search on google... you will get a million sites with the info you want.
Dom
Domnic is offline
Old 4th October 2004, 16:43   #4
drifter's Avatar
Thanked: 13 Times
thanx....im on google right now.
drifter is offline
Old 4th October 2004, 16:46   #5
They call it "mileage correction services"
ajmat is offline
Old 4th October 2004, 16:54   #6
drifter's Avatar
Thanked: 13 Times
One more question...
if i take out the battery for some amount of time...will it reset the ecu? n will the odometer be affected? n resetting of the ecu....is it ok?
drifter is offline
Old 4th October 2004, 17:28   #7
Thanked: 91,846 Times
Topic moved to Technical stuff
GTO is offline
Old 4th October 2004, 18:41   #8
SLK
SLK's Avatar
Thanked: 185 Times
well.. wagonR/alto have a digital ODO, it doesn't reset by disconnecting the battery....
Digital ODOs don't count backwards while reversing the car... .. ha
onething....
do all cars have electronic speedo?
i.e u switch off the engine... and the speedo shows Zero!
SLK is offline
Old 4th October 2004, 22:15   #9
drifter's Avatar
Thanked: 13 Times
yeah while rolling with the ignition off....my speedo shows zero.
drifter is offline
Closed Thread
Photoshop/Digital Art thread Shan2nu Shifting gears 1873 22nd August 2017 01:32
SET2 DIGITAL Rudra Sen Shifting gears 15 6th July 2007 08:59
What brand is your digital music player? revtech Gadgets, Computers & Software 28 16th July 2005 22:08
help in buying a digital cam speedsatya Gadgets, Computers & Software 39 8th April 2005 20:15
DIGITAL. Where I live.. Rudra Sen Shifting gears 8 28th June 2004 16:47
