Closed Thread
Old 23rd September 2006, 22:25   #1
Thanked: 22 Times
Default Can A Diesel Engine be put in Wagon R ?
i would like to know if a wagonr lxi be diesel fitted, if yes what engine to be fitted and where can it be done
raja_ys is offline
Old 24th September 2006, 08:33   #2
gd1418's Avatar
Thanked: 656 Times
Default WagonR diesel
Instead of going through the hassle of retrofitting, why don't you wait till Dec? I've heard a rumour that they are coming out with a Swift diesel and if it is successful then will introduce a diesel variant for all models..
gd1418 is offline
Old 24th September 2006, 21:03   #3
esteem_lover's Avatar
Thanked: 451 Times
why not ? i think the peugot diesel that comes in the zen or the esteem would easily go into the wagonr. but why would you want to do that ? if you are thinking of fuel cost, just fit a lpg kit around 18k & you are on your way.
p.s if you are particular about the diesel, then sell the wagon r & get a diesel zen, that is a much better option.
esteem_lover is offline
Old 25th September 2006, 01:30   #4
Zappo's Avatar
Thanked: 2,080 Times
I am not very sure that the Wagon-R's small bonnet space can accomodate a diesel engine so easily. In fact even Hyundai has decided to launch a separate diesel model to be put alongside its Santro simply because the Santro could not accomodate a diesel in that bonnet. And IMO Wagon-R has even lesser bonnet space. Even if you find a small diesel (say a Daihatsu one) that could go in your choices will be pretty limited.
Also, the hassles are ffar too many for such a conversion. A far better option is to either go for LPG conversion or buy a diesel car off the shelf.
Zappo is offline
Old 25th September 2006, 02:17   #5
Fuelled's Avatar
I think going for LPG would make more sense. Esp. so cause Maruti kits the new Wagon R with it. So sourcing all the compatible parts will be very easy.
Engine swapping is a big(complex n costly) job to undertake.. and no way can be guaranteed to be perfect
Fuelled is offline
Old 25th September 2006, 23:20   #6
Thanked: 22 Times
thnks for ur replies. if i have to fit it with a lpg wht is the cost of lps kit and wht mileage do i get and wht is the cost of lpg in hyderabad
raja_ys is offline
Closed Thread
Can i put 165/70/r13 tyres on alloys that say they need 175/70/r13's ? jcoxy4 Tyre & Alloy wheel Section 6 20th November 2008 04:19
CAn I put 15" rims with 50 profile yokohamas on my esteem?? joshzma225 Tyre & Alloy wheel Section 16 20th July 2006 22:22
whats the max size of alloys and tyres can i put to a santro cooldude585 Tyre & Alloy wheel Section 14 19th June 2006 11:09
Can we put XETA interiors in Indica Turbo Diesel? abhee Modifications & Accessories 6 12th May 2006 16:59
